Why is only one USB audio path allowed?
This is no doubt an uninformed (aka stupid) question, but why is only one USB audio path available at one time? I have several synths and a mixer with USB audio outputs but I cannot combine them in my Windows PC. I have to choose which one to use. Clearly, this is not like an SP/DIF digital audio stream. Perhaps someone could explain...
- This Wreckage
Poster - Posts: 14 Joined: Mon Jul 04, 2022 8:19 am
Re: Why is only one USB audio path allowed?
It's because, under Windows, each USB audio connection requires its own driver and there is no facility to synchronise the digital audio sample rates coming from multiple sources through multiple drivers.
Posts: 35511 Joined: Fri Jul 25, 2003 12:00 am
Isn't it technically an ASIO thing rather than a Windows thing?
- This Wreckage
Probably not the answer you want to hear but on the Mac it's built-in at system level:
Create an Aggregate Device to combine multiple audio interfaces
RockinRollin' VampireMan
It's a handy feature.... but I wonder if anyone has done any performance testing on the 'drift correction' function which is a software asynchronous sample rate converter?
A partial solution might be to use Asio4all to combine the usb inputs.
I say "partial" because I've got it working here on Reaper with a Fender Mustang amplifer (usb output) and a Focusrite audio interface but it seems a bit flaky, with excessive latency and little control of where the audio output goes. However, I can successfully record via both devices at the same time. If you just wanted to record, and monitor using the speakers in the synth, it might be OK.
Learning from the experts on this forum
Even with a Mac, it's probably better for Ye to use an AI with a lot of I/O
- resistorman
Frequent Poster (Level2) - Posts: 2241 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
This Wreckage wrote: ↑Thu Aug 11, 2022 11:36 am
If a solution were to be found, who would provide it? Microsoft? Does Apple architecture allow multiple USB audio streams?
YAMAHA [as in YAMAHA Steinberg ASIO driver]
I believe Apple handles multiple AI because devices are USB class compliant and dont need drivers.
Windows can handle multiple drivers if they are different but it cant handle multiple asio driver instances.
So for instance, I cant use Yamaha USB synth outputs at the same time as a Yamaha guitar amp or Yamaha audio interface.
Is this a nail in the coffin of USB microphones ?
In a multitracking scenario, I would only be using 1 device at a time and would be happy to press a hot key to select which driver is in use i.e. which driver is the timing master.
It's a distinct disadvantage
- resistorman
