Mediterranean is our 4th sounbank of Biome series presets for Pigments 3. It contains 80 unique synths and leads for your productions. Explore the Mediterranean ecosystem and its characteristics in a sound dimension. MW usually used for Vibrato, AT for pitch drift or other setting and the 4 Macros are assigned to give new dimensions to the sounds.
12 Gods: Hermes for Omnisphere 2 contains 50 ethereal synth patches inspired by the Messenger of Gods according to the Greek Pantheon. The soundbank mainly uses slow evolving amp envelopes and with the parallel use of an Aux reverb it creates airy, dreamy and full of motion soundcolors for most of the presets.
New Dimension for Serum contains 80 presets mainly focused but not limited to Progressive and Deep House genre.
Most of the pads have a rhythmic (subtle or more obvious) element sometimes different than the classic 1/4 rate, to help you set some unusual but interesting multidimensional movement in conjunction with the classic sidechain compression linked to the Kick of your tracks.
Mystic Places is an 100 patches soundset for DIVA made with the DUAL VCO and the Digital Envelopes which are inspired from some legendary synths of the past. It contains 71 poly synths and 29 legato leads with vintage character.
12 Gods: Demeter library for Spectrasonics Omnisphere contains 50 poly synth patches inspired by the Goddess of Harvest according to Greek pantheon. Here there are some analog classics keys and synths with evolving motion and vintage character.
Desert for Pigments 3 is the 10th and last pack of our Biome series for this incredible synth by Arturia. It contains 80 atmospheric sounds including 70 evolving synths and pads as well as 10 experimental percussions.
12 Gods: Apollo is a 50 folk and ethnic patches soundbank for Spectrasonics Omnisphere 2. All presets are based on plucked strings inspired by Apollo’s lyre. The presets are using Omnisphere’s Soundsources as base to create folk sound colors with fast attack envelopes. Mandolins, Saz and Nylon Guitars are the most used elements to achieve that.
Harmonic Keys for Arturia Pigments 3 is a free library of 40 keyboard patches created exclusively with additive synthesis (Harmonic engine of Pigments 3).
Outrun Time is a Synthwave library for Arturia Pigments 3 and Analog Lab V. It contains 50 vintage and nostalgic patches derived from the 80s era in 4 categories:
10 Bass presets
10 Dream Pad presets
15 Outrun Keys
15 Outrun Melodies (Leads)
Blue Pads contains 30 slow evolving synths perfect being used as pads for your productions. It was designed with the powerful Arturia Pigments 3 and it is also available for Analog Lab V users. It is the first soundbank of our new series 5€ Libraries
Outrun Time Vol.2 is a Synthwave library for Arturia Pigments 3 and Analog Lab V. It contains 65 vintage and nostalgic patches derived from the 80s era. This soundbank is full of atmospheric, evolving and emotional sounds created with the wavetable and analog engine of Pigments 3 continuing what was started with the previous Outrun Time soundbank.
New Omnisphere 2 library and a 40 presets freebie Serum soundset
Hybrid Symphonic library for Spectrasonics Omnisphere 2 contains 100 orchestral based patches. A vast variety of cinematic sounds are creating a multidimensional sonic palette for your productions.
Link:https://www.viciousantelope.com/product ... -symphonic
Intro price 9,99€ until October 8th (Norm.19,99€)
Presets walkthrough https://youtu.be/i-wNL26BKvk
