Turn on speakers from external switch
Re: Turn on speakers from external switch
With it being a relay, would a regular RCD serve the same purpose - apart from the remote access?
- shufflebeat
Longtime Poster - Posts: 9108 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
shufflebeat wrote: ↑Fri Aug 05, 2022 10:03 am With it being a relay, would a regular RCD serve the same purpose - apart from the remote access?
Well, you CAN trip an RCD remotely but it would be naughty to tell the world how!
There are different format RCDs. I was thinking this would be more along the DIN-rail mounted types and do have an on/off switch, rather than the in-line plug type. I wouldn't recommend the latter for regular switching on and off.
e.g. https://www.wentvaleelectricalltd.co.uk ... 7877-p.asp
Lizardpoint wrote: ↑Wed Aug 03, 2022 11:35 pm Get yourself a Furman power sequencer.
Plug all your gear into the delay 1 & 2 output connectors and your power amps into the delay 3 output connectors.
Then when you power on, all your toys come on first, finally your monitors.
When you power off, your monitors go off first then the rest of your toys.
It works for me
Cheers
Dave
I do likewise with my core gear, except I use a Studiospares Trojan 348010 AC Power Sequencer which offers six 13A rear sockets. Not sure if they still make/sell these?
- Forum Admin
Posts: 4292 Joined: Mon Jul 21, 2003 11:00 pm
Don't think that's available any more. Studiospares do sell the Furman power sequencer, though for about £500... except it's currently on back order.
https://www.studiospares.com/cables-lea ... 470800.htm
Posts: 39102 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Fri Aug 05, 2022 1:08 pm Don't think that's available any more. Studiospares do sell the Furman power sequencer, though for about £500... except it's currently on back order.
And the Furman model offers 9 power connections, compared to the Studiospares (no longer sold) model I use which has a mere 6.
- Forum Admin
Hugh, in the September 2021 Q&As you mentioned an Energenie 8 way wireless strip.
I would guess that would last more than 2 years but even if not, half a bag buys a lot of backups!
- Exalted Wombat
Longtime Poster - Posts: 5815 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Exalted Wombat wrote: ↑Fri Aug 05, 2022 4:21 pm
Why? It exactly emulates what we all think the problem is.
No it doesn't. The switch is designed to be able to handle arcing. The plug pins are not, and will develop pits and poor contact. I wouldn't attempt this once, even just 'to see if it's OK'. Also I have seen the result of this sort of damage. It was in a relatively safe environment. I wouldn't like to see the same in someone's home.
- Folderol
Jedi Poster -
Posts: 18288 Joined: Sat Nov 15, 2008 12:00 am
OK, then compare the 'pop' from using the switch on the "extension power cord that has switches" with that from using the switch at the wall socket.
- Exalted Wombat
