Vicious Antelope - Synth Preset Packs List - Updated
Post by viciousantelope »
Hi everyone,
I am Tolis with Vicious Antelope a sound designer that have released many soundbanks for synths like Pigments 3, Massive X, Omnisphere 2, DIVA, Zebra etc.
You could find my packs at: https://www.viciousantelope.com/presets-for-synths
For most of my soundbanks ther is a preset walkthrough video on my Youtube channel. Here is the playlist I have already created: https://youtube.com/playlist?list=PLaR9 ... mtnPaXMKP6
Latest addition is soundbank Savanna for Pigments 3. It is the third soundbank of "Biome" series for Pigments 3 after Steppe and Tundra. It contains 80 presets like huge pads, classic polysynths, epic leads and other with cinematic flavor, trying to capture the Savanna biome and transform it to sound. It fits for styles like cinematic, prog and post rock, electronic music and other. There are many modulation options and for all presets MW, AT and the 4 Macros are assigned to a variety of parameters to give new dimensions to your sound. Analog Lab V edition also available.
You could grab it at: https://www.viciousantelope.com/product ... pigments-3
Intro price 7,00€ until July 01,2022 ( Normally 17,00€ )
https://youtu.be/yCe9UL_HEdM
All presets designed and run best with Pigments 3.7.0.2587 (x64)
All the best,
Tolis
viciousantelope
Posts: 46 Joined: Sat Jun 25, 2022 8:16 am
Re: Vicious Antelope - Synth Preset Packs List - Updated
New DIVA soundbank has been released
Prog Rock is a 100 preset soundbank for the great DIVA synth. As the name suggests the sounds were designed having the giants of 70's progressive rock in mind. Beside that its analog sound could also fit to electronic music and Techno. MW usually adds vibrato and AT most of the times glides pitch up or down
It contains:​
20 Synth Keys​
20 Long Synths​
20 Leads​
20 Experimental Synths​
15 Bass Synths​
5 Airy Synths​
You can grab it at: https://www.viciousantelope.com/product ... -rock-diva
Intro price 8,00€ until July 10, 2022 ( Normally 20,00€)
Introduction Video ( All music produced with Prog Rock Soundbank)
https://youtu.be/9AHr-wys10c
Preset Walkthrough Video
https://youtu.be/QSYed1_SwLo
Presets were designed with Diva 1.4.4 (Rev.9709) and run best with Diva 1.4.4 (Rev.9709) or newer
viciousantelope
New Pigments 3 soundbank
Mediterranean is our 4th sounbank of Biome series presets for Pigments 3. It contains 80 unique synths and leads for your productions. Explore the Mediterranean ecosystem and its characteristics in a sound dimension. MW usually used for Vibrato, AT for pitch drift or other setting and the 4 Macros are assigned to give new dimensions to the sounds.
You can grab it at: https://www.viciousantelope.com/product ... pigments-3
Intro price 7,00€ until July 11, 2022 (Normally 17,00€)
Introduction Video - All music except percussion produced with Mediterranean
https://youtu.be/TTGE4tiD4CA
https://youtu.be/Dibe77OATYQ
viciousantelope
Cinematic Synths Vol.3 for Zebra released - Freebie
Cinematic Synths Vol.3 - The drums for Zebra 2 contains 25 percussive elements for your productions. They fit not only to cinematic music but also to electronic, house, techno or even more rock/metal styles. It is a great fit with our Cinematic Synths Vol.1 & Cinematic Synths Vol.2 soundbanks.
You can grab Cinematic Synths Vol.3 at : https://www.viciousantelope.com/product ... ums-zebra2
All Cinematic Synths series at: https://www.viciousantelope.com/presets ... +for+Zebra
Music Video - All music produced with our Cinematic Synths soundbanks
https://youtu.be/QsIvA6e2zwU
Presets were designed and run best with Zebra 10409 or newer
viciousantelope
New Pigments 3 soundbank has been released
Arctic is the 5th soundbank for Pigments presets series "Biome". As all previous "Biome" soundbanks there are 80 experimental approach designed sounds like polysynths, keys, pads and leads. The sound dimension of the Earth's poles full of character and cold atmospheres.
MW and AT mostly assigned to vibrato and pitch change respectively. All 4 macros are assigned to different elements for richer dimensions in your sound.
- You can grab Pigments edition at: https://www.viciousantelope.com/product ... pigments-3
- Analog Lab edition at: https://www.viciousantelope.com/product ... alog-lab-v
Intro price 7,00€ until July 17, 2022 (Normally 16,99€)
Intro Video - All music produced only with Arctic
https://youtu.be/6SjQ90HDWRM
Presets Walkthrough video
https://youtu.be/41B3u0_db2I
viciousantelope
New DIVA soundbank release
Prog Rock 2 is a 100 preset soundbank for the great DIVA synth and second in our DIVA presets series "Prog Rock". As the name suggests the sounds were designed having the giants of 70's progressive rock in mind. Beside that its analog sound could also fit to electronic music and Techno. MW usually adds vibrato and AT most of the times glides pitch up or down.
It contains:
50 Huge Synths Presets
50 Soft Synths Presets
Grab it at: https://www.viciousantelope.com/product ... ock-2-diva
Intro price 8,00€ until July 18,2022 (Normally 19,99€)
Intro Video - All music produced only with Prog Rock 2 soundbank
https://youtu.be/nrqC5Omdpos
Presets walkthrough video
https://youtu.be/2_blf6pvabk
viciousantelope
New HIVE 2 soundbank released
Electronic Music Toolkit Vol.2 is a Hive presets pack containing 80 new sounds designed for electronic music producers. Main purpose here is mainly to create huge sounds for your productions with lot of vintage coloration in most of presets. Beside those there are some experimental synths that can be used for a variety of purposes like melody lines, transitions or sound effects.
This Hive 2 soundbank contains:
10 Bass presets
20 Experimental presets
50 Polysynth presets
You can grab it at : https://www.viciousantelope.com/product ... l-2-hive-2
Intro price 5,20€ until July 19, 2022 (Normally 12,99€)
Electronic Music Toolkit Vol.1 is available at: https://www.viciousantelope.com/product ... ol-1-hive2
https://youtu.be/iiJmjYjPYuk
Presets were designed with Hive2 v2.1.1 (revision 12092)
viciousantelope
Tundra Soundbank also available for Analog Lab V users
Tundra is a 100 presets soundbank for Analog Lab V designed with Pigments 3. It contains basses, pads, leads, keys and synths with a cold atmosphere from the depths of Tundras. Many experimental sounds here like most of our soundbanks that are fitting for many genres from electronic and cinematic to rock and experimental.
You can grab it at: https://www.viciousantelope.com/product ... alog-lab-V
Price only 9,99€ because there are no assignments to the 4 macros.
Demo song video - All music produced with Tundra
https://youtu.be/vnCiYreyR9I
viciousantelope
50% off all soundbanks + 10% coupon + new Pigments 3 Soundbank
All our soundbanks for half the price. The half price offer do not apply for the products that are running with their intro price - although you can use coupon to get an additional 10% for them. End date July 17.
On checkout use code JULY10 to get an additional 10% to all of our soundbanks
Mountains for Pigments 3 and Analog Lab V released
Mountains is the 6th Pigments soundbank in our Biome series. It contains 80 experimental synth presets inspired by the scapes, fauna and flora of the Mountains Biome. Those Pigments presets could fit for genres like electronic music, progressive rock, post rock to cinematic and more experimental styles. Mw mostly used for vibrato and AT for pitch quest. All 4 macros are assigned to a variety of Pigments synth elements to create new dimensions on your sound pallete.
Analog Lab edition : https://www.viciousantelope.com/product ... alog-lab-v
Intro price 7,00€ until July 20, 2022 (Normally 16,99€)
Intro video - All music produced with Mountains
https://youtu.be/kX-KFGW_CIY
https://youtu.be/m4y_OJhKdY4
All presets designed and run best with Pigments 3.7.0.2587 (x64) or newer
Analog Lab V Soundbank needs at least version Analog Lab V 5.5.0.2592 (x64)
viciousantelope
New DIVA sounbank release
Prog Rock 3 contains 70 DIVA presets inspired by the early 70's prog bands sound that defined a golden era of music. Their classic sound could be used for a variety of music genres beside progressive rock. MW usually adds vibrato and AT most of the times glides pitch up or down.
You can grab at: https://www.viciousantelope.com/product ... rock3-diva
Intro price 6,49€ until July 20,2022 (Normally 15,99€)
Intro Video - All music produced only with Prog Rock 3
https://youtu.be/71qVx6frm5I
https://youtu.be/XFXVUUGXTzI
viciousantelope
Re: Vicious Antelope - Synth Preset Packs List - Updated - New Omnisphere soundbank
New Omnisphere 2 Sounbank released
Omnisound Saws is a 50 Omnisphere patches soundbank created with Saw oscillators. This bank has mainly a sci-fi feeling with lot of majestic character. MW for vibrato and AT most of the times for pitch quest.
You can grab at: https://www.viciousantelope.com/product ... nisphere-2
Intro price 6,49€ until July 22, 2022 (Normally 12,99€)
https://youtu.be/U7EBVgOyL_w
Presets were designed and run best with Omnisphere 2.8 or newer
• Software 2.8.3d
• Soundsources v2.6.1c
• Patches v2.8.1c
viciousantelope
The Analog Pads for DIVA is now free
It contains 100 premium pads for DIVA. Great for a variety of music genres like electronic music, cinematic and rock
You can grab it here: https://www.viciousantelope.com/product ... undle-diva
......And we offer a discount equally with its old price
Use JULY3 on your next orders until July 21th, 2022 to get an additional 3,00€ discount on your purchases.​
*It cannot be used with JULY10 code for the same order​
viciousantelope
