guitar string corrosion - any experts out there?
Post by heavenorlasvegas »
I know there are alot of varying theories out there...
but how does corrosion develop as it relates to steel and nickel wound strings?
There are many different "types" of corroded strings. Those that have turned sticky and almost have a sandpaper like feel to them, strings that have went black, and strings that are simply blotched red with rust.
what kind of conditions, for example would cause a string to turn black as opposed to developing a sandpaper like feel?
heavenorlasvegas
Posts: 154 Joined: Mon Feb 22, 2021 2:41 pm
Re: guitar string corrosion - any experts out there?
Is this about a problem you experience and hope to resolve?
Or is this purely an academic question?
In over 45 years of playing I have never experienced corrosion of strings. And in over 30 years as a trained luthier and very experienced tech I struggle to recall clients who had a problem with string corrosion.
I did have one client who had a problem with strings going off within days of being fitted. His acoustic guitar had a brace that had come unglued and was a simple repair.
For the vast majority of guitarists, it's not a problem. For the small minority that do have a problem, they just buy coated strings, Maxima gold plated strings, or just bulk buy standard strings and change them more often.
And as for all those 'varying' theories you imply....
Almost all can be disregarded because they are ill informed opinion from people who are unqualified to comment.
Posts: 13021 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Post by resistorman »
From personal and anecdotal experience, I've known people that have unusually acidic sweat whose very touch started strings corroding, though I don't remember what color the corrosion took. Also, I lived on a small tropical island where everything corroded. I rotted two bridges off my 66 Jazz bass playing downtown Key West for decades. Since I moved to the mountains of North Carolina, corrosion doesn't even budge the trouble meter.
resistorman
Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by Bob Bickerton »
Reminds me of a phone call I had from an acquaintance a few years back. He asked if he should change his guitar strings. I asked when did he last change them and he replied 1969.
I said probably.
Bob Bickerton
Posts: 5419 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Plain steel strings will rust over time. The higher the relative humidity of the air, the faster they’ll rust.
Wound strings will pick up dirt, grease and bits of dead skin in the wraps, probably the primary reason why strings get duller as they age.
But the big variants in string corrosion are the player’s skin/sweat acidity and air pollution. Some people’s fingers have a near neutral pH and their strings can last ages. Others are so acidic that I’ve seen an almost new set of strings go black in places and feel rough with an hour of playing. That’s quite unusual, but you do get some people like that (Dan Boland, you know who you are).
The more built-up your environment, the more pollution there is in the air. Sweat and grease from your fingers will start attacking the strings as you play, but it generally does take quite some time. The act of playing will rub off some of the surface corrosion, so most generally happens after you stop playing. You then get a mixture of finger acid, pollutants such as NOx and SOx (from car exhausts) mixing with moisture in the air, and plain old damp conditions, that can eat away at the strings over time.
Far too many combinations to state what conditions will give exactly what type of corrosion you’ll see on a string. There are various types of iron oxide and different starting conditions will give different end results.
Washing your hands before playing and wiping the strings down after playing should give the longest string life for uncoated strings, but the same make of strings may last a week for one player and several months for another.
So really it’s the standard SOS forum answer; “It depends”.
Posts: 18299 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Bob Bickerton wrote: Thu Jul 21, 2022 3:56 am Reminds me of a phone call I had from an acquaintance a few years back. He asked if he should change his guitar strings. I asked when did he last change them and he replied 1969.
I said probably.
Post by BigRedX »
The only time I have witnessed corrosion on guitar or bass strings, were ones that were VERY old, or on instruments that had been played by someone with acidic sweat. I used to be in a band someone like this and he would change his strings every week, and ideally he should have changed them after every gig or rehearsal but he couldn't afford that.
BigRedX
Posts: 2810 Joined: Fri Sep 03, 2004 12:00 am
Post by Dow Fereday »
Hi
not an experty but....living near the sea gets my strings rusting...
keep hands clean and wipe down strings after use, put in case with silica
wd40 may extend the life....
Dow Fereday
Posts: 9 Joined: Tue Jan 22, 2002 12:00 am Location: Wales UK
Post by Scouser »
I can't see the value in knowing more about this, but that's just me.
Having played guitar for 45 years, many of those professionally, in my own experience it is moisture and grime, oils and salt, transferred from hands/fingers to the strings. Obviously we are all different and how much we sweat etc varies from person to person. I would suggest using uncoated strings as a first step and just keeping them clean as possible, however they should be changed way before they become as you describe.
Scouser
Posts: 805 Joined: Mon Oct 04, 2004 12:00 am
Post by Dan Bo »
Wonks wrote: Thu Jul 21, 2022 6:19 am Plain steel strings will rust over time. The higher the relative humidity of the air, the faster they’ll rust.
Yeah, my hands eat strings. Wonks lets me touch his guitars but Max just flat out bans me from touching any of his (unless the strings need to be changed by his standards). It literally takes me minutes to ruin a set of strings, so I have to have a different standard as to what is acceptable. I also don't really like coated strings so its a case of changing them more often for me.
My case is extremely acidic sweat and sweaty hands and its always been the case. On my 18th birthday my parents bought me a silver signet ring, it turned black after a few weeks and after about a month the band had corroded enough that it snapped. My wedding ring is Palladium so it suffer the same fate.
Its getting a little better with age and living in a cooler country but I've just learnt to deal with.
Dan Bo
Posts: 298 Joined: Fri Jul 20, 2007 12:00 am Location: Arbroath
English (legal) immigrant, living in Scotland, coz it pleases the wife.
Dan Bo wrote: Sat Aug 13, 2022 9:56 am Yeah, my hands eat strings. Wonks lets me touch his guitars but Max just flat out bans me from touching any of his (unless the strings need to be changed by his standards). It literally takes me minutes to ruin a set of strings, so I have to have a different standard as to what is acceptable. I also don't really like coated strings so its a case of changing them more often for me.
But you are very useful if anyone needs any hardware reliced!
Wonks wrote: Sat Aug 13, 2022 10:11 am But you are very useful if anyone needs any hardware reliced!
I generally prefer my hardware louse-free. ;)
Posts: 28059 Joined: Sun Jul 05, 2015 12:00 am Location: York
blinddrew wrote: Sat Aug 13, 2022 10:15 am
You're so crabby today!
I thought you might step up to the plate Wonks, but I must confess I was expecting a 'software bug' retort. :clap:
When i was playing guitar and bass I never had a problem with string corrosion.
I did however have a problem with wristwatch straps (remember them?) The leather would rot and fall apart in under 6 months.
String rot is however a 'problem' of the lazy 21st century! Before the discovery of stainless steel and Aluminium you had to TAKE CARE of steel objects!
A knife or a gun had to be dried off and wiped down with an oily rag. Firearms especially, if they got wet had to be stripped and carefully dried and oiled. This of course applied to tools of all kinds.
Anyone with this string problem I suggest should place a piece of card under the strings to protect the fretboard and wipe the strings with a rag with the MEREST trace of WD-40 on it. Alternatively gunshops can sell you a cloth impregnated with silicone oil.
Posts: 18109 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
ef37a wrote: Sat Aug 13, 2022 12:57 pm String rot is however a 'problem' of the lazy 21st century! Before the discovery of stainless steel and Aluminium you had to TAKE CARE of steel objects!
Being as stainless steel was invented in 1913 I think the 20th century can take a bit of blame here too. ;)
blinddrew wrote: Sat Aug 13, 2022 1:04 pm
Well yes but Harry Brearley found the alloy by accident in 1913. He was actually trying to find a better material for gun barrels. It took quite a long time before SS became as common as it is today for everyday stuff such as cutlery. For highly stressed parts such as gun receivers it was well after WWll before a strong enough stainless alloy was produced, at least for civilian arms.
Even today I doubt there are many stainless Purdeys!
Much the same is the case with Aluminium, took a long time before it was cheap enough to be common.
Post by Dan Bo »
Its the nickel coating that my hands dispatch 1st and this is not due to string care. It happens whilst playing not because my sweat is left on it afterward.
I wipe down my strings (individually) after every playing session but I'd like to look into using something that would neutralise any acidic sweat left on (crevices of wound strings).
Non nickel plated strings don't do it for me really, sound wise. So an all steel string is out.
Dan Bo
Try using a weak baking soda solution - it's alkaline so will neutralise acids.
Posts: 19879 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by GCKelloch »
Folderol wrote: Sun Aug 14, 2022 10:59 am Try using a weak baking soda solution - it's alkaline so will neutralise acids.
That's an interesting idea, but it is a type of salt. That could increase corrosion as well. Otherwise, you could try mixing it with thinned mineral oil.
GCKelloch
Posts: 33 Joined: Fri Jul 23, 2021 6:58 am
GCKelloch wrote: Tue Aug 16, 2022 5:11 pm
Then try a very weak solution of Sodium hypochlorate, house hold bleach, about a desert spoon to 1/2ltr. That is definitely alkaline and then wash off with deionized water then oil of choice.
Post by merlyn »
This is all getting a bit icky/sticky/gooey/soggy. :D I play the guitar and I'm mostly trying to get stuff off my strings, not putting it on.
Two main approaches : (1) stop stuff getting on in the first place. (2) get stuff off.
One result of lockdown was that washing my hands all the time seemed to make my strings last longer. Now I wash my hands before playing, and my strings are lasting well. That's approach (1).
For the second approach wiping strings down with a cloth is a low-tech solution. Wipe the top and bottom of strings by looping the cloth around strings one at a time. If you're in a hurry there's 'snapping'. This is pulling a string out over the fretboard and letting go. It whacks off the fretboard and hopefully dislodges stuff. (You may have to do it more than once.)
merlyn
Posts: 1545 Joined: Thu Nov 07, 2019 2:15 am
