What musical instrument does this sound come from?
Post by ming8080 »
Hello, I'm trying to sequence a song (using cakewalk) to sound as close as possible to the original, but I'm stuck with a small part of the song where there's a sound that I don't know what musical instrument it came from. Basically, this part contains an electric piano and a percussion (conga I suppose). I've sequenced the piano & the conga, but there's a sound that seems to shadow (played simultaneously with) the conga that I couldn't figure out (please ignore the reverb difference, I haven't had the chance to add any FX).
Here's the link to the sounds:
Sequenced: https://drive.google.com/file/d/12gw2A3 ... sp=sharing
Original: https://drive.google.com/file/d/1vc8ISM ... sp=sharing
I've tried cuica, ocarina, conch shell, but they sound different. Any thought on this?
ming8080
Posts: 6 Joined: Sat Sep 24, 2022 10:28 am
Re: What musical instrument does this sound come from?
Post by BJG145 »
Hey ming8080, welcome to the forum.
The conch and ocarina are played by blowing, while the cuica is played with a cloth on a rosined stick. The sound here is produced by striking a resonant drum head with your fingers against it, and using pressure on the skin to vary the pitch, like a talking drum.
https://youtu.be/B4oQJZ2TEVI
Since you're going to be sequencing it rather than finding an original, perhaps you could just use a boingy drum sample with pitchbend.
(I could only hear two instruments on that clip; Rhodes and drum. Actually I think all you need to do is splash on some reverb, pitchbend that drum sample you've got a couple of semitones up and down while it plays, and you're in the ballpark.)
Posts: 7724 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Post by ming8080 »
Thanks for the suggestion, I'll give it a try :thumbup:
ming8080
Post by Jorge »
That is a conga, not a conch, talking drum, cuica, kinfuiti or other percussion or wind instrument. That particular sound is not produced by pressing on the skin or changing the tension on the skin like a talking drum. On a conga (not tuned too high) you hit an open tone while sliding your middle fingertip of the other hand across the skin. Takes a lot of practice and is easier with an old, properly cured and broken-in natural conga skin. With some skins you have to moisten your fingertip with saliva to get it to work. Most people who play congas never master that technique.
Jorge
Posts: 379 Joined: Sat Dec 13, 2003 12:00 am Location: New York, NY
Post by ming8080 »
Wow, that's a very detailed explanation :clap: Thanks for the insight. I ended up simulating the sound using a conga instrument with a reverb, not quite the same sound though :)
ming8080
