Vicious Antelope - Synth Preset Packs List - Updated
Post by viciousantelope »
Hi everyone,
I am Tolis with Vicious Antelope a sound designer that have released many soundbanks for synths like Pigments 3, Massive X, Omnisphere 2, DIVA, Zebra etc.
You could find my packs at: https://www.viciousantelope.com/presets-for-synths
For most of my soundbanks ther is a preset walkthrough video on my Youtube channel. Here is the playlist I have already created: https://youtube.com/playlist?list=PLaR9 ... mtnPaXMKP6
Latest addition is soundbank Savanna for Pigments 3. It is the third soundbank of "Biome" series for Pigments 3 after Steppe and Tundra. It contains 80 presets like huge pads, classic polysynths, epic leads and other with cinematic flavor, trying to capture the Savanna biome and transform it to sound. It fits for styles like cinematic, prog and post rock, electronic music and other. There are many modulation options and for all presets MW, AT and the 4 Macros are assigned to a variety of parameters to give new dimensions to your sound. Analog Lab V edition also available.
You could grab it at: https://www.viciousantelope.com/product ... pigments-3
Intro price 7,00€ until July 01,2022 ( Normally 17,00€ )
https://youtu.be/yCe9UL_HEdM
All presets designed and run best with Pigments 3.7.0.2587 (x64)
All the best,
Tolis
viciousantelope
Posts: 334 Joined: Sat Jun 25, 2022 8:16 am
Re: Vicious Antelope - Synth Preset Packs List - Updated
New DIVA soundbank has been released
Prog Rock is a 100 preset soundbank for the great DIVA synth. As the name suggests the sounds were designed having the giants of 70's progressive rock in mind. Beside that its analog sound could also fit to electronic music and Techno. MW usually adds vibrato and AT most of the times glides pitch up or down
It contains:​
20 Synth Keys​
20 Long Synths​
20 Leads​
20 Experimental Synths​
15 Bass Synths​
5 Airy Synths​
You can grab it at: https://www.viciousantelope.com/product ... -rock-diva
Intro price 8,00€ until July 10, 2022 ( Normally 20,00€)
Introduction Video ( All music produced with Prog Rock Soundbank)
https://youtu.be/9AHr-wys10c
Preset Walkthrough Video
https://youtu.be/QSYed1_SwLo
Presets were designed with Diva 1.4.4 (Rev.9709) and run best with Diva 1.4.4 (Rev.9709) or newer
viciousantelope
New Pigments 3 soundbank
Mediterranean is our 4th sounbank of Biome series presets for Pigments 3. It contains 80 unique synths and leads for your productions. Explore the Mediterranean ecosystem and its characteristics in a sound dimension. MW usually used for Vibrato, AT for pitch drift or other setting and the 4 Macros are assigned to give new dimensions to the sounds.
You can grab it at: https://www.viciousantelope.com/product ... pigments-3
Intro price 7,00€ until July 11, 2022 (Normally 17,00€)
Introduction Video - All music except percussion produced with Mediterranean
https://youtu.be/TTGE4tiD4CA
https://youtu.be/Dibe77OATYQ
viciousantelope
Cinematic Synths Vol.3 for Zebra released - Freebie
Cinematic Synths Vol.3 - The drums for Zebra 2 contains 25 percussive elements for your productions. They fit not only to cinematic music but also to electronic, house, techno or even more rock/metal styles. It is a great fit with our Cinematic Synths Vol.1 & Cinematic Synths Vol.2 soundbanks.
You can grab Cinematic Synths Vol.3 at : https://www.viciousantelope.com/product ... ums-zebra2
All Cinematic Synths series at: https://www.viciousantelope.com/presets ... +for+Zebra
Music Video - All music produced with our Cinematic Synths soundbanks
https://youtu.be/QsIvA6e2zwU
Presets were designed and run best with Zebra 10409 or newer
viciousantelope
New Pigments 3 soundbank has been released
Arctic is the 5th soundbank for Pigments presets series "Biome". As all previous "Biome" soundbanks there are 80 experimental approach designed sounds like polysynths, keys, pads and leads. The sound dimension of the Earth's poles full of character and cold atmospheres.
MW and AT mostly assigned to vibrato and pitch change respectively. All 4 macros are assigned to different elements for richer dimensions in your sound.
- You can grab Pigments edition at: https://www.viciousantelope.com/product ... pigments-3
- Analog Lab edition at: https://www.viciousantelope.com/product ... alog-lab-v
Intro price 7,00€ until July 17, 2022 (Normally 16,99€)
Intro Video - All music produced only with Arctic
https://youtu.be/6SjQ90HDWRM
Presets Walkthrough video
https://youtu.be/41B3u0_db2I
viciousantelope
New DIVA soundbank release
Prog Rock 2 is a 100 preset soundbank for the great DIVA synth and second in our DIVA presets series "Prog Rock". As the name suggests the sounds were designed having the giants of 70's progressive rock in mind. Beside that its analog sound could also fit to electronic music and Techno. MW usually adds vibrato and AT most of the times glides pitch up or down.
It contains:
50 Huge Synths Presets
50 Soft Synths Presets
Grab it at: https://www.viciousantelope.com/product ... ock-2-diva
Intro price 8,00€ until July 18,2022 (Normally 19,99€)
Intro Video - All music produced only with Prog Rock 2 soundbank
https://youtu.be/nrqC5Omdpos
Presets walkthrough video
https://youtu.be/2_blf6pvabk
viciousantelope
New HIVE 2 soundbank released
Electronic Music Toolkit Vol.2 is a Hive presets pack containing 80 new sounds designed for electronic music producers. Main purpose here is mainly to create huge sounds for your productions with lot of vintage coloration in most of presets. Beside those there are some experimental synths that can be used for a variety of purposes like melody lines, transitions or sound effects.
This Hive 2 soundbank contains:
10 Bass presets
20 Experimental presets
50 Polysynth presets
You can grab it at : https://www.viciousantelope.com/product ... l-2-hive-2
Intro price 5,20€ until July 19, 2022 (Normally 12,99€)
Electronic Music Toolkit Vol.1 is available at: https://www.viciousantelope.com/product ... ol-1-hive2
https://youtu.be/iiJmjYjPYuk
Presets were designed with Hive2 v2.1.1 (revision 12092)
viciousantelope
Tundra Soundbank also available for Analog Lab V users
Tundra is a 100 presets soundbank for Analog Lab V designed with Pigments 3. It contains basses, pads, leads, keys and synths with a cold atmosphere from the depths of Tundras. Many experimental sounds here like most of our soundbanks that are fitting for many genres from electronic and cinematic to rock and experimental.
You can grab it at: https://www.viciousantelope.com/product ... alog-lab-V
Price only 9,99€ because there are no assignments to the 4 macros.
Demo song video - All music produced with Tundra
https://youtu.be/vnCiYreyR9I
viciousantelope
50% off all soundbanks + 10% coupon + new Pigments 3 Soundbank
All our soundbanks for half the price. The half price offer do not apply for the products that are running with their intro price - although you can use coupon to get an additional 10% for them. End date July 17.
On checkout use code JULY10 to get an additional 10% to all of our soundbanks
Mountains for Pigments 3 and Analog Lab V released
Mountains is the 6th Pigments soundbank in our Biome series. It contains 80 experimental synth presets inspired by the scapes, fauna and flora of the Mountains Biome. Those Pigments presets could fit for genres like electronic music, progressive rock, post rock to cinematic and more experimental styles. Mw mostly used for vibrato and AT for pitch quest. All 4 macros are assigned to a variety of Pigments synth elements to create new dimensions on your sound pallete.
Analog Lab edition : https://www.viciousantelope.com/product ... alog-lab-v
Intro price 7,00€ until July 20, 2022 (Normally 16,99€)
Intro video - All music produced with Mountains
https://youtu.be/kX-KFGW_CIY
https://youtu.be/m4y_OJhKdY4
All presets designed and run best with Pigments 3.7.0.2587 (x64) or newer
Analog Lab V Soundbank needs at least version Analog Lab V 5.5.0.2592 (x64)
viciousantelope
New DIVA sounbank release
Prog Rock 3 contains 70 DIVA presets inspired by the early 70's prog bands sound that defined a golden era of music. Their classic sound could be used for a variety of music genres beside progressive rock. MW usually adds vibrato and AT most of the times glides pitch up or down.
You can grab at: https://www.viciousantelope.com/product ... rock3-diva
Intro price 6,49€ until July 20,2022 (Normally 15,99€)
Intro Video - All music produced only with Prog Rock 3
https://youtu.be/71qVx6frm5I
https://youtu.be/XFXVUUGXTzI
viciousantelope
Re: Vicious Antelope - Synth Preset Packs List - Updated - New Omnisphere soundbank
New Omnisphere 2 Sounbank released
Omnisound Saws is a 50 Omnisphere patches soundbank created with Saw oscillators. This bank has mainly a sci-fi feeling with lot of majestic character. MW for vibrato and AT most of the times for pitch quest.
You can grab at: https://www.viciousantelope.com/product ... nisphere-2
Intro price 6,49€ until July 22, 2022 (Normally 12,99€)
https://youtu.be/U7EBVgOyL_w
Presets were designed and run best with Omnisphere 2.8 or newer
• Software 2.8.3d
• Soundsources v2.6.1c
• Patches v2.8.1c
viciousantelope
The Analog Pads for DIVA is now free
It contains 100 premium pads for DIVA. Great for a variety of music genres like electronic music, cinematic and rock
You can grab it here: https://www.viciousantelope.com/product ... undle-diva
......And we offer a discount equally with its old price
Use JULY3 on your next orders until July 21th, 2022 to get an additional 3,00€ discount on your purchases.​
*It cannot be used with JULY10 code for the same order​
viciousantelope
New Omnisphere 2 small soundbank release
Omnisound Saws 2 The Legatos is a small Omnisphere 2 soundbank consisting of 20 legato synth sounds with sci-fi character. It is a great addition to the first "Omnisound Saws" Omnisphere presets. MW for Vibrato and AT for pitch quest.
Intro price 3,99€ until July 22nd,2022 (Normally 4,99€)
Preset walkthrough video
https://youtu.be/zqBDAPk-4P4
• Software 2.8.3d
• Patches v2.8.1c
viciousantelope
New DIVA soundbank released
Orange Dream Vol.1 is the first 50 presets DIVA soundbank in our new series inspired by one of my biggest influences in music. This pack consists of 30 short synths and 20 mono basses. MW and AT are assigned to vibrato and pitch quest respectively.
You can grab it at: https://www.viciousantelope.com/product ... vol-1-diva
Intro price 5,49€ until July 25th (normally 11,99€)
https://youtu.be/Bw6P87IAoIw
viciousantelope
ELOY (Enraptured Leads Of Yesterday) Vol.2 is a deep dive into the seventies progressive and space rock synth leads. Inspired by one of my favorite bands ever it contains 50 DIVA lead presets.
You can grab it at: https://www.viciousantelope.com/product ... vol-2-diva
Intro price 5,49€ until July 25th, 2022. (Normally 10,99€)
https://youtu.be/35QMOLWk17Y
viciousantelope
Orange Dream Vol.2 consists of 50 vintage sounding presets for uHe DIVA synth. It continues the previous Orange Dream Vol.1 soundbank and it is heavily influenced by one of the most iconic bands ever existed. All 50 presets are polysynths with MW and AT attached mainly to vibrato and Resonance respectively.
Intro price 6,00€ until July 31, 2022 (Normally 11,99€)
Presets Walkthrough Video
https://youtu.be/DBH0xLasiyk
viciousantelope
New Massive X soundbank has been released
Perihelion is a 50 presets soundset that explores mainly the bright side of Massive X synth. Its sound is influenced by the 90's workstation hardware synthesizers. Here there are some classic atmos, some weird keys and bright polysynths.
You can grab it at: https://www.viciousantelope.com/product ... -massive-x
Intro price 5,99€ until July 31st, 2022 (Normally 11,99€)
Introduction video
https://youtu.be/Yx8o5sNxKmY
https://youtu.be/J_a8oFLbokE
Presets were designed with Massive X 1.3.5 (R238) and runs better with Massive X 1.3.5 (R238) or newer edition
viciousantelope
New Omnisphere 2 patches release
Zeus is the first soundbank of our new series for Omnisphere 2 under the name 12 Gods.
12 Gods: Zeus contains 50 patches inspired by the king of the 12 Greek Gods. Here you could find folklore sounds, epic synths, playable soundscapes and dark pads. The presets have a deep cinematic character.
You can grab it at: https://www.viciousantelope.com/product ... nisphere-2
Intro price 6,99€ until August 2nd, 2022 (Normally 12,99€)
https://youtu.be/8Zmez_5i5D0
Presets were designed with Omnisphere 2.8 or and run best with this or newer version
• Software 2.8.3d
• Patches v2.8.1c
viciousantelope
All Soundbanks 50% off ​
Almost 100 packs and 3800 presets for your productions on big sale. The next 3 weeks Vicious Antelope will not release new soundbanks. That's why I decided to run a half price offer for all August.
Plus the Coupon: Use code "AUG10" for an additional 10% on the discounted price!
...Coupon will be valid all August
You can shop the offer at: https://www.viciousantelope.com/presets-for-synths
viciousantelope
New Omnisphere soundbank release + August sale continues
12 Gods: Hera is the second Omnisphere soundbank of "12 Gods" series. It consists of 50 unique atmospheric sounds inspired by the queen of the Greek Gods. All patches are based on bowed string instruments, creating atmospheric cinematic tension and ancient soundcolors.
When I create soundbanks for any synth I love to see each one as a full music album and each patch of the soundbank as a different song of that album.
I believe this is what describes Hera soundbank best. A sound journey through the mythological stories related to Hera ( or Juno in the Roman pantheon) , her character, famous myths about her and her relationship with other Gods.
You can grab it at:
Intro price 6,50€ until August 31st (Normally 12,99€)
Presets walkthrough video : https://youtu.be/r1R1b29hrIk
• Software 2.8.3d
• Patches v2.8.1c
viciousantelope
Prog Rock 4 is the final soundbank of Prog Rock series for DIVA synthesizer. Its presets are inspired by the famous organ sounds of the 70s and their distinct character. It is a great dive into that golden Era of music that have influenced a variety of music genres.
The sounds are mainly focused on Progressive Rock style but they would also be used on modern rock and pop tracks or even some experimental productions.
You can grab it at: https://www.viciousantelope.com/product ... ock-4-diva
Intro price 4,00€ until August 31st (Normally 7,99€)
https://youtu.be/74CYIzfi3WA
viciousantelope
Prog Rock Bundle for DIVA is out
Prog Rock Bundle for DIVA is a collection of 4 soundbanks for a total of 300 vintage sounding presets.
It is full package focused on Progressive Rock genre but it could also be used for Cinematic music as well as for Electronic productions especially those with dark sound character and those which rely on warm analog sounds.
The first soundbank of this collection is a generic journey through the Golden Era of music and it consists of 25 Synths, 20 Long synths, 20 Leads, 15 Basses and 5 Airy Synths.
Prog Rock 2 is focused on two opposite sides of synth sounds with 50 Huge synths and 50 Soft synths.
Prog Rock 3 is even more focused with 70 patches that dive into the early 70s soundcolors and it is full of nostalgia.
Finally Prog Rock 4 contains 30 organ sounds that fit with all the other Prog Rock packs and fills the blanks to create a multidimensional collection dedicated to the genre.
Intro price 34,99€ (Normally 49,99€)
For all 4 volumes there is a dedicated preset walkthrough video at our Youtube channel. https://www.youtube.com/channel/UCmj7_V ... lVjtlrw1oQ
https://soundcloud.com/viciousantelopep ... al_sharing
https://soundcloud.com/tolisvagios/prog ... al_sharing
viciousantelope
New Pigments 3 Library release - Analog Lab V edition available
Ocean continues the Biome series for Pigments. The 7th soundbank for this series is containing 80 new presets pads, synths, keys leads and basses including. Most of them were designed with the powerful wavetable engine of Arturia Pigments sometimes using only one engine sometimes stacked both engines with some fine-tuning difference to result to a fuller and more dimensional sound.
Ocean is a sound story of the depths of our planet’s seas, a journey through very special pelagic places and to some of the most known animal and plants that it hides. It is a perfect fit for cinematic and game audio music as well as for electronic and rock genres.
Analog Lab V edition at: https://www.viciousantelope.com/product ... alog-lab-v
Intro price 8,50€ until September 1st (Normally 16,99€)
https://youtu.be/9vVxhtHH6E4
- All presets designed with Pigments 3.7.1.2684 (x64) and run best with Pigments 3.7.1.2684 (x64) or newer
- Analog Lab V soundbank needs at least version Analog Lab V 5.5.1.2692 (x64) or newer
viciousantelope
New Omnisphere 2 soundbank release
12 Gods: Hephaestus is the 3rd soundbank of our 12 Gods series for Spectrasonics Omnisphere 2 synth. It contains 50 patches focused on creative percussive sounds with rich cinematic character and very often saturated tones to enhance the rhythm of your productions.
The percussions of this soundbank vary from deep tones with heavy tension to brighter metallic drums that fill the higher frequencies.
Each patch is dedicated to different myth or creation of the God of fire, craftsmen and blacksmiths. Hephaestus was the son of Zeus and Hera. He made the weapons of the Gods and some very notable crafts and armor of Greek mythology like Achilles armor, walking tripods and Hermes winged helmet.
Most of patches shine on the lower register of the keyboard. You could make them drier by disabling the reverbs or delays effects from the FX pages of Omnisphere.
You can grab it at:https://www.viciousantelope.com/product ... hephaestus
Intro price 6,50€ until September 3rd (Normally 12,99€)
https://youtu.be/jDk4EXzr6C0
• Software 2.8.3d
• Patches v2.8.1c
viciousantelope
