Vox VT100 amp
Vox VT100 amp
Post by GRAHAM99 »
My pal has one of these.It plays ok for a few minutes and then looses a lot of volume.
It will then go back to being ok and so on.
I have had a look inside but cannot see anything obvious.
Anyone had the same issue?
GRAHAM99
Posts: 281 Joined: Fri Nov 15, 2002 12:00 am
Re: Vox VT100 amp
Try giving the valve a wiggle in it's base - may be just a poor contact.
Posts: 19868 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Vox VT100 amp
Bad solder joint or a dodgy pot are also likely candidates.
Can we presume they’ve tried another guitar and lead to rule those out and confirmed it’s an amp issue?
Posts: 18266 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Re: Vox VT100 amp
Post by GRAHAM99 »
Yep tried another lead and guitar.
Will have another careful poke around inside.
GRAHAM99
Re: Vox VT100 amp
If you need to poke around where there are unknown voltages, the only thing I'd suggest would be a plastic knitting needle.
The other hand in your pocket.
Re: Vox VT100 amp
The single valve in the amp, an 12AX7, is fed from +51v and -51v DC PSU rails, so whilst not as bad as an all-valve amp, it’s in that just not-quite safe area for working on live unless you really know what you are doing. But leaving it off for a couple of hours before opening it up should allow the capacitors to discharge to a safe level.
I’d first be checking for cracks in the solder around the volume control and input jacks.
Re: Vox VT100 amp
Yes, as Wonks says be careful. A valve amp fading down and up is almost always a problem in the heater supply.
MIGHT be the valve but I doubt it.
Posts: 18096 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Re: Vox VT100 amp
The valve heater voltage should be the standard 6.3v AC, (each side of the transformer output is connected to ground through a 1W 100 ohm resistor). But the heater takes a reasonable current, so that can be an issue if PCB tracks are undersized or the inter-board connectors don’t connect well.
It’s almost all a DSP amp, with just that single valve in the circuit between the digital pre-amp and the power amp.
All the front panel controls look like they feed directly into the DSP processor with the exception of the master volume control.
There’s also a series effect loop, and if unused, corrosion on those switched connectors in the jack sockets doesn’t get wiped off and the signal can become dodgy. So always good to occasionally spray some switch cleaner in those and push a jack in each one a few times.
Re: Vox VT100 amp
Post by GRAHAM99 »
Thanks for all the help on this.
I have seen a lot of criticism of the soldering on these amps so maybe that is the issue.
I used the output of the effects send into another amp and it worked ok.Also the headphones out put worked ok.
This would point to a problem in the power amp section?
GRAHAM99
Re: Vox VT100 amp
It would seem so from looking at the schematic. The line out is taken from after the valve section.
Re: Vox VT100 amp
Post by GRAHAM99 »
I couldn’t find a schematic could you put the link on here?
GRAHAM99
Re: Vox VT100 amp
Re: Vox VT100 amp
Post by GRAHAM99 »
Thank you.
GRAHAM99
Re: Vox VT100 amp
Post by jjlonbass »
That is a very odd circuit around the 12AX7. The 2 triodes are biased from a -51V supply, but the anodes' DC supply comes from the unity gain inverting op-amp circuits around IC2A and IC2B which in turn are driven from the triode anodes, IC2A by a DC blocking capacitor! I'm not sure what is going on here, but I suppose with no signal, the anode supply would be 0V.
Ah, I see that the cathodes are connected to the -51V supply via R42 and also Q3 if it is switched on. Q3 is controlled by the A/AB output of the M3803 microcontroller. So the valve bias is under the control of the micro via Q4 and Q3.
Does the fading occur in A or AB mode or both?
The power amp uses one of the Sanyo STK thick film hybrid modules, these often cause trouble - hopefully not in this case.
jjlonbass
Posts: 114 Joined: Wed Dec 19, 2018 3:52 pm Location: Ware, Hertfordshire UK
Re: Vox VT100 amp
Wonks wrote: Mon Aug 15, 2022 9:03 am It would seem so from looking at the schematic. The line out is taken from after the valve section.
By my reading of the circuit diagram the line/headphone out is taken before the valve stage. Plugging something into that socket interrupts the feed to C31 and I think the Phone_DT signal is used to mute the input to the power amp IC and also sent to the control processor.
The headphone socket could well be causing the problem.
Posts: 15852 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
