A friend needs a free/cheap playout software package to play sound effects in a stage drama. I've seen recommendations here before, but can't remember and a quick search failed to find anything here.
I'd be grateful for suggestions.
Sound FX live playback software?
Posts: 35511 Joined: Fri Jul 25, 2003 12:00 am
Re: Sound FX live playback software?
Mac/PC or tablet?
I recommend the free MultiPlay for Windows. I use the old v2.5 (v3 is still in beta).
A few limitations, but does everything you need for audio in a small to medium theatre show IME. Crossfades, scripting, keyboard shortcuts, multiple triggers, level and pan control and more. This has been used by me for dozens of professional productions. Just have an audio converter utility like this handy since it only uses wav/mp3 files.
For bigger productions on Mac, QLab is available to rent.
Plus 1 for Multiplay. Although it doesn't like 24 bit wav files if I recall correctly.
Regards, Simon.
Regards, Simon.
- Stratman57
Regular - Posts: 386 Joined: Wed Apr 20, 2005 12:00 am
Stratman57
Stratman57 wrote: ↑Sat Oct 01, 2022 6:41 pm Plus 1 for Multiplay. Although it doesn't like 24 bit wav files if I recall correctly.
Yes, 16-bit WAV is what it prefers. Thanks for the reminder.
I do this from time to time and I like to use a sample player and a MIDI/USB keyboard, and split effects across key ranges. I use Kontakt, but a free sample player, such as TX16Wx might do the job, albeit a VST host might be required.
Not quite the "free/cheap playout software package" that the OP wanted. In a theatre situation you'd need to find an additional location for the keyboard or other midi controller, label them up etc. Perfect for a more improvisational scenario, though. I used my keyboard as the lighting controller for a few shows since it was more fun playing the cues that way!
For Mac I have had great results with Rogue Amoeba’s Farrago and on the iPad/iPhone I’ve used Go Button.
Hope this helps
Cheers
Dave
Hope this helps
Cheers
Dave
- Lizardpoint
Regular - Posts: 185 Joined: Sat Oct 18, 2003 12:00 am Location: Biggin Hill, Kent
I've used Multiplay for many years in all sorts of situations - FX for plays and otherwise. I've also played around with GoButton and liked it, but never used it in earnest.
- Mike Stranks
Jedi Poster - Posts: 9932 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote: ↑Sat Oct 01, 2022 10:21 pmI've also played around with GoButton and liked it, but never used it in earnest.
The Importance of Being, presumably?
QLab is pretty much industry standard here for Mac or iOS. If it’s just the one show that needs to be programmed then it’s free.
- Bob Bickerton
Jedi Poster -
Posts: 4741 Joined: Fri Dec 20, 2002 12:00 am
Bob Bickerton wrote: ↑Sun Oct 02, 2022 4:10 am QLab is pretty much industry standard here for Mac or iOS. If it’s just the one show that needs to be programmed then it’s free.
Same over here. I know I go on about it, but for anything theatrical it really is the business.
And to clarify, it's only the Go Button iOS app that has the one show limit. The license-free QLab includes the vast majority of the audio cue tools enabled with no limit.
The pro audio licence is only needed for multi-channel I/O (above stereo) some of the MIDI/OSC features and other advanced audio tools.
