Guitar and audio interface noise
Re: Guitar and audio interface noise
Martin Walker wrote: Tue Nov 29, 2022 8:57 pm
ef37a wrote: Sun Oct 23, 2022 9:43 am I once went to the trouble of opening up a USB cable with a craft knife and removing some 10mm of the screen. I had a laptop that buzzed with an AI when on mains power but not on battery. Open circuiting the screen did not fix it.
As I understand it, a USB cable only has its screen connected at the source end, and not at the device end, so removing some of the screen wouldn't defeat a ground loop.
To do that you would probably have to cut its black GND wire (or preferably add a small resistor in series with it, say 50 or 100 ohms, which is a great cure for ground loops caused by audio cables).
CAVEAT: I've not tried this myself, and with devices drawing larger amounts of current the series resistor would also drop the 5V supply. ;)
Did not consider that Martin! I had just assumed a USB cable screen was continuous like an audio cable but as you say, they are not, at least the A B cable I pulled from the rack at random is not.
Op's 3kHz whine smacks to me of a low grade 16 bit converter? These were common in early 16 bit USB mixers. Even my A&H Z10 generates a low level whine at around that frequency. They soon changed to a very quiet 24 bit converter.
Posts: 18095 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by Francesco Chieffo »
ef37a wrote: Tue Nov 29, 2022 11:44 pm
I use an Audient iD14 mkII. Shouldn't its converters be working at 24 bit?
Francesco Chieffo
Posts: 27 Joined: Tue Jan 14, 2020 1:05 pm
Francesco Chieffo wrote: Wed Nov 30, 2022 12:15 am
Yes indeed it should and I very much doubt it is responsible for the noise but it should be easy to eliminate it.
Note, it is not the 16bit working that causes the noise, most AIs can do 24 and 16 bits and the latter free from artefacts, it is some design shortcoming in these low end converters causing the whine.
Post by ajay_m »
I have also noticed that the most obvious noise in these scenarios is around 3KHz though it can vary. As far as I can see, what's going on is that within both the PC and the audio interface, we have a lot of digital circuitry. Each transistor (strictly, a MOSFET in most cases) acts as a small switch, with very fast rise and fall times and cumulatively they impose a very erratic load on the main PSU in each unit (or via bus power in some cases). Obviously the designers know this and there are significant amounts of capacitors sprinkled around, as anyone who has done electronic design knows, you normally decouple each chip with a small capacitor across power and ground.
But while this ensures that transients are smoothed out, as seen by the chips themselves, those transient currents still flow through the capacitors and they make their way to the ground plane. The transient currents can be very high, in the order of amps, and so depending on the design of the PCB, its possible for portions of the ground plane to experience a voltage drop as a result, relative to other portions of the ground plane as these currents flow around the circuit.
Now the impedance of the ground plane is very low but the currents are very high and it only takes a millivolt or so of drop and you have a problem now.
Depending on the design of the PC and/or audio interface, you then end up in a scenario, as I said, where the ground reference at the audio input or output jacks is not precisely zero volts, but is in fact jiggling around by a millivolt or so. This represents an incredibly low impedance source which can easily provide a LOT of current. (I would guess maybe 0.01 ohm impedance or even less).
Both the PC and the audio interface can then have ground planes which are independently 'jiggling around' by a tiny amount of voltage. This is probably why some combinations of PC and interface are particularly bad.
On the other side, the 'hot' signal wire represents a very high impedance signal path and carries negligible current. So now if you were to put a sensitive meter between the two units across the hot side wire, you'd see 0 volts, because so little current flows through this wire it looks like a short circuit.
But do the same on the ground side and you'll see a tiny signal. Because this signal is sourced by an incredibly low impedance high current source, any normal piece of wire looks like quite a high resistance and consequently the two ground points aren't, in fact, at the same potential. Since the audio interface amplifies the difference between the signals, this appears as noise.
When you use balanced I/O this helps somewhat because now, in theory, the difference between the two hot lines is amplified and any 'common mode' signal is rejected.
But the idea of balanced I/O is to handle a common mode signal on the hot side - typically, 50Hz mains hum. In this case the common mode signal is being introduced via the single ground wire.
Unfortunately this digital noise has an incredibly wide bandwidth - it will go out to several megahertz and possibly beyond. Most opamps used in audio devices are, understandably, specced to handle signals in the audio range and their common mode rejection ratio figures - which we rely on when using balanced I/O - degrade rapidly outside the audio range. As well as this the common mode noise is being injected into the ground plane on the audio interface so it can radiate out from there into signal paths that don't have any rejection.
This then allows the spurious signal to get back in via pathways that have no intrinsic common mode rejection, and as a result of intermodulation effects it can reappear in the audio spectrum. (and as well as this I think, to do with the underlying software, there are routines that run with scheduling frequencies in the audio range, which imposes a 'modulation' on these current spikes that then appears as an audio 'whine'.)
Also LEDs (including display backlights) seem to be driven by PWM signals that end up in the audio range. I've often found on equipment where the LEDs can be turned off, that this affects the level of the resulting whine.
Unfortunately the interaction between PC and audio interface somewhat randomly then ends up with noise issues. Bus-powered units seem to be more vulnerable but there's no real pattern unfortunately.
It does look as though USB2 optical isolators are starting to become available, albeit they aren't cheap compared to the USB1.1 solutions (which are only about £15). This is a magic bullet solution though and is pretty much guaranteed to resolve the problem. If you only have 4 or 6 audio channels, then USB 1.1 is perfectly adequate. You may, though, as I said, have to splice a PSU in on the output side (by cutting the red wire and then splicing into the black wire without breaking it.
Now your ground path is completely broken, so any ground plane voltage transients can't propagate across the isolator because the signals are optically coupled and neither the 5V or ground wires have a circuit between the devices. Instead, downstream power is now supplied by a second PSU which has no electrical connection to the PC, as the PSU is double insulated.
Why don't the manufacturers make sure that the ground points for USB ports and audio jacks are always at 0V?. Well, it's very tricky. There's no point at which the ground plane is ever really at 0V, because those transient currents also have to flow back up into the main PSU (which for a laptop is always external) and so the resistance of the ground wire means that relative to true ground (which is buried inside the PSU effectively), the ground plane will always jiggle up and down a bit.
Digital circuitry doesn't care about this because the threshold voltages for the logic gates are much higher than the groundplane noise. But analogue circuitry cares very much, which is why we get problems.
ajay_m
Posts: 1286 Joined: Mon Jan 16, 2017 7:08 pm
Post by merlyn »
Francesco Chieffo wrote: Tue Nov 29, 2022 11:34 pm I believe it's not the instrument since I own several ones and the problem occurs with all of them.
I'm not suggesting there is anything wrong with your guitars. Pickups by their design can pick up electromagnetic waves.
For clarity, the only noiseless scenario is guitar into the audio interface (with an amp sim plugin) and headphones connected.
The interface is OK then, if there is a whineless scenario. The iD14 is 24 bit, and it's not the convertors.
The whine already occurs just connecting the Macbook (I just bought a new one, but it is also there with the previous one I owned) to its power supply.
There are a few combinations and permutations of which gear is connected. Let's say you have :
Guitar > Interface > Headphones (Mac on battery) -- no whine
and
Guitar > Interface > Headphones (Mac on AC) -- whine
Now if you pull the guitar lead out is there still a whine? If so it's not the pickups picking up electromagnetics, and it may be worth trying a USB isolator, as suggested by ajay_m.
Could it be a dirty power problem?
Probably not, despite what the power conditioner industry might tell you. The Mac works on DC. The power supply converts AC from the wall into DC, so the DC should already be cleaned up and filtered if the Mac works.
merlyn
Posts: 1531 Joined: Thu Nov 07, 2019 2:15 am
Back in the early days of computer audio manufacturers of internal audio cards used to go to great lengths to reduce computer noise to a minimum. This would include paying extra attention to grounding and power supply filtering.
It seems that many modern manufacturers of external interfaces possibly aren't paying the same attention to noise reduction. Perhaps they think that having the convertors in a box away from the computer is enough, without any other measures being needed.
It is interesting that most dedicated digital audio connection systems like SPDIF, ADAT, AES and even networked systems use isolated connections to prevent grounding issues. My personal choice is to keep the computer and audio parts separate by using ADAT or SPDIF links between the convertors and the audio interface.
Posts: 15849 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Unfortunately I have a not very big desk here and I have to keep everything not too far apart. As for the USB isolators, could you point me to one? I tried looking for optical ones and they seem quite expensive. I haven't actually found any USB3 ones, the MacBook Air I have now only has these ports.
At this point I have to wonder why last year in the house where I lived I had none of these problems.
Francesco Chieffo
Post by ajay_m »
Just Google usb isolator Amazon. The first two hits I got were around £17 or £18 . They use an admu3160 chip. Note that for bus powered audio interfaces the downstream power available is less than 400mA which may not be enough for some interfaces. In this scenario I would splice in a 5v PSU like a phone charger to provide power. These should work fine with a usb3 port but they are usb1.1 12Mbps devices so they should handle 4 to 6 channels at 44.1khz ok (at 24 bits this is approx 1Mbps per channel not allowing for protocol overhead)
ajay_m
Post by merlyn »
ajay_m wrote: Wed Nov 30, 2022 10:51 am I have also noticed that the most obvious noise in these scenarios is around 3KHz though it can vary ...
I think your explanation makes sense and hangs together. What I wonder is how you would explain, in this case, why there is no whine when working on battery power?
merlyn
Post by ajay_m »
On battery power CPU clock speed is usually reduced and the idle clock speed is often set very low as well. Plus backlight intensity is usually reduced. This could significantly affect the amount of interference, quite a bit could be coming from the voltage regulation subsystem which handles 10s of amps at very low voltages. Also with a PSU connected you have a fairly good antenna to radiate interference out for possible pickup via leads, guitar pickups etc.
ajay_m
ajay_m wrote: Wed Nov 30, 2022 7:31 pm Just Google usb isolator Amazon. The first two hits I got were around £17 or £18 . They use an admu3160 chip. Note that for bus powered audio interfaces the downstream power available is less than 400mA which may not be enough for some interfaces. In this scenario I would splice in a 5v PSU like a phone charger to provide power. These should work fine with a usb3 port but they are usb1.1 12Mbps devices so they should handle 4 to 6 channels at 44.1khz ok (at 24 bits this is approx 1Mbps per channel not allowing for protocol overhead)
Thanks a lot, I will definitively try this.
Francesco Chieffo
Post by merlyn »
If you want the 480Mbps bandwidth of USB 2, there is the Topping HS01. It also has a USB C input for a phone charger, which the Audient iD14 will probably need.
merlyn
merlyn wrote: Fri Dec 02, 2022 1:30 pm If you want the 480Mbps bandwidth of USB 2, there is the Topping HS01. It also has a USB C input for a phone charger, which the Audient iD14 will probably need.
Thanks, do I need a specific cable to connect the Audient to both the USB 2 (for audio) and the USB C (for power) ports?
Francesco Chieffo
Post by ajay_m »
This device seems to have good reviews and if I recall the price has dropped since I first saw it. Usefully you can connect a PSU to it to supply downstream power and if the audio interface is bus powered than the standard cable is just used to connect the isolator output to the audio interface. Otherwise you just plug the psu into the interface if it is separately powered.
ajay_m
Great, thanks. Can I use this cable instead of the included one? https://www.playstereo.com/it/cavi-usb/ ... 30866.html
Francesco Chieffo
Post by merlyn »
There's a diagram of how to wire it up on the page I linked :
Yes, that USB lead looks suitable. You need three leads : the one you linked between Mac and HS01, a USB A male to USB C male between the HS01 and the iD14, and a USB A male to USB C male between the phone charger and the HS01.
merlyn
merlyn wrote: Sat Dec 03, 2022 3:28 pm There's a diagram of how to wire it up on the page I linked :
The Topping Isolator has arrived but unfortunatelu it isn't over. I haven't been able to test it because the Audient iDmkII doesn't get enough power, even when I plug a cable to a phone charger (it starts blinking and it doesn't work at all).
What's the next step? Maybe I'm using a wrong cable between the topping and the phone charger (it's not the one I got with the smartphone)?
Francesco Chieffo
Post by merlyn »
How many Amps or Watts can the phone charger put out? 2A = 10W is fairly standard. That should be enough for the iD14.
It could be the cable as not all cables are 2A. I would have thought most are these days, though.
What is the charger and cable?
merlyn
I just checked and the iD14 is very power hungry compared to some other audio interfaces. It needs at least 0.9A and ideally 1.5A at 5V.
Post by ajay_m »
I can't find anything about any intrinsic power limitation for the hs01 feedthrough power port which I would assume essentially just connects the PSU directly to the output port. That said, many usb cables have pretty thin wire and that's a lot of current so using two very short 0.5m cables for the power feed to the hs01 and then to the audio interface might be a good idea.
If that failed it's always possible to directly splice the PSU into the output cable close to the audio interface connector, a couple of cheap Poundland cables can be used to do this.
ajay_m
Post by ajay_m »
An in-line usb voltage meter is a useful thing to have, they're a few quid from Amazon and will show you the voltage at the point they are plugged in. Most will also measure current drain as well
ajay_m
