SM7B suddenly sounding really tinny - only on recording ?!
Hi
My Shure SM7B (brand new approx 1 year ago) has been working fine, I haven't used it for recording for a couple of months but it hasn't moved from its mix stand and never left my home - no damage, no drops, nothing.
Went to use it to record some vocals today - sounds fine through monitoring but the actual recordings are really tinny. Using Logic on a blank project through a focusrite liquid saffire 56 - have tried:
different channels (same problem)
different leads (same problem)
different mic (SM58 - sounds fine in monitoring and recording using same channels)
different preamp (was using direct into sound card, I know the SM7B doesn't need a pre-amp but thought I would try it) same problem.
It is driving me a bit strange.. it makes no sense that it sounds fine in monitoring but the actual recording sounds so tinny. Have used empty projects to make sure there is no strange plug in hiding somewhere
Can anyone recommend what else I should try ?
edit: have just tried recording on garageband (exact same setup) - sounds normal - what the hell is wrong with Logic ?!
Please ?!
Please ?!
- Sam the Scholar
Regular - Posts: 54 Joined: Wed Jul 20, 2005 12:00 am
Re: SM7B suddenly sounding really tinny - only on recording ?!
An unexpected thin sound is often due to the signal being captured through two paths simultaneously, with a slight delay between them, which results in partial cancellation of the low frequencies.
I'd suggest you check your routing configuration as you may find the mic signal is being routed in a weird way.
Posts: 35436 Joined: Fri Jul 25, 2003 12:00 am
As Hugh says above, double check that the recording is not reaching your outputs twice!
For example, if you're using something like Sonarworks correction software or any other processing on one monitoring feed (eg headphones) and not on another (speakers perhaps), then check that both feeds are not being sent to the same place (fairly easy to do if you're using comprehensive monitoring/routing utilities like RME Totalmix or something)
Does previously recorded material play back OK with the same settings?
It can be hard to evaluate the sound of a microphone on your own voice in real-time due to the vibrations of your voice through your head etc - do you have a way of recording the mic using a different setup, or check with a different mic to try and track down where the problem is?
Aled
Aled
- Aled Hughes
Posts: 1519 Joined: Tue Oct 24, 2006 12:00 am
Thanks both.
This would make sense but I have re-wired routing (was going through a patch bay) to go direct into the sound card.
Focusrite do have an annoying routing section but nothing in this has changed and everything else works fine.
Tried the mic in garageband and it works fine.. so this is now a Logic problem but I don't know what routing to even check when I haven't made any routing changes - gah !
tried the SM58 on the same routing - works fine, just the SM7B causes this issue!
- Sam the Scholar
Have you checked the bass roll-off and presence boost switches on the SM7B?
Thanks Hugh - yes, have tried that, makes no difference.. I don't understand how one microphone can sound tinny in this way (and its really obviously tinny - like a telephone plug-in) on this input path (as other ones work fine on the same path)
Is this more likely a Logic issue (as related to the fact it sounds fine in monitoring, only on playback does it sound tinny) ?
- Sam the Scholar
I have now managed to use the mic with another interface, on another laptop (on garageband)- same issue, really tinny on playback.
Must be a mic deficit ?
I can't think of any other routing to test it
- Sam the Scholar
Sam the Scholar wrote: ↑Thu Sep 29, 2022 7:25 pm I have now managed to use the mic with another interface, on another laptop (on garageband)- same issue, really tinny on playback.
You said the mic sounds fine monitoring when recording. Is that still the case?
Does the audio waveform look as strong as the other mics? You should see a clear difference in intensity if the mic is faulty and the recording is "thin".
If you save a recording as a file and play it back on a known-good system does it sound tinny?
It might be helpful to record a test track, then export it and play it via different audio player to see if the problem is in the recording or the playback processes.
My guess is still on a sneaky routing issue in the DAWs output or the interface.
So have tried test recording - exporting, sounds exactly the same (tinny)
It sounds normal when monitoring and recording - it is only on playback that it sounds tinny
Yes - waveform looks normal, is quite low (as I understand SM7Bs generally are) but have tried it both with low channel gain and high gain - same issue in regards to tinny-ness (just gets louder)
I have tried the same signal path on an SM58 and Rode NT1A - both work fine, no tinnyness.
I have requested a repair from Shure but just seems like the oddest problem - I have trouble shooted as much as I can logically think of, old tracks using the mic all sound fine, all other channels sound fine, other mics sound fine - it can only be the SM7B..?!
Its the mic sounding fine when monitoring that is completely throwing me.. I agree how this can clearly look like a routing issue but I have now tried enough things (including different system) for it to suggest it can't be.. Logic has no-way of registering this specific mic when plugged in (when using same input path as other mics) so it leads me to conclude it can only be the mic..
Again, thanks for the responses - can be so maddening when things go wrong!
- Sam the Scholar
Where are you based Sam? Sometimes a second set of eyes on things can help and there might be a forumite near you who could help?
Though it sounds like you’ve done it, can you confirm that you’ve simply unplugged the SM7b, plugged in the SM58 and the recording went from tinny to normal? No changes to the monitoring path?
Are you using a direct monitoring facility on the interface or software monitoring via the DAW?
Phantom power on at all on the SM7b channel?
