Get in fast if anyone wants one - they're rare as hen's teeth.......
Mic'ing 2 instruments to a single amp
Re: Mic'ing 2 instruments to a single amp
- Bob Bickerton
Longtime Poster -
Posts: 5092 Joined: Fri Dec 20, 2002 12:00 am
Though the main mic input’s phantom power circuit then has to power two mics and the mini mixer. Whilst a lot probably would, there will be some that can’t.
Quite so.
The combiner draws 2-4mA, leaving at most 3 or 4mA per connected mic. That's enough for many, but certainly not all. This combiner is designed for AT's Unipoint conference mics, and the ones I checked pull only 2mA.
Posts: 39072 Joined: Fri Jul 25, 2003 12:00 am
I'm using dynamics
- Bob Bickerton
Longtime Poster -
Then a transformer combiner would be fine!
That may be so if the source levels are similar, but the balance control will be essential for the particular application I have in mind
Two M201s feeding a preamp in order to route around a pedal board - one will have the equivalent of a trumpet, the other rustling leaves - yes, I know, it’ll still be a challenge!
- Bob Bickerton
Longtime Poster -
The balance control only has a +/-6dB range...
Like many balance controls, the centre position gives 6dB of attenuation of both signals in the centre position to maintain a rough overall unity gain throughout the balance control travel (assuming both input signal levels were the same). The tech info states a maximum attenuation of 33dB (but no boost), so it would seem you can't totally silence one channel.
Apologies, I misread / misunderstood the brochure.
You're quite right, it looks like the balance range is about 27dB.
