I just bought a Yamaha O2R 24 (with 2 adat cards and meter bridge for a ridiculously low price) but the 16 white fader caps have all discoloured over time. I was just wondering if theres any safe way to restore these to their original colour, or as near as possible? I saw on one forum, someone was recommending using the "Retrobrite" method of hydrogen peroxide and UV light. Others, however, say this will turn the plastic to dust and not to use it.
Any help or suggestions appreciated.
How to restore discoloured fader caps?
- BelfastGooner
Poster - Posts: 22 Joined: Mon Aug 30, 2010 12:00 am
Re: How to restore discoloured fader caps?
Bit of a sideways approach, but often on eBay you'll find people selling-off various knobs and fader-caps from mixers that they've disassembled...
... just search 'Mixers' in 'Pro Audio Gear'.
- Mike Stranks
Jedi Poster - Posts: 9932 Joined: Fri Jan 03, 2003 12:00 am
Yes, I've seen suggestions of hydrogen peroxide, although I'd be careful with that one.
The gentlest way to try at first is with warm soapy water and an old toothbrush before you investigate fiercer approaches.
Posts: 19919 Joined: Wed Jan 13, 2010 8:44 am
In the sailing world we use oxalic acid solution to remove rust stains from sailcloth and GRP, not sure whether it would work with whatever plastic used to make fader caps though. That said if you could source a few spares off ebay they will likely be similarly discoloured so you could experiment with different approaches.
I'd also start with soapy water and a toothbrush though (as MW says).
Jedi Poster - Posts: 17921 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Try putting them in the washing machine. This worked well to restore the knobs on my A&H desk to their full glory. I put them in a washing bag first though and I think I used a fairly gentle setting.
Posts: 12889 Joined: Mon Sep 10, 2001 12:00 am
BelfastGooner wrote: ↑Wed Oct 05, 2022 7:12 pm I just bought a Yamaha O2R 24 (with 2 adat cards and meter bridge for a ridiculously low price) but the 16 white fader caps have all discoloured over time. I was just wondering if theres any safe way to restore these to their original colour, or as near as possible? I saw on one forum, someone was recommending using the "Retrobrite" method of hydrogen peroxide and UV light. Others, however, say this will turn the plastic to dust and not to use it.
Yep you have to be careful what you use for cleaning. I thought meths was quite ‘benign’ and so I thought I would use it to clean my Virus TI and ended up wiping off the text for the controls
I've used hydrogen peroxide on yellowed fader caps - took about an hour. I didn't use UV but left them to soak out in the garden on a sunny day.
It worked perfectly and came out totally white. No damage to the black printed line.
I also used it on some other coloured fader caps and also helped them look much better too.
They didn't melt/turn brittle/disolve/turn to dust
That was about a year ago and they still look white and haven't re-yellowed.
orange wrote: ↑Wed Oct 05, 2022 10:20 pm I've used hydrogen peroxide on yellowed fader caps - took about an hour. I didn't use UV but left them to soak out in the garden on a sunny day.
So did you use neat hydrogen peroxide, or did you dilute it?
- BelfastGooner
I have a UV light which came with a UV activated screen protector. It has 2 rows of 10 tiny UV leds. I'm just wondering if this would be safer to use than a whole day's worth of sunshine.
- BelfastGooner
