How to track using virtual instruments when they are so loud
Most my virtual instruments are very loud and when I try record audio using say a piano VI as my backing track I find my audio too soft. What is the correct way to work with VI's. Do most engineers turn them way down at the output of the actual instrument or is turning down the fader the best way? Why are the outputs so hot anyway, do they just assume that nobody will like the sounds if they are at a decent level?
Re: How to track using virtual instruments when they are so loud
Most VSTi's will have an output gain or volume somewhere in the GUI, just turn it down to a sensible level there. That way any following plugins or master summing will all be getting expected levels.
As to why they do it like this, you'd need to ask the developers - or their marketing departments...
Posts: 28072 Joined: Sun Jul 05, 2015 12:00 am
Either do as Drew says or turn down the pre-gain / trim on the channel if you have that available in your DAW.
I turn VSTi input gains down, so they match my -10dBFS peak - just as if they were tracks I'd recorded myself. That gives a good starting point for the mix.
I don't know which DAW you use, but a good trick with Cubase is to flatten the mixer, reset peak indicators, and allow the song to run through. Then turn down each track's gain by the amount the track has peaked over target.
You can also have a default startup template where the first insert in all the instrument slots is a gain trim plugin to pull the channel down by +12dB (or whatever)...
That's what I do as well, since even if you adjust the VSTi output level itself, there's a good chance that if you change the VSTi patch for a different sound the level will jump back up and deafen you (and even if you decide that the new sound doesn't work, and you switch back to the previous one, you'll probably have to manually drop its level again).
Having post-VSTi gain plug-ins in your template also means that all the faders in your mix can start life at around 0dB.
Posts: 21662 Joined: Wed Jan 13, 2010 8:44 am
My experience has been that quite a few VST instruments were programmed too loud, and the only real solution is to turn down the level of the offending patches in the instrument itself, at least for anything other than a rough version.
Once I've decided on the sounds I'm using, I make my own patches. There's always something I want to change, anyway!
Thank you. I do have something called "PRE" in Cubase. This is at the top of my mixer along with my EQ settings. Would this be the right place in my signal chain to reduce the level? When I create a midi track in Cubase I actually get two tracks in my mixer and only the VST has the "PRE" option available.
Yes, that’s it!
Martin Walker wrote: ↑Thu Dec 01, 2022 11:50 pm
Great suggestions. Is there any difference in the final sound if I reduce the level using PRE in my mixer compared to lowering the instrument level output?
armans wrote: ↑Tue Dec 06, 2022 11:10 amMartin Walker wrote: ↑Thu Dec 01, 2022 11:50 pm
No, both are just gain controls. I usually set a sensible initial gain inside the virtual instrument, and then if I need to tweak the entire track volume I use the pre-gain. This is a great way to adjust the overall track level if you have it automated, much easier than trimming the automation itself.
That's certainly possible, although I suspect rare, since it's unlikely that most instruments will have their preset output levels set so high that they overload internally.
One exception might be monophonic instruments that someone decides they would like to play chords with (by upping the polyphony). A clutch of notes on a sound designed to be played solo might end up over the top gain-wise.
I'm sure that's possible, but in the context of reducing the gain both should be equivalent. I guess it's possible the initial gain might be set too high, so a patch starts off distorted out of the box, but I think that's going to be very rare.
Martin Walker wrote: ↑Tue Dec 06, 2022 11:43 pm That's certainly possible, although I suspect rare...
Well, not in my experience. I've heard a lot of presets pushing levels into distortion to impress, and multi-timbral synths can easily get into overload when combining sounds.
