Not sure what kind of phone (if any) you have Dave but I've not used my scanner in ages, a photo of an A4 doc comes through more than good enough for legibility purposes.
Am I going nuts (or just ga-ga)?
Re: Am I going nuts (or just ga-ga)?
Forum Aficionado -
Posts: 24657 Joined: Sun Jul 05, 2015 12:00 am
Good enough perhaps Drew but my colour scanner does not 'shake' or screw the geometry. I reckon I could do better with a proper camera than a phone?
I use 'Genius Scan' app on the iPad to scan, PDF and email receipts etc. Very painless once set up and understood - and it allows you to correct wonky perspectives. Also available on Android.
- resistorman
Frequent Poster - Posts: 2693 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
You don't GET "wonky perspectives with a scanner! Geez! Talk about re inventing the wheel!
Dave, you raised the concern about screwing the perspective with a phone, I’m just letting you know that the app can deal with it and, as Drew says, with plenty of resolution to be readable. I use it because I can’t take a scanner on the train, and also because it’s a lot easier even when I am in the office or at home. But if you can get your scanner working, carry on with what you like and know.
BillB wrote: ↑Fri May 27, 2022 11:47 pm Dave, you raised the concern about screwing the perspective with a phone, I’m just letting you know that the app can deal with it and, as Drew says, with plenty of resolution to be readable. I use it because I can’t take a scanner on the train, and also because it’s a lot easier even when I am in the office or at home. But if you can get your scanner working, carry on with what you like and know.
Yeah, I know Be' Just me being a cranky, flippant old sod!
Try the "Fill and Sign" button in Acrobat Reader.
https://helpx.adobe.com/acrobat/using/f ... -sign.html
Click on the button, click on the field, and type away.
(This is assuming that the form has been created with fields, but it probably has.)
