Nice. How about a tad less volume in the accordion/concertina/harmonium during the quiet opening? It's a question as much as a suggestion.
Pretty easy in the ears.
A Place To Lie In
Re: A Place To Lie In
Ah, you see there's a plan for that. This is now going to be part of an EP and the previous track will bleed directly into this one, so I will need to do some level balancing when I get to mastering. So I'll look at that at the time, thank you.
Here's an (unfinished) sneak preview of the track that will lead into it: https://soundcloud.com/blinddrew/the-no ... Hi7xHHm5eJ
Posts: 28013 Joined: Sun Jul 05, 2015 12:00 am
blinddrew wrote: ↑Wed Aug 10, 2022 8:05 pm Lightly updated version: https://soundcloud.com/blinddrew/a-plac ... Py3Lz7ZewT
Yes (with a slight reservation).
The drone becomes too in-yer-face. Having established it's presence I would be inclined to fade it down quite a bit, so it almost disappears in the louder parts of the rest, which will then make it show up more and remind you of it it the quieter parts.
Just my 2d.
- Folderol
Jedi Poster -
Posts: 19864 Joined: Sat Nov 15, 2008 12:00 am
That's lovely Drew - I'm so glad you haven't added drums!
I'd agree with Will that dropping or cutting out the drone in some places would make it more effective when it is there.
Noted, thanks folks, I shall add that to the snagging list.
My last comment seems to have vanished, but anyway, I concurred with the comment about the 'drone' and it being a tad too intrusive - but I'd miss it if it weren't there.
For some reason this track takes me back to The Incredible String Band, quirky but observant, sounds good
No, I'm just talking mixing at this stage.
[/quote]
The Norwegian sounds good through the Avantone as well as the monitors. I thought the vocal would come back in at 2.45, but no - you left it later. Nice tune, Drew.
"Don't try to teach a pig to sing - it doesn't work, and it irritates the pig.'
The thing that people are calling a drone sounds a better level tonight. Did you change it? Can one even do that on Soundcloud? Can you leave the uploaded submission where it is, but replace the sound file for that submission? That would be useful. But if you didn't change the mix, then I'd like to retract my previous question about drone level.
So, did you change it?
awjoe wrote: ↑Fri Aug 12, 2022 2:29 am The thing that people are calling a drone sounds a better level tonight. Did you change it? Can one even do that on Soundcloud? Can you leave the uploaded submission where it is, but replace the sound file for that submission? That would be useful. But if you didn't change the mix, then I'd like to retract my previous question about drone level.
A) nope, not changed.
B) if you've got the pro version of soundcloud then you can replace the audio on a track without loosing any of the other stuff. But not on the freebie version.
The drone is actually the same part at the chords (it's a reed organ) but I think I should be able to automate the fundamental fairly easily with an EQ notch.
I love this. Not anything that I would ever listen to normally but its ace, think the mix stands up really well.
The only slight tweak I would make is that when the Leslie'd Hammond comes in there's a bit of a fight going on in the middle of the stereo image at 2-3K (ish) feels like you've pushed the level of the Hammond up to try and 'win' the fight but I reckon that makes it a bit too loud, is there any sort of of opposite eq you can do between Hammond and the bed parts and maybe pan the 2 away from each other just for that bit?
Might make it sit better, and be less of a punch in the face when it comes in.
Only a thought, its cool though mate, really cool.
Now that you mention it Jaminem, that had been bugging me a bit as well.
It is sooooo useful to have all these extra sets of trained ears available!
Thanks for your general comments as well.
And likewise thank you Oneworld, sorry I missed your comment earlier. Always happy to be compared to The Incredible String Band.
