Running my Behringer mother keyboard from a guitar PSU?
I have a UMX610 mother keyboard, I’ve run out of PSU's, I was wondering if it’s possible to run it from one of the outputs on my MXR Isobrick? it’s centre negative, 9v 100mA, there are many outputs on the MXR that seem to be able to do the job, but I’m just checking with you folks that it will be OK.
Re: Running my Behringer mother keyboard from a guitar PSU?
Checking the manual, that device can be powered directly via USB, or by batteries, or via a 9v 100mA supply, so if your pedal psu can supply 100mA per socket you should be good to go.
Me, I’d just leave it to USB bus power, but I guess you are using physical MIDI, rather than MIDI over USB.
centre-negative, 9v, 100mA is very vanilla so I'd be amazed if the MXR didn't have an appropriate output. Should be fine.
Posts: 28086 Joined: Sun Jul 05, 2015 12:00 am
That would be fine Dave, except!
The Berry only sends out Midi via the hardware socket in USB mode if you loop it back through the USB lead! which means turning on the computer, loading up the appropriate template in Reaper, I’d have to create a MIDI output track, all a lot of faffing around.
Thanks for confirming the guitar PSU, I’ll use that, as using an external PSU automatically sends data out of that socket.
Arpangel wrote: ↑Sun Oct 02, 2022 8:31 am
Fairenoughski. You are lucky the Berry wants centre negative. Most kit that ISN'T guitar related is the more sensible centre poz!
Yes, this is all because I need another supply for my MicroGranny, I’ve got a universal supply for that which is able to reverse polarity, as the MG is centre pos, it was being used on the Berry, so I’m having to move things around, without forking out for another supply.
