Using Saturation
Re: Using Saturation
More like WTF.
- Guest
As an effect, tape and transformer saturation are very similar. Fundamentally it's the same magnetic behaviour, although the tape curve is 'fatter'.
You can also get a very approximate saturation effect with two germanium diodes back-to-back fed via a fairly high value resistor - although there is no hysteresis at all of course, so it's never going to be quite right.
- Folderol
Jedi Poster -
Posts: 18275 Joined: Sat Nov 15, 2008 12:00 am
Posts: 20657 Joined: Wed Jan 13, 2010 8:44 am
To return to the OP for a moment, typically I'd only apply noticeable levels of distortion or saturation to electronic instruments such as synths and drum machines, the occasional weedy-sounding bass drum, and hand percussion such as shakers and tambourines. Distorted vocals have become a bit of a cliché to my mind. When I do use saturation I'll usually also roll off a lot of top end to stop something becoming too harsh (especially on a tambourine).
I often use a clean tape emulator on the master bus, but I think of that as a form of compression and tone shaping rather than saturation really.
- Sam Inglis
Moderator - Posts: 3042 Joined: Fri Dec 15, 2000 12:00 am
I look at saturation as how much I want to dunk my biscuit in tea.
- tea for two
Frequent Poster - Posts: 3467 Joined: Sun Mar 24, 2002 12:00 am
