New mix for opinions.. please 😊
Re: New mix for opinions.. please 😊
It's nice, but probably not necessary.
As Martin says, it does distil and speed up the process a little, but you already have all the tools you need in the standard Cubase plugins.
Posts: 28055 Joined: Sun Jul 05, 2015 12:00 am
Hippie162 wrote: ↑Mon Aug 01, 2022 4:47 pmJames Perrett wrote: ↑Sun Jul 31, 2022 2:51 pm Here's a very quick attempt at bringing the vocals up and compressing them with a soft knee compressor ...
I can see what you mean they sound so much clearer. Did you add a reverb, sounds really lush?
No, that's just a side effect of the compression which is both bringing out the quieter syllables and also the reverb you've used on the vocals (Music Rebalance includes the vocal effects as well as the vocals themselves on the separated vocal track).
Posts: 15869 Joined: Mon Sep 10, 2001 12:00 am
Lots of good ideas in there (though what's with the barking dog?)
Now, play it to someone who hasn't heard it before. Ask them to write the words down. If there's anything they're not sure about after hearing it twice (which for me is the few words after 'I feel you tremble' and then, I'm afraid, much of the chorus) you need to do something about it.
But I think we've reached the limit of what can be 'fixed in the mix'. Re-record the vocals.
- Exalted Wombat
Longtime Poster - Posts: 5837 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Exalted Wombat wrote: ↑Tue Aug 02, 2022 1:37 am Lots of good ideas in there (though what's with the barking dog?)
I still want to try to fix it. I think i just need to level it up and sort the volume.
Cubase Pro 11 user: Trying to improve my production and mixing skills!
Well, it sounds like a barking dog!
OK, I won't go on about it after this reply!
But do remember, you KNOW what the words are. A lot of the problems aren't level or e.q., you just aren't pronouncing the words clearly.
- Exalted Wombat
Exalted Wombat wrote: ↑Tue Aug 02, 2022 11:08 am Well, it sounds like a barking dog!
Ok... (not a dog)
Hi again,
I had a zoom session with Drew earlier who unwound the wonders of parallel compression for me
I have added this to the vocal, tried to level out the parts and then bussed it to try and get consistent levels and boosted them a bit.
I needed to add some automation on the chorus as it was still a bit much on that high note, I checked the EQ and boosted slightly at just over 200hz to try and add a bit of chest voice to level the vocal out.
https://soundcloud.com/user-410433233-5 ... al_sharing
I reckon you can go harder with the parallel compression there.
I agree, but unlike so many vocals, I also suspect that your 'esses' are rather subdued, so if you're deliberately doing anything to suppress them, dial it back a bit so that you get a little more 'spit' in your delivery, which could help the clarity of words.
On the other hand, more parallel compression might just help with this aspect too.
Posts: 21652 Joined: Wed Jan 13, 2010 8:44 am
Returning a favor here: vocals start getting loud for me around 1:00 (and similar); and I am the guy with notoriously loud vocal recordings (according to many others)! The singer is good. The song is pleasant. Some elements of the song are somewhat repetitive. Nice overall.
- Guest
Hi guys
Thanks you all so much for all the feedback, I do feel my mixing is improving all the time thanks to you lovely lot.
I sent the track to Elf to fix the mix and master for me and I'm delighted with the results:
Wow - wonderful end result!
Well done to both Kirsty and The Elf.
Cooking with gas!
