Hi all... looking for a free decent autotune download that would work with
Steinberg Sequel 3. Any suggestions? cheers.
Free Autotune download
- STEVEN PICKER
New here - Posts: 7 Joined: Sun Sep 18, 2022 6:20 pm
Re: Free Autotune download
Many years ago I used to use something called GTune (I think) although no idea if it's still around.
If you happen to be using Reaper, it's got one built-in.
- Rich Hanson
Frequent Poster (Level2) - Posts: 2982 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Rich Hanson wrote: ↑Tue Sep 27, 2022 10:02 am If you happen to be using Reaper, it's got one built-in.
And it's rather good - that's all I use for pulling the odd stray note back into line.
Posts: 19904 Joined: Wed Jan 13, 2010 8:44 am
I think Reatune is part of the Reaplugs package that you can download from the Cockos site but I'm not sure what kind of plugins Sequel handles?
If it's VST stuff then that should be an option.
Unfortunately it isn't included in Reaplugs but all of Reaper's pitch/time manipulation effects work extremely well and, as you can try Reaper for free, you could import the files that you want to tune into Reaper and then export them again after tuning them.
Posts: 12882 Joined: Mon Sep 10, 2001 12:00 am
Ah, thanks for the correction James.
Rich Hanson wrote: ↑Tue Sep 27, 2022 10:02 am Many years ago I used to use something called GTune (I think) although no idea if it's still around.
It's called GSnap, and it's still around. In fact he has a whole suite of free VSTs.
- Tomás Mulcahy
Posts: 2357 Joined: Wed Apr 25, 2001 12:00 am
