Getting mixes done faster
Post by Aaron Straley »
I've been seriously mixing for about 6 months now, and my mixes are still taking me way too long. Started using templates this week to speed things up, and just getting to know my DAW better is helping. Also making quicker decisions on how to deal with problem areas.
I need a more systematic method and thought you guys might have some good suggestions. I feel like I am too random in my method and this is holding me back
What strategies do you recommend for speedier mixes?
Aaron Straley
Posts: 99 Joined: Wed Apr 13, 2022 12:25 pm Location: Pennsylvania, USA
Re: Getting mixes done faster
I think some of this comes down to whether you're working on 'complete' songs, and literally just doing the mixing, or whether you're creating and mixing as you go.
Assuming we're just looking at the mix side of things, then the pink noise method can help: https://www.soundonsound.com/techniques ... -reference
Personally I find that doing my first cut mix in mono and at low volume helps make some of the critical decisions.
But that's it from me really as more often than not I'm mixing and creating at the same time.
Posts: 28042 Joined: Sun Jul 05, 2015 12:00 am Location: York
Speed comes with experience, confidence and competence. Just keep at it and don't be looking for shortcuts at this stage.
Posts: 21008 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by RichardT »
If you haven’t got it already, I recommend Mike Senior’s book ‘Mixing Secrets for the Small Studio’. It features a very systematic approach to mixing.
Speed will come with time - it’s worth spending time struggling with your mixes at this stage to make them the very best you can as this will teach you a lot more than trying to finish them quickly.
I’d also be looking to make sure your playback monitoring is the very best you can make it. This makes an absolutely massive difference to hearing what’s wrong and so being able to fix it.
Also it may be worth taking time out to experiment with different techniques and tools just to learn more about them. For example, dynamic EQs, gating, multing, parallel compression, etc etc. then you’ll feel more capable of using them for real when you need to. Mike’s book will help you both to understand the techniques and more importantly when to use them.
RichardT
Posts: 4977 Joined: Fri Aug 13, 2004 12:00 am Location: UK
And it may help you if you limit the number of software plugins you have available to use, so that you don't spend several hours deciding which compressor works best for a particular sound. Pick the ones you like best/use most, and stick with those until you feel that you are mixing at a reasonable speed. It helps you to get to know those plug-ins very well so that they become quick to dial in the sound you want.
Then you can start adding in more plugs, but don't add too many at a time. If there are plugs you don't use, move them into a different folder e.g. 'VSTunused' so you don't have them cluttering up your effects list.
Posts: 18282 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by Sam Inglis »
What's driving your wish to mix faster? Are you unable to get all the mixing done in the time available? Or do you just feel frustrated that it's taking so long? If the latter, I wouldn't worry. As long as you enjoy mixing and find it rewarding, who cares if it's slow?
Sam Inglis
Posts: 3162 Joined: Fri Dec 15, 2000 12:00 am
I'll probably just echo what others have said but I'd say that it is all about getting to know your tools and good ear training - especially knowing how particular sounds are created. Wonks suggestion of limiting your plug-ins is also good. A good general purpose eq and compressor will work for most things if you know how to drive them.
It is also about having a good idea of where you want the song to go. If you just have a load of tracks full of ideas that might work (but might not) then the mix is going to take far longer than one with a load of tracks that were created with a particular sound in mind.
Posts: 15859 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by RichardT »
Sam Inglis wrote: Thu Oct 06, 2022 2:33 pm What's driving your wish to mix faster? Are you unable to get all the mixing done in the time available? Or do you just feel frustrated that it's taking so long? If the latter, I wouldn't worry. As long as you enjoy mixing and find it rewarding, who cares if it's slow?
Personally I have a love-hate relationship to mixing. It's great to have something come together, but it's painful when fixing one problem reveals another, and fixing that reveals another, almost ad infinitum.
But I agree that there's no need to hurry unless there are external deadlines to meet.
RichardT
Post by Matt Houghton »
It took me ages (several years) to get to the point where I could mix relatively quickly. Speed is still not my strongest point either! But here are some random tips that spring to mind on reading this thread:
1. You need to have monitoring you're confident in so that you're not second-guessing your decisions all the time. Doesn't have to be the most expensive listening system in the world, but you must have confidence in what it is telling you.
2. However good your speakers/headphones, (1) means listening to LOTS of good commercial material, and getting to know it intimately so that system, so that you can make good judgements on what you're mixing. The good thing about that is that it's a lot of fun!
3. You have to have material worth mixing — on a technical level (eg without noise or horrible room tone preventing you doing what you want to do with a source), a musical level (being on time, on pitch etc, as well as decent parts and instrumentation/arrangement choices, and an emotional one (quality of performances/programming etc.). Otherwise, you spend ages thinking you're mixing when you're actually just compensating for problems — that can take time, leave you frustrated and, worst of all, turn you off the material, making it hard to focus on the end result.
4. Gain staging — stick to the analogue way of working when it comes to levels. Yes, you *can* get away with pinning the meters into the red in a modern DAW, but being disciplined about levels helps a lot when it comes to using analogue-modelling plug-ins, and particularly threshold-based bus processing (eg mix bus and drum bus compressors). The point here being that it helps you avoid problems, which helps you avoid spending time chasing your tail.
5. Focus on the most musically important sounds first. Eg, lead vocal and drums/bass (in that order) are likely more important than anything else. Spend time getting that core of the mix right, and the rest will fall into place much more easily.
6. Don't worry about what you cannot hear. As in, don't go down the rabbit hole solving problems that annoy you only when something is soloed. You can always go and attend to that stuff later if you really feel the need, but better to focus on the big picture/broad strokes first.
7. Avoid ear fatigue — have a calibrated reference listening level that is your default (doesn't stop you going louder or quieter, but you can return to this whenever); take regular short breaks (cuppa time!) away from music. Occasionally take a longer break — go feed the ducks, take the dog for a walk or whatever. This all stops you making decisions when you can't really trust your ears... which obviously causes that whole 'chasing your tail' thing again.
8. Don't listen on everything on loop for ages. As well as hastening listening fatigue it leads you to be overfamiliar with the music — ie your ears grow accustomed to any problems. Instead, try having a notepad/pen handy, and as you get into the mix, try the tape-style workflow: play back once, listen, take notes on your thoughts and any problems, and write down a snag list. Work through it and then listen again. I find this helps me haul my ass across the finish line!
Of course, Sam's point is a good one: there's no reason why you *must* mix fast unless you have deadlines to meet or want that album to come out before the end of Time.
Dammit... a couple more and I could have called this a listicle :lol::headbang:
Matt Houghton
Posts: 1486 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Post by RichardT »
Great points Matt. To amplify point 8, which I wholeheartedly agree with, I find it helpful to work on a number of songs at the same time to increase that sense of freshness and distance.
RichardT
Thanks everyone, great advice that I will take to heart. I definitely need some self imposed time limits. Some of the denser mixes are taking me more than 20hrs, mainly because I cant get to where I want it, and refuse to call something complete that I know is not right.
I get really sick of listening to the same song that much and it ends of having a negative impact. It feels like I am not being very productive when it takes this long.
Yes I want to be able to mix faster, for a more satisfying experience and better end results. Lord knows I cant get any slower.
Aaron Straley
Aaron Straley wrote: Thu Oct 06, 2022 7:32 pm Some of the denser mixes are taking me more than 20hrs
That's not untypical. Even a relatively simple mix can take a day, depending on your definition of 'mixing' - often the de-essing edits and tuning can take half a day on their own.
I'd worry less about how long things are taking and more about what you have at the end of the process.
Post by RichardT »
Aaron Straley wrote: Thu Oct 06, 2022 7:32 pm Thanks everyone, great advice that I will take to heart. I definitely need some self imposed time limits. Some of the denser mixes are taking me more than 20hrs, mainly because I cant get to where I want it, and refuse to call something complete that I know is not right.
You might be one of those people for whom mixing is a necessary chore rather than a pleasure - but even so, it will get easier with experience!
RichardT
Post by sonics »
May we know what sort of music, what sort of arrangement and which DAW? Folk singer/guitarist, deathcore, or 200-track film score? :lol:
There have been some good posts already, of course!
It's probably inexperience. You could do worse than find a mix engineer that works with music you like, and find out their methods. That's the old way it was done. I once paid for studio time with producer/engineer as a learning experience. In the end we had a great time and he didn't charge me anything!
sonics
Post by MarkOne »
Of course the other thing that contributes is the performance. More than once I’ve heard interviews with big name mix engineers talking about really famous tracks saying stuff like “It was a joy to do, it pretty much mixed itself”
If it’s a great performance, it’s in time, in tune and the captured tone is on the money, and it was recorded in a great space there’s not much to do to get a great mix.
If on the other hand you’re like me and despite all your efforts those things are all a little sub-par, then it’s a much bigger job.
MarkOne
Posts: 2989 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
Aaron Straley wrote: Thu Oct 06, 2022 11:42 am What strategies do you recommend for speedier mixes?
None.
It takes as long as it takes, yours might take longer than mine, or they may be quicker, I’ve made mixes in five minuets, and some have taken months, making a mix is like growing plants in your garden, the same type of plant may take different times to grow, or it may not grow at all, it’s the same with recording, we must abandon this desire to make everything quicker, like, taking a long time is wrong somehow, it’s not, it’s just a natural thing, you just go with the flow.
Posts: 19866 Joined: Sat Jul 12, 2003 12:00 am
Post by Mike Stranks »
Really good stuff so far... some of which I've only skimmed, so apologies if what follows has already come up...
I find that because I'm self-taught on using DAWs etc - aren't we all? - then my 'voyages of discovery' may have led me to adopt some labour-intensive ways of achieving a desired effect when there's a much simpler way available that I hadn't discovered. Checking out 'tips and techniques' articles and videos (with care!) can be useful in identifying quicker and easier ways of doing stuff.
Just last night I was watching a set of videos on using some video software I use... Some useful highlights on much easier ways of achieving something than I've been using. However, there were also some convoluted ways of doing stuff where I use much quicker approaches! Hence, 'with care' above...
... View and read with discernment... your current way may be a better way! :lol:
Mike Stranks
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Post by jaminem »
Aaron Straley wrote: Thu Oct 06, 2022 11:42 am I've been seriously mixing for about 6 months now
Thats not very long, at all. I think your expectation is way off. I know a pro who can work very 'quickly' if they have to, usually this is due to a deadline, too much work on, or the knock-on effect of far too many little changes leading up to a deadline. True he will work faster than I and get a better result as he does it everyday and is very talented.
he's been at it over 20 years....
Practice mate, 6 months is really no time at all. Stop worrying about speed, quality is what you want - there are some excellent suggestions in this thread.
You will naturally become quicker the better you get...
jaminem
Posts: 1486 Joined: Mon Mar 19, 2001 12:00 am
Post by OneWorld »
I think the point 8 made by Matt is especially useful....."8. Don't listen on everything on loop for ages. As well as hastening listening fatigue it leads you to be overfamiliar with the music — ie your ears grow accustomed to any problems. Instead, try having a notepad/pen handy, and as you get into the mix, try the tape-style workflow: play back once, listen, take notes on your thoughts and any problems, and write down a snag list. Work through it and then listen again. "
I think it helps to be consistent, using your ITB mixer as would have been done back in the day before DAWs became commonplace - each channel on a mixer would essentially always deal with the same content eg Channel 1 would always be lead voice and so on. OK there has to be done flexibility, but if for example one section of your mixer is for drums Kick, Snare, HiHats etc then when you get to mixing you won't need to set up each channel strip anew.
I use a controller which back across in groups of 8, so I set up each section reflecting that 8 MIDI + 8 Audio + 8 instrument tracks and so on
It is taking a bit of time to establishing the 'ideal' setup but I am getting there bit by bit, instead of setting up a mix and each time I do assign some plug in to track 1, another to track 2 and so on, I have all the oft used plugins always loaded and use them/bypass them as and when. I have set the controller up so the press of a button opens the plugin editor.
I guess what I am trying to say is that I am trying to mimmick the use of a hardware mixer
OneWorld
Posts: 5291 Joined: Tue Apr 07, 2009 12:00 am
Post by danclapson »
Some of my personal hints for faster mixing...
- "Always gain stage". Get your channel levels coming in right before you do anything else. It'll save you a massive headache later.
- "Learn how to set your Levels, Pan and EQ before you do anything else". I've had to learn this skill the hard way, but if you can become super amazingly expert with Levels/Pan/EQ you are nearly 90% of the way. People waste hours adding compressors, distortion, verb, delays etc. I am not saying don't use other FX... yes, you might need them... just don't underestimate how important your L/P/E is to the overall mix. It's more important than anything else.
- "You can't polish a turd". However much you think adding yet another plugin FX can fix a sound, the problem is most likely your source material. Don't be precious - throw away and start again if it doesn't sound right.
- "Learn how to side-chain kicks and bass etc". Side-chaining is your friend for well balanced mixes.... and this comment is not just for EDM.
- "Always keep the input into your Master Bus under -XXX db". Be kind to your mastering process - give enough headroom for the final polish. Some say - 3db... others say -6db. I go for -6db and haven't looked back.
- "Less is much more". Save time. Don't add more. You'll realise later that it sounds better when you remove it.
- "Practice, practice, practice until you aren't thinking how to mix".
- "Oh... wait on... you can polish a turd". Once you become really fast, skilled and proficient at mixing you'll learn how to make anything sound good!!
danclapson
Posts: 1 Joined: Fri Oct 13, 2017 11:48 am
I think the suggestions so far have been great. On thing I tried yesterday is using a list for each session and this is helping me already. This is such a simple step that is making big difference. How did I miss this?
One suggestion, I was already using. This was to use only stock plug ins and limit choices for plug ins. Once in a while, I will go searching for a 3rd party plug in if absolutely needed
I do enjoy mixing and have only been serious about it for about 6 months. By serious mixing, I mean mixing a song to a radio ready state. Please understand I have been recording music and using some type of DAW for more than 25yrs...recording my own music, sharing with bandmates, etc....Basically, I have a foundation there to build on, I just was not attempting to mix to a pro standard
I also worked as an RF technician tuning and testing amplifiers for many years, so I have a decent grasp on compression, EQ, filtering and the like.
When I started about 6 months ago, I was super slow and learning the new DAW. Getting my monitoring situation up to par (best I can), Exploring the the different plugins and settings for each. Learning all the editing features on the DAW. Now, I can tell I am at a point where I need to speed things up, that's what this post is all about. I think if I can start getting through mixes quicker, it will be more enjoyable and I will get better results. I am not trying to rush through mixes just to call it done, and will not pass anything off as complete when it is not right.
Aaron Straley
Post by OneWorld »
I wonder if one day some AI coder will attempt writing the code to mix automatically, after, mixing is to a great extent objective ie, each instrument should occupy a certain frequency range, volume levels and dynamics set relative to other tracks etc etc and a really clever application could ‘learn’ from organically mixed tracks?
It certainly would be an interesting challenge for a coder. That said, one of the most difficult aspects of implementing AI is the knowledge engineering element of the process, many human experts are very reluctant to disclose knowledge they have spent years and years acquiring, why would one make oneself redundant?
OneWorld
danclapson wrote: Fri Oct 07, 2022 12:00 pm Some of my personal hints for faster mixing...
Hi danclapson, and welcome to the SOS Forums! 8-)
And what a great and super helpful first post - you'll soon have lots of friends here ;)
Posts: 21642 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
This is very true, and this may seem strange, but I’ve noticed this many times over the years, George Martin semi-jokingly said something along the lines of, he could tell a good mix just by looking at the meters, this has been my case more often than I care to think, if the levels are all around the same area, things tend to gel, depends what type of music, but it’s not as silly as it sounds.
