Using Saturation
Re: Using Saturation
I'm with Wonks, I've always thought of it as 'tape saturation'. Probably because, until your post above, I've never understood what transformer saturation actually was.
Posts: 28041 Joined: Sun Jul 05, 2015 12:00 am Location: York
blinddrew wrote: Mon Aug 15, 2022 10:34 am I'm with Wonks, I've always thought of it as 'tape saturation'. Probably because, until your post above, I've never understood what transformer saturation actually was.
Few do. "They" don't even really mean "saturation" on tape, really somewhere around 4-6% THD I would guess. Most machines were lined up for ~3% THD at +4dBu but then we would have to delve into the history of tape flux levels!
Actually saturating a tape would sound 'king awful!
Ooo! Have a look at "saturable reactors".
Posts: 18103 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by merlyn »
If we think how this would be done in DSP ...
We need a non-linear function. Inverse tan would do it :
The saturation is that at a certain point increasing the input doesn't increase the output.
merlyn
Posts: 1539 Joined: Thu Nov 07, 2019 2:15 am
merlyn wrote: Mon Aug 15, 2022 12:08 pm If we think how this would be done in DSP ...
That looks very like a flux v magnetizing force curve.
Here's a typical B-H curve showing how a magnetic material behaves under different field strengths.
If we are talking about tape then there are all kinds of other effects involved - notably bias levels. Under-biasing can produce some interesting distortion effects.
(Diagram taken from https://www.electronics-tutorials.ws/el ... resis.html)
Posts: 15859 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
ef37a wrote: Mon Aug 15, 2022 8:51 am ...to mean a mild form of distortion when in fact, electronically it is the most extreme form of distortion you can get.
That's clipping, surely?
Many engineering terms have become corrupted in popular usage.
To most, 'saturation' means a benign and moderate level of musical distortion, well below that introduced by more severe forms of distortion like clipping or A-D overload.
Posts: 42172 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Mon Aug 15, 2022 12:42 pm
Yes, same thing because the transformer/valve/transistor/tape cannot supply any more signal.
ef37a wrote: Mon Aug 15, 2022 8:51 am But, like "rms" bloody watts I suppose I shall just have to live with the term!
I still chuckle at a loudspeaker review I read many years ago in a 'hi-fi' magazine, that referred to its power rating in Watts WFT.
When asked to elaborate on this unfamiliar term, the reviewer replied that it stood for 'WishFul Thinking' :lol:
Posts: 21642 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Guest »
More like WTF.
Guest
As an effect, tape and transformer saturation are very similar. Fundamentally it's the same magnetic behaviour, although the tape curve is 'fatter'.
You can also get a very approximate saturation effect with two germanium diodes back-to-back fed via a fairly high value resistor - although there is no hysteresis at all of course, so it's never going to be quite right.
Posts: 19871 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Folderol wrote: Tue Aug 16, 2022 10:05 pm You can also get a very approximate saturation effect with two germanium diodes back-to-back fed via a fairly high value resistor
Ah, the components so beloved by electric guitarists everywhere (it sounds so much more natural then silicon diode clipping ;) )
Post by Sam Inglis »
To return to the OP for a moment, typically I'd only apply noticeable levels of distortion or saturation to electronic instruments such as synths and drum machines, the occasional weedy-sounding bass drum, and hand percussion such as shakers and tambourines. Distorted vocals have become a bit of a cliché to my mind. When I do use saturation I'll usually also roll off a lot of top end to stop something becoming too harsh (especially on a tambourine).
I often use a clean tape emulator on the master bus, but I think of that as a form of compression and tone shaping rather than saturation really.
Sam Inglis
Posts: 3162 Joined: Fri Dec 15, 2000 12:00 am
Post by tea for two »
I look at saturation as how much I want to dunk my biscuit in tea.
tea for two
Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
