Bass strings for Jazz bass
For all tech discussions relating to Guitars, Basses, Amps, Pedals & Accessories.
Re: Bass strings for Jazz bass
Post by ManFromGlass »
So a thicker string has more tension and thus you have to work harder?
Posts: 7473 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Post by Tim Gillett »
Back then, electric was often not recorded direct but through an amp and cab, and miced up. Then if the Motown drum tracks are any guide the tape could be heavily saturated. So there may be more going on on say Jameson's bass lines.
Tim Gillett
Posts: 2698 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
Post by Aled Hughes »
Tim Gillett wrote: Fri May 27, 2022 8:49 pm Back then, electric was often not recorded direct but through an amp and cab, and miced up. Then if the Motown drum tracks are any guide the tape could be heavily saturated. So there may be more going on on say Jameson's bass lines.
Most things I’ve read suggests that the bass was usually DI’d and an amp only used for monitoring.
Aled Hughes
Posts: 2027 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Post by Gus784 »
I have had the TI flatwounds on my ‘78 Fender Jazz for more than 10 years and they are fantastic. Great tone and easy to play. Expensive option but you can’t go wrong with TI’s if you are looking for lower tension strings.
On my Fender Precision I first tried GHS flatwounds but the tension was too high. Then I tried the La Bella low tension flats but the tone on one of the strings was funky. Ultimately I landed on DR Sunbeam roundwounds whch are low tension, easier to play and yet still have that great roundwound tone. A nice contrast with the Jazz bass.
Gus784
Posts: 13 Joined: Sat Jan 16, 2010 12:00 am
