daddy
Members who have 100 or more posts under their belt can apply to the Moderator Team requesting membership of this forum. We will add you to the members and you will then be free to post here to promote your own music, recording activities, releases and gigs, etc.
daddy
Post by awjoe »
I tried some new stuff with this one - split screen, different color adjustment on the video, newish mixing tweaks. How'd I do?
Tjarko Busink on bass. He's good.
https://youtu.be/ZVFIB_0dypI
awjoe
Posts: 5251 Joined: Tue Mar 08, 2011 12:00 am
"Don't try to teach a pig to sing - it doesn't work, and it irritates the pig.'
Re: daddy
Listening now. Enjoying the bass part but, if I may, I'm less keen on the bass sound. It's a bit honky for me and competing a little with the guitar and voice.
Posts: 28016 Joined: Sun Jul 05, 2015 12:00 am Location: York
Re: daddy
Enjoyed this overall, but agree the bass part as it stands isn't a good fit. Volume-wise it's rather overpowering and not a pleasant tone, especially when he goes up the scale.
Posts: 19868 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: daddy
Post by awjoe »
Thanks. I continue to struggle with mixing. Sime day I'll it right, if only by accident.
awjoe
Re: daddy
I think we've discussed our differences about the bottom octave before if I remember rightly?
But in a stripped back arrangement like this I think you can definitely let the bass loose a bit in the low end.
Re: daddy
Post by awjoe »
I'll do it again.
awjoe
Re: daddy
Post by awjoe »
blinddrew wrote: Wed Jun 29, 2022 4:53 pm I think we've discussed our differences about the bottom octave before if I remember rightly?
Okay, I changed it. Now I've got two mixes for this one. Can I ask what you listened to this one on? - tinies, or studio monitors or headphones?
awjoe
Re: daddy
Studio monitors if I recall correctly.
Re: daddy
Post by awjoe »
I can hear the difference you're talking about, so you're right. :thumbup:
awjoe
Re: daddy
I like the song very much, that was a proper foot-tapper! :clap:
Posts: 9590 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Re: daddy
Post by awjoe »
I'm glad the pleasure reached as far as your toes. I'm glad I'm overdubbing stuff these days - I think it presents the tune both more pleasantly and more completely.
awjoe
Re: daddy
Post by awjoe »
Okay, I hear the difference you're talking about, but only just. I switch between a rolloff of 40 and 70 Hz on the bass, and what I hear is mininal. Clear, but mininal. You're still right about the last bit.
awjoe
Re: daddy
Out of curiousity, what are you using for your references?
Re: daddy
Post by awjoe »
I forget what I used for that one, but for most of my stuff, I trawl through the usual culprits - a Dylan and a Nick Drake for my end stops, a Richard Thompson to aim at, an Aldous Harding just to see, stuff like that.
awjoe
Re: daddy
It's worth bearing in mind then that things like Dylan and Drake are likely to have been mixed with a lot less of that bottom octave than modern equivalents. So if that's what you're aiming for, you're there, but it's also why people like me are suggesting that there's more space available to exploit down there.
If that makes sense.
Re: daddy
Post by awjoe »
A lot more space down there to exploit for what?
Okay, let's open this can of worms. You've been suggesting less bottom end in this mix would benefit it, right? I think you're right. I would add a 'however', however. The 'however' has different parts. The first is that shifting the rolloff on the bass track from 40 Hz to 70 Hz (12 dB per octave) produced a subtle difference to my ears. I preferred the new sound, but it wasn't huge. The second is that, where bass is often mixed politely down in the mix, I really like the sound of bass and want it to be heard. The third is that, on another site I posted this tune on, nobody responded to my question about whether there was too much low end in the affirmative. The fourth is that there's a very good chance that my ears simply aren't hearing stuff that other ears can hear.
Okay, taking all of this together, I'm concluding that the problem isn't glaring, but still I'm going to employ a lighter touch in future. What's your take on it?
awjoe
Re: daddy
My take on it is that it's 99% preference, personally I like a lot of really low end so take it with a pinch of salt.
Re: daddy
Post by awjoe »
Ah, we worked that one out, then. it's the sound you're not keen on, not the amount of low end. Got it.
awjoe
