Alphatrack & windows 10
Post by Scouser »
I have an old Alphatrack and gave up some time back trying to install it with windows 8 or 9 whatever is was a while back and had no joy.
I now have windows 10 and still no joy, trying to get it to work with cubase 11. Is this something worth pursuing, or would I be better off cutting my losses and going for something like the X touch one ? Is that a better controller than the Alphatrack
Scouser
Posts: 801 Joined: Mon Oct 04, 2004 12:00 am
Re: Alphatrack & windows 10
I had my AlphaTrack working on Win 7/8/10 with all Cubase versions - no problem. You have to force the drivers to load (it used to require running in compatibility mode) and place the correct supporting file for Cubase to pick it up - then it just works by selecting it as remote in Cubase.
I no longer have my AlphaTrack, but I use one at 'the other place' and my friend also still runs his under Win11/Cubase 12, so it definitely works. If you're still struggling I'll check where the Cubase file needs to go, as that's the part most people forget.
Posts: 21007 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
I have one working happily with Reaper in Windows 10 although I think the driver needs to be installed in compatibility mode and I use a third party plug-in with Reaper rather than the one included with Reaper.
Posts: 15849 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Aled Hughes »
James Perrett wrote: Sun Jul 03, 2022 10:52 pm I have one working happily with Reaper in Windows 10 although I think the driver needs to be installed in compatibility mode and I use a third party plug-in with Reaper rather than the one included with Reaper.
Same here. Working happily under Windows 11.
Aled Hughes
Posts: 2027 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Post by Scouser »
Obviously me then.
Any install advice ?
Scouser
Install the AT driver using compatibility mode.
Then...
Make sure you put this file:
AlphaTrackCN64.dll
into:
C:\Program Files\Steinberg\Cubase xx\Components
That should be it. Go into Cubase and create the remote.
