Exalted Wombat wrote: ↑Tue Aug 02, 2022 1:37 am
Lots of good ideas in there (though what's with the barking dog?)
Now, play it to someone who hasn't heard it before. Ask them to write the words down. If there's anything they're not sure about after hearing it twice (which for me is the few words after 'I feel you tremble' and then, I'm afraid, much of the chorus) you need to do something about it.
But I think we've reached the limit of what can be 'fixed in the mix'. Re-record the vocals.
It's not a barking dog it's a vocal chop
I still want to try to fix it. I think i just need to level it up and sort the volume.
Posts:5815Joined: Sat Feb 06, 2010 12:00 amLocation: London UK
I had a zoom session with Drew earlier who unwound the wonders of parallel compression for me
I have added this to the vocal, tried to level out the parts and then bussed it to try and get consistent levels and boosted them a bit.
I needed to add some automation on the chorus as it was still a bit much on that high note, I checked the EQ and boosted slightly at just over 200hz to try and add a bit of chest voice to level the vocal out.
blinddrew wrote: ↑Thu Aug 04, 2022 8:09 pm
I reckon you can go harder with the parallel compression there.
I agree, but unlike so many vocals, I also suspect that your 'esses' are rather subdued, so if you're deliberately doing anything to suppress them, dial it back a bit so that you get a little more 'spit' in your delivery, which could help the clarity of words.
On the other hand, more parallel compression might just help with this aspect too.
Returning a favor here: vocals start getting loud for me around 1:00 (and similar); and I am the guy with notoriously loud vocal recordings (according to many others)! The singer is good. The song is pleasant. Some elements of the song are somewhat repetitive. Nice overall.
Maybe a little too high on 4 6 khz
I think the voice needs compression to stop those increases in volume and make it more homogeneous, sometimes they sound too loud
