Do the five shapes of piano key have unique names?
Post by jellyjim »
Hello
There are five unique key shapes on a piano keyboard
1. The black keys
2. A white key with a black neighbour to the left only
3. A white key with a black neighbour to the right only
4. A white key with black neighbours both left and right
5. Occasionally a white key with no neighbours
Do these have unique names? I don't mean musical names. Imagine you make pianos and you're doing an inventory, "Hey Bert, we're low on the XXXX keys. Can you pick some up when you get the milk?"
Jim
jellyjim
Posts: 1747 Joined: Wed May 15, 2002 12:00 am Location: uk
Re: Do the five shapes of piano key have unique names?
1 Black keys
2 B and E
3 F and C
4 G A D
5 Ends of keyboard
That’s how I would refer to them, but there are probably more technical names in piano making circles.
Posts: 19934 Joined: Sat Jul 12, 2003 12:00 am
Dunno, but I'd refer to them as:
Black
Full White
Left White
Centre White
Right White
Posts: 19924 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Folderol wrote: Tue Sep 27, 2022 8:41 am Dunno, but I'd refer to them as:
Black
Full White
Left White
Centre White
Right White
They sound like a bunch of dodgy political groups!
:D:D:D
Post by Stickman0_3 »
Arpangel, I'd vote for them! :bouncy::bouncy::bouncy:
Stickman0_3
Posts: 279 Joined: Thu Nov 03, 2016 12:38 pm Location: Birmingham
Nono. Dodgy political groups are:
Conservative
Labour
(and some other lot who's name I forget)
Post by jellyjim »
Eh can we steer away from politics so the thread doesn't get locked?
I'm quite curious about the answer, if there is one :thumbup:
jellyjim
Post by nathanscribe »
I don't know about an actual piano, but on synths there are a couple of ways of doing it.
Some have different shapes for every white key – the spacing between the black keys is different for C-to-E than for F-to-B, so there are subtle differences in the cutouts and mounting for B than E, for example, though you can sometimes use them interchangeably if you don't mind a bit of wiggle. On these boards D, G, and A all have black keys either side, but they are all differently spaced so again are not interchangeable.
The (presumably cheaper) other method I've seen is that E/B and C/F are equally spaced and designed to be interchangeable. I've never seen one with G/A equal though.
So, in the first case, including the top key (usually C), there are 9 shapes; in the latter (presuming top C), 7.
nathanscribe
Posts: 1543 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
I suspect there are lots of answers... each builder uses their own names for the keys.
Post by Nazard »
The only exception I can think of is the Bosendorfer Imperial Grand, which has an extra 5 'white' keys, C to G, at the bass end, which are painted black. So as not to confuse the eye when playing.
Apparently it was Busoni, who made many well know Bach transcriptions, particularly the organ works, who wanted an instrument that could go down almost as far as a 16 foot organ pipe (pedal). So Bosendorfer kindly obliged him.
Nazard
Posts: 747 Joined: Sat May 15, 2010 12:00 am
Post by Tomás Mulcahy »
Go look at spare parts for pianos. I don't think they have names, just part numbers. As @nathanscribe says, each manufacturer will organise it differently. For example the Yamaha digital piano I fixed recently (It's the budget weighted action they use in loads of keyboards) all the octaves are the same so the parts list is short, but each key has a part number. Whereas on the CP80 each key has its own part number, because the mechanism varies in angle and length. That action is almost identical to what is in their concert grand pianos. Which is absolutely lovely when it's been regulated/ serviced by a trained technician :)
PS the budget Yamaha action I referred to is pretty good too. Quite a clever design extremely reliable and easy to service/ repair. But the Casio Privia surpasses it for feel IMHO.
Tomás Mulcahy
Posts: 2812 Joined: Wed Apr 25, 2001 12:00 am Location: Cork, Ireland.
Post by jellyjim »
I guess there's been enough variations as outlined above and they're otherwise easy enough to identify by note name for no unique names to have ever been coined.
Makes sense.
The reason I was asking was quite random, inconsequential really, but it piqued my curiosity.
I was writing some code for an experiment and had functions that drew each key. I was just trying to think of better names than 'drawBlackKey', 'drawWhiteKeyLeftNeighbour', 'drawWhiteKeyRightNeghbour' etc.
Although from a programming perspective they're arguably good function names as they're descriptive and require no special knowledge to be understood.
jellyjim
Post by adrian_k »
I’m pretty sure they are called Dave Dee, Dozy, Beaky, Mick, and Tich.
adrian_k
Posts: 3412 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Above all, be kind.
