Although electricians do install CCTV systems for companies as part of there job, I came hear because I though the Knowledge would be more pacific and specialised to my subject
But they do still seam to be of the opinion that the cable I have made up should get a signal for its short distance. But as you stated it would not work so I have taken your good experienced advice (again why I came hear in the first place) and this is why I ordered the fitting the other day and I look forward to it arriving and pressing on with the project
Coax to phono connector wanted
Re: Coax to phono connector wanted
- Guest
Organ Grinder:
This: https://cpc.farnell.com/pro-signal/psg0 ... no%20leads will also provide what you want. This is a complete lead with 75-ohm cable.
Nothing more we can say really...
Good luck in testing the gear!
- Mike Stranks
Jedi Poster - Posts: 10471 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote: ↑Wed Oct 05, 2022 4:15 pm This: https://cpc.farnell.com/pro-signal/psg0 ... no%20leads
- Guest
Excellent. I like a happy customer supplied with a range of practical solutions. Case closer.
Posts: 39052 Joined: Fri Jul 25, 2003 12:00 am
