Eddy Deegan, meet Nina, and then get your credit card out
New analog synth coming to NAMM 2022
https://www.youtube.com/shorts/lmrAHSgHwdM
Nina is a 12-voice analogue polysynth with motorised knobs - when you select a preset, all of them will immediately move to their correction positions. As you can see and hear, patch morphing is an option, too.
See what you think Eddy, and of course everybody else ;)
Posts: 21669 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: Eddy Deegan, meet Nina, and then get your credit card out
Post by BJG145 »
Martin Walker wrote: Sat May 28, 2022 7:34 pmNina is a 12-voice analogue polysynth with motorised knobs
...motorised...knobs...
Sensory overload. :lolno::crazy:
Posts: 7736 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Post by resistorman »
BJG145 wrote: Sat May 28, 2022 7:41 pm
Just try to replace them when they go bad :mrgreen: It would make finding obsolete ICs seem trivial.
resistorman
Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by ajay_m »
But why? If behringer could put 32 rotary encoders with led collars in the bcr2000 for £150 why not just go that way and have no moving parts. Even if the underlying circuitry is analogue you could drive that with those digital pot chips and have a design that has almost no failure points.
ajay_m
Posts: 1314 Joined: Mon Jan 16, 2017 7:08 pm
Post by muzines »
Internet forums: "Where's all the innovation? Why aren't companies trying something new? Why are they falling back on the same old things?"
Company tries something new.
Internet forums: "What's the point? Who needs this? Who asked for this? Why don't they just use this other thing that other companies have already done that was fine?"
I'm all for companies trying stuff, especially if they genuinely think it works well. And many of the people who demand innovative products just don't realise how conservative this segment is. Innovation has often done very poorly in the market (eg, "Wavestation? Meh, it doesn't even have a piano sound...").
Is this particular feature genuinely useful, or just a gimmick that isn't that great? No idea - but when a few more people use it, I'm sure we'll find out. It's not something that has never been thought of before, it's just a tricky one to implement well, and reliably, and is probably expensive too.
Honestly, I'm fine with people trying out more experiments in the user interface of these things (especially in the softwaresynth controller space, which is... dire...)
muzines
I love the concept! I'd prefer the teaser not to have wild panning on the sound but of course that's not a reflection on the product at all, just the choices of the demo creators.
I will be watching this with interest, thank you Martin :D
Posts: 9596 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Quite honestly I'm not impressed. The same can be readily done with MIDI-learned setups on any decent soft-synth - so there's your visual with no actual moving parts to wear out.
Posts: 19905 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by OneWorld »
Sounds like a glorified wah-wah pedal - there's a whole lotta wee-wahin' goin' on
Sounds like a bit of a one trick pony sort of thing
OneWorld
Posts: 5306 Joined: Tue Apr 07, 2009 12:00 am
OneWorld wrote: Sat May 28, 2022 10:46 pm Sounds like a glorified wah-wah pedal - there's a whole lotta wee-wahin' goin' on
A demo does not a synth make, as we saw (and sadly heard) with the Andersons video on the Behringer UB-Xa.
What I took from the Nina short teaser wasn't the sound or the capabilities of the engine but the fact that someone has designed and implemented automated motorised knobs.
This could be a huge thing and with respect I think some previous repliers to the topic are overlooking the implications.
I could waffle on as to why but I'll raise two salient points:
1) Look at what fader automation did for mixing desks
2) Analogue synth hardware suffers from a limitation that when recalling a preset the physical knobs on the control surface don't reflect the current settings
This is why features such as a dot next to a parameter value on an LCD indicates the knob not matching the preset value, and why we have global settings to determine whether a knob is going to jump to a new value when turned or whether to remain ineffective until the existing value is met during the operation of turning it.
Of course plugins/softsynths can do it already but for those of us with analogue (and even digital-with-knobs) synth hardware the potential is a very exciting prospect indeed.
All the above aside, I still want to know more about the synth that is Nina and will keep a weather-eye (ear?) open!
Post by BJG145 »
Eddy Deegan wrote: Sat May 28, 2022 11:11 pmLook at what fader automation did for mixing desks
...yep, I was thinking that if they implemented a record/playback feature it could encourage a new approach to modulation; a bit like the Mod Sequencer on the MS2000, but with continuous values instead of steps. But I think you'd need touch-sensitive controls to do it effectively, like the touch-sensitive motorised faders on a desk that can flip into write-mode when you adjust them. Definitely an interesting innovation though.
Post by t-sun »
On the one hand, 12-voice all analog with what looks like nice, chunky build quality and plenty of features is always nice.
On the other hand, motorized anything are both guaranteed to fail and to be expensive or difficult to both produce reliably and to later replace.
Given that this is full analog, I'm thinking this was their solution to the fact that a full analog synth can't actually have patch memory because it would require digital control of the knobs to some degree. Seems to be a complaint with some DAW people who buy an analog monosynth and then don't understand why it's not controllable by MIDI. If you absolutely, positively have to have a completely analog synthesizer with modern conveniences...
Over/under on price? I'm thinking 4K local currency units. Could be up there in Moog One territory, or maybe they manage to get it priced around Polybrute.
t-sun
Posts: 264 Joined: Mon Jan 18, 2021 6:31 am
t-sun wrote: Sun May 29, 2022 12:02 am ... motorized anything are both guaranteed to fail and to be expensive or difficult to both produce reliably and to later replace.
I gently disagree. Not insofar as I'd go so far as a motorised fader or pot will match the life expectancy of a dumb fader or pot but we've had motorised faders for a long time now and they seem extremely reliable.
Where I would possibly agree with you is that the life of motorised controls of any sort is a bit of an unknown: I'm sure many of us have had a floppy drive fail after 20 years for example. But overall the fader solutions seem fairly robust and long-lived. I've also resurrected floppy drives with a new rubber belt more than once.
To my way of thinking the biggest issue with longevity is capacitors as opposed to mechanics. But I agree that if there are rubber belts involved they should be spec'd for decades of use. If the motors are well made they should last for as long as the capacitors and should also be replaceable in 20 years although one suspects that by then there should be replacement models to choose from.
BJG145 wrote: Sat May 28, 2022 11:49 pm ... I was thinking that if they implemented a record/playback feature ...
Now you're talking my language :)
https://reverb.com/uk/item/1403837-sold ... s-rare-slo
Guitarists had something along these lines decades ago ;)
Posts: 13022 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Well Nina has certainly generated a lot of interest!
Let's hope future demos highlight her strengths in a more obvious fashion.
Post by pax-eterna »
Martin Walker wrote: Sat May 28, 2022 7:34 pmNew analog synth coming to NAMM 2022
This is going to be BIG dollars!
pax-eterna
Posts: 166 Joined: Sun Apr 22, 2007 12:00 am
Want it.
Posts: 19893 Joined: Sat Jul 12, 2003 12:00 am
Post by OneWorld »
Eddy Deegan wrote: Sun May 29, 2022 12:16 am
I can't see it being much use without the ability to record the movements. For me the demo left me a bit non-plussed, I thought ok, we have some filter sweeps and such - so what next? But yes if there is the addition of recording, then wow, it would be like having 8 hands, all making changes simultaneously, yo could go crazy with that, not modulation but madulation.
In a more general sense, it is good to see new developments coming along and this might be something the more established marques, Yamaha, Korg, Roland et al might licence and use in their products
OneWorld
It's clever, I'll give them that. But, there's a difference between being innovative and just bolting on some motorized pots to a moldering paradigm.
resistorman
As far as motorized synths go, I'd call the Gamechanger Audio MOTOR Synth Mk2 innovative.
https://www.youtube.com/watch?v=c81RCOBrrcM&t=61s
resistorman
Post by Ian Shaw »
zenguitar wrote: Sun May 29, 2022 12:42 amhttps://reverb.com/uk/item/1403837-sold ... s-rare-slo
I had a Yamaha rackmount thing that had motorised knobs many moons ago. I think Alan Holdsworth used one. My band mates were well-impressed:
https://reverb.com/uk/item/54003713-vin ... 0-s-1990-s
PS. Not by my guitar sound or playing, it has to be said
Ian Shaw
Posts: 181 Joined: Wed Dec 22, 2004 12:00 am Location: Somerset
'...and when we got bored, we have a world war...'
OneWorld wrote: Sun May 29, 2022 10:46 am But yes if there is the addition of recording, then wow, it would be like having 8 hands, all making changes simultaneously, yo could go crazy with that, not modulation but madulation.
Admittedly you can already do this with other synths - it's one of the reasons I bought my Prophet 12, as there was a dedicated knob for almost every parameter, that sends out MIDI controller data when you move it. I've recorded plenty of multi-pass solos where I'd need 7 or 8 hands to perform it in real time ;)
For me the beauty of Nina is that you can see in real time exactly what parameters are changing on the synth itself, without having to look on a screen somewhere - so much easier to take in all the info.
Post by steveman »
Tough crowd...
To the person who commented they're able to do this this in software, really who cares? We all know this thanks, and we're using software where we want to.
This for those interested in hardware.
As Martin says, this is about seeing exactly where you controls are set when you recall a patch. Encoders don't feel or behave the same, there's no physical endstop and without encoders you're stuck with deciding jump, match, or relative modes of knob catchup. Jump is useless for performance (I was surprised this has yet to be implemented on the UDO Super Six), match is not much better. Relative (or 'catch up' works best provided the knob isn't at an endstop.
I don't see a problem with this - if you're not interested, move along. Why on an analgue synth? I'm guessing because it's likely to have fewer controls which makes this more likely to be cost effective.
steveman
Posts: 62 Joined: Sun Mar 17, 2002 12:00 am Location: London - UK
resistorman wrote: Sun May 29, 2022 2:22 pm It's clever, I'll give them that. But, there's a difference between being innovative and just bolting on some motorized pots to a moldering paradigm.
After thinking about this, I agree, it’s a sledge hammer to crack a nut really, in not a very elegant way.
It's quite interesting to hear different takes on it.
Motorised knobs are nothing new, the volume knob on my NAD amp is automated and I bought that nearly 15 years ago. What I am more surprised about is that they haven't been more prevalent on synthesizers as it's a use case that cries out for them.
Perhaps the economy of scale is kicking in, or perhaps the tech is cheaper now. I don't know but on a synth it's a desirable feaure and I for one welcome the introduction of them even if it's still rather niche.
Of course with digital knobs (usualy endless encoders) we've had the 'ring of light' solution for it which does work well (the Korg Radias springs to mind) but it's not precise and I've never seen it on an analogue device.
Each to their own and all that but I applaud and welcome it. I am interested as a potential buyer so there is a target market for certain. How big that market is remains to be seen but I'm all for it as a trend ;)
