Am I going nuts (or just ga-ga)?
Nothing to do with music but, I have downloaded 2 .pdf blood pressure logs as my doctor has suggested I monitor my BP. I have bought a machine. 20 quid from a local pharmacy and that works fine.
However, when I open the .pdf charts with Acrobat reader I find I cannot enter any text.
I was doing this for Blackstar some ten years ago with amp test data and I even tried the same W7 laptop I used then after giving up with W10.
So, what is the daft old fekker getting wrong?
Posts: 18094 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: Am I going nuts (or just ga-ga)?
Post by Random Guitarist »
Are they definitely editable pdfs, or just standard pdfs you're supposed to print out?
Random Guitarist
Posts: 1129 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Random Guitarist wrote: Fri May 27, 2022 8:58 am Are they definitely editable pdfs, or just standard pdfs you're supposed to print out?
Wow! That's quick. How can I tell Random? I thought a .pdf was just a .pdf! The whole point of which being you could enter data?
This is doing your blood pressure no good at all :)
We have to do the same thing Dave, but I use good old fashioned pen and paper, and show the doctor in person, "when" I can get an appointment :(
Posts: 19820 Joined: Sat Jul 12, 2003 12:00 am
Arpangel wrote: Fri May 27, 2022 9:07 am This is doing your blood pressure no good at all :)
Av' of 2 at 06:45 today 147/76. I actually did see a doctor face to covered face yesterday. She seemed quite anxious to be shot of me!
But yes, getting in is a bind that is why I thought a .pdf log and then I could email it in periodically. Have to find out how to do that though. I use 'systemonline' to get my drugs, probably a way in that.
Post by IAA »
This is what I do. Painless and fail safe.
IAA
Posts: 1424 Joined: Fri Dec 28, 2007 12:00 am
Sometimes I just write stuff down and send it as an Open Office/Word compatible document.
Post by BillB »
If it is anything liike this one
https://bihsoc.org/wp-content/uploads/2 ... _diary.pdf
There is nothing editable about it. I could convert yours to Word format if that would help.
BillB
Posts: 2197 Joined: Mon Apr 07, 2003 12:00 am Location: East Yorkshire
Post by Mike Stranks »
Hi Dave
What version of Word do you have - assuming you have it? As has been said, later versions have a PDF-Word converter built in...
On my new Win 11 laptop I have opted-out of 'Office' and am using this:
https://www.wps.com/
Comes with various PDF manipulation options... Works well and is compatible with Win 7...
I'm just a 'bread and butter' user and haven't explored if it can do some of the more esoteric functions that Excel, f'r instance, provides...
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Post by BJG145 »
BillB wrote: Fri May 27, 2022 10:17 am If it is anything liike this one
I've always found Acrobat Reader quite confusing and annoying. However, by clicking on the icon for "Sign document by typing or drawing a signature" in the toolbar (Acrobat Reader DC v2022), I was able to fill in the fields on that document and save it.
Posts: 7722 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Post by resistorman »
I use Microsoft Edge as my PDF wrangler, and you can mark up PDFs with it. That's all it's good for these days, which is sad as it had a promising start when it went to chromium.
resistorman
Posts: 2886 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Thanks chaps.
Resistorman, I did get Edge to work but tis very fiddly and I cannot change the typeface or density.
I shall print out a form and do it by hand as advised, if I can get my scanner working I could still email it in.
ef37a wrote: Fri May 27, 2022 4:11 pm I shall print out a form and do it by hand as advised, if I can get my scanner working I could still email it in.
Not sure what kind of phone (if any) you have Dave but I've not used my scanner in ages, a photo of an A4 doc comes through more than good enough for legibility purposes.
Posts: 28013 Joined: Sun Jul 05, 2015 12:00 am Location: York
blinddrew wrote: Fri May 27, 2022 4:30 pm
Good enough perhaps Drew but my colour scanner does not 'shake' or screw the geometry. I reckon I could do better with a proper camera than a phone?
Post by BillB »
I use 'Genius Scan' app on the iPad to scan, PDF and email receipts etc. Very painless once set up and understood - and it allows you to correct wonky perspectives. Also available on Android.
BillB
Maybe you could take a picture with your phone and send that?
resistorman
BillB wrote: Fri May 27, 2022 5:32 pm I use 'Genius Scan' app on the iPad to scan, PDF and email receipts etc. Very painless once set up and understood - and it allows you to correct wonky perspectives. Also available on Android.
You don't GET "wonky perspectives with a scanner! Geez! Talk about re inventing the wheel!
Post by BillB »
Dave, you raised the concern about screwing the perspective with a phone, I’m just letting you know that the app can deal with it and, as Drew says, with plenty of resolution to be readable. I use it because I can’t take a scanner on the train, and also because it’s a lot easier even when I am in the office or at home. But if you can get your scanner working, carry on with what you like and know.
BillB
BillB wrote: Fri May 27, 2022 11:47 pm Dave, you raised the concern about screwing the perspective with a phone, I’m just letting you know that the app can deal with it and, as Drew says, with plenty of resolution to be readable. I use it because I can’t take a scanner on the train, and also because it’s a lot easier even when I am in the office or at home. But if you can get your scanner working, carry on with what you like and know.
Yeah, I know Be' Just me being a cranky, flippant old sod!
Post by BJG145 »
Try the "Fill and Sign" button in Acrobat Reader.
https://helpx.adobe.com/acrobat/using/f ... -sign.html
Click on the button, click on the field, and type away.
(This is assuming that the form has been created with fields, but it probably has.)
Post by BillB »
ef37a wrote: Sat May 28, 2022 8:52 am Yeah, I know Be' Just me being a cranky, flippant old sod!
I can neither confirm nor deny that's what I was thinking :bouncy:
BillB
You haven’t even reached the bottom slopes of cranky-hood yet Dave, I bought a beer from the local corner shop, threw the car keys on the back seat, and tried to start the car with the beer can.
:shocked:
Post by BillB »
:bouncy: Best laugh so far today :bouncy:
BillB
BillB wrote: Sun May 29, 2022 9:49 am:bouncy: Best laugh so far today :bouncy:
It’s not good, more of these types of things are happening, it’s bad.
