Can someone please help with some DX Sys-Ex?
Re: Can someone please help with some DX Sys-Ex?
Layering FM attacks from a DX with the body of the sound from a Prophet was regular practice for me a few decades ago. I made excellent, fairly realistic brass sounds that way.
Great bells and mallets, too. You couldn't get those fast attacks elsewhere without using a sampler.
FM is all about snappy, twinkley, glassy, bell-ish tones. It does those fabulously. Not so hot for pads, strings and the like.
Cue other posts disagreeing with me in four... three... two... one...
I got the pads by putting DX7 string patches through a Dimension C footpedal, still necessary when I got the TX802 which in theory was eight DX7s which could all be separately micro detuned to each other.
MOF wrote: ↑Sat Nov 26, 2022 7:06 pmFM is all about snappy, twinkley, glassy, bell-ish tones. It does those fabulously. Not so hot for pads, strings and the like.
Me too! I still have my Dimension C chorus pedal, which I must dig out to try with the Nymphes.
The original sine only FM carriers on the dx series synths and lack of filters did limit the sonic palette. You could not create the spectrum of a true sawtooth and so strings were always just out of reach. Also the lack of filters meant that timbre changes over the duration of a note had to be accomplished by modulation depth changes which led to a characteristic "boingy" timbre due to the way Bessel functions work. But fm synths like the fs1r had other waveforms and filters and their sonic palette is huge, certainly strings and pads were well within reach
CE-1 and Dimension D here...
We stuck ours through a distortion pedal...
You can get decent sustained pad sounds out of an original DX7, but it's hard work compared with how easy it is with even the most basic of analogue synths, so these days why even bother?
Yup, I have Dim D and a couple of CE-1s here still too. Love 'em all!
TBH the Line 6 Helix, and a few plug-ins, emulate any of these to my satisfaction, but some things you just don't feel you can part with.
You're right. However, on my list of things to do are some A/B tests with some of my old gear. If software gets close enough, I'm selling it. I actually like the idea of that gear going to someone who really wants it, and will use it more than I do (hopefully). Just haven't got around to it yet...
What about the Korg OPSIX? I don’t generally get on too well with soft synths, in terms of playing with them to figure out sounds. Dexed looks pretty complex. And I like to understand how stuff works
Gear: Loads of guitars, Line 6 Helix, Yamaha THR30 amp
Bechstein 1932 5’3” Grand Piano, Yamaha CP88, Yamaha YC61, Nord Wave2, Arturia Keystep Pro, Arturia KeyLab88, MacBook Pro, Mainstage, MAudio and Presonus interfaces, Behringer XAir mixer…
Then FM isn't for you. I doubt more than a dozen people ever knew how FM worked!
I've never even seen a OPSIX.
Clearly there's been some confusion somewhere along the way. There's no way these files should have been given a .syx suffix. But these files go back many years, so I'll never know what truly happened.
I suspect the files in question were actually Cubase MIDI file exports, despite me believing they were clean Sys-Ex dumps. I was using a hex editor to try to isolate the Sys-Ex, but couldn't see the wood for the trees.
Sonics found the data and saved the day!
The Elf wrote: ↑Mon Nov 28, 2022 4:05 pm
I got the Opsix. Only had it a day, but having watched tutorials and reviews, and reading about FM, I’m finding it fairly easy to use and am getting to grips with the concepts.
