I've been researching the really small mics designed for video use.
I've just bought a new (to me) camcorder where the hot-shoe is very close to the front. This means even the usual suspects in the short-shotgun field are out of the question for run-and-gun because of visual intrusion when panning wide.
So the little guys from Rode, Deity, Comica et al have been having the once-over...
The Sennhesier MKE-200 takes an interesting approach. Rather than the usual attachable foam and dead-kitten wind-shields, it's a supercardioid mounted in its own blimp, but supplied with a furry for stronger winds. Test evidence when compared with the 'others' is good.
Now, at c.£75 I'm under no illusions about ultimate quality - and in terms of overall sound indoors it's by no means 'best of bunch'. (For me, it does have a lot going for it though.)
But it's got me wondering whether anyone else has/will enter the market with an oven-ready blimp/mic combo? As a user of a Rode Blimp with various decent mics, I know that for the pro, full choice is vital and it's born out by the generated quality, but for the serious amateur, I think the sheer simplicity and convenience of an all-in-one might be attractive...
Really compact 'run and gun' mics - an interesting discovery...
- Mike Stranks
Jedi Poster - Posts: 10467 Joined: Fri Jan 03, 2003 12:00 am
Re: Really compact 'run and gun' mics - an interesting discovery...
Interesting approach. Given the limited dimensions there's naturally going to be some compromises involved but for outdoors use I'd be very interested in a comparison with some of the Rode equivalents.
It is very dinky though, I wonder if a slightly larger one, with more space between the blimp and the mic would be any kind of improvement or whether it wouldn't make much difference until you got up to 'proper' sizes.
Forum Aficionado -
Posts: 24657 Joined: Sun Jul 05, 2015 12:00 am
This is true. But having the mic on the camera is a compromise anyway (unless you're just capturing general stmos soundtracks).
wonder if a slightly larger one, with more space between the blimp and the mic would be any kind of improvement...
Yes. The greater the distance twixt mic diaphragm and windshield surface, the better the noise attenuation will be. I can't remember whether it's a square or cube relationship, but a small change makes a big difference.
Of course, a bigger windshield means bulkier and heavier, so a practical compromise is necessary.
The sharp edges of the cylindrical windshield will create additional noise through turbulence — which is why Rycotes (etc) all have domed ends — but it's obviously more expensive to manufacture a blimp than a cylinder. Compromises again.
Posts: 39031 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Sat Dec 03, 2022 2:56 pm Yes. The greater the distance twixt mic diaphragm and windshield surface, the better the noise attenuation will be. I can't remember whether it's a square or cube relationship, but a small change makes a big difference.
That was my starting assumption, but then I wondered if it might be one of those things where you get an initial improvement, but then not much difference until to you move to something much larger.
Something with about twice the dimensions (in all axes) of the Sennheiser might still be camera-mountable without being too bulky.
Forum Aficionado -
Agreed. I personally don't like a single mic on the camera, it's neither here nor there. There are a lot of stereo mics that are nice and short. Here's my budget rig with a Sony camcorder mic, like all their small mics it sounds a lot better than you might expect.
- Tomás Mulcahy
Posts: 2568 Joined: Wed Apr 25, 2001 12:00 am
Looks like your camera is being impregnated by an Elvis impersonator.
- shufflebeat
Longtime Poster - Posts: 9105 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
I've bought one...
... like so much, somewhere 'in transit'...
- Mike Stranks
Mike Stranks wrote: ↑Sat Dec 03, 2022 12:46 pm I've just bought a new (to me) camcorder where the hot-shoe is very close to the front. This means even the usual suspects in the short-shotgun field are out of the question for run-and-gun because of visual intrusion when panning wide.
There are camera shoe bars available that allow you to mount to one side or behind the lens pickup area.
Turn the knobs 'til the music moves ya.
I'd be interested in a mini review once you're given it a workout.
Arrived today... does not intrude 'in shot' on full wide-angle even with 'fluffy' in place.
The audio is acceptable for what I want from 'run and gun' - more directional and mono compared to built-in mic array. If I need the video to be used for something 'important', judicious use of iZotope RX will deal with any shortcomings inherent in the mic.
Happy bunny!
Happy bunny!
- Mike Stranks
Forum Aficionado -
