How to Remove Mic Thread Adapter!
Re: How to Remove Mic Thread Adapter!
But note the overall diameter of the expanding bolt will need to be a bit less than 3/8” to fit in the hole (I’d use calipers to measure). They are normally sold by the size of the bolt that screws into the expanding jacket, so look for the jacket diameter, not the screw size.
I think every combination of extraction method has been aired here except seeing your friendly car mechanic and asking if he has a suitably sized stud extractor. The left hand thread will bugger the adaptor but as said, cheap as.
Just an observation. I have handled mic accessories on and off for 60 years and we were always careful to fit the adaptors 'slot out'. It has only been in the last couple of years or so that I have noticed with some cheap mics the adaptors now have a slot cut both ends. WTF weren't they ALWAYS like that?
What about a Dremel type affair to cut a new (crude) slot on the top/inside of the thread so you can use a (large) screwdriver to undo it. Don’t use WD40, it’s of limited use as a penetrating oil - Plus gas is far better.
I am fairly sure OP said the mic holder was plastic? In that case he has to be careful what kind of solvent he uses. I have never found WD-40 to attack anything.
I have a few of these... inherited from eBay buys...
I just use a 5/8-3/8 adapter if one is needed.
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Mike, I’m not sure we are looking for a simple and elegant solution here . . .
(Whether the idea works or not this is one of the reasons I love these forums, somebody always has the right idea!)
- ManFromGlass
Longtime Poster - Posts: 7473 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Breaking news people! It's out, I repeat it's out!
In the end it was simpler than I anticipated, but I think the WD40 (whilst maybe not the right thing) had helped overnight.
I basically jammed a large wide flat headed screwdriver in there as firmly as possible and applied pressure inwards whilst turning. Took a bit of oomph but it came out in the end.
Some pretty creative suggestions here though! Some easier than others.
I hear-by declare today a national holiday in celebration
- siderealxxx
Frequent Poster - Posts: 605 Joined: Sat Jan 24, 2009 12:00 am Location: Cambridgeshire
Excess makes the heart grow fonder
The Force was with you!
- ManFromGlass
siderealxxx wrote: ↑Tue Dec 06, 2022 1:21 pm Breaking news people! It's out, I repeat it's out!
Great! Now, put two blades in a 12" hacksaw and cut a slot in the other end of that adaptor!
Another thing I have noticed with the cheap mic adaptors is that many are now Aluminium. I dare say the subjectivist beardy tweaks will say Brass gives a 'denser' tone but I can live with that!
- siderealxxx
All sorted now. But for reference Plus gas is similar (ish) to WD40 but much better. It’s not a solvent but penetrating oil.
Mmm, that sounds familiar. Didn't..., someone..., suggest doing just that with one jaw of the pliers two pages ago?
Anyway, sometimes the beauty is in the travelling as much as the arrival.
Well done.
- shufflebeat
Longtime Poster - Posts: 9702 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
shufflebeat wrote: ↑Tue Dec 06, 2022 2:19 pmsiderealxxx wrote: ↑Tue Dec 06, 2022 1:21 pm I basically jammed a large wide flat headed screwdriver in there as firmly as possible and applied pressure inwards whilst turning.
Well done.
Granted and I did try, but I took you very literally and tried with my pliers which were in no way sized or shaped for the task. My simple brain didn't extend this idea any further!
Had you said 'the large flat red screwdriver in the bottom kitchen drawer' then then this thread wouldn't have run to, ahem, four pages! Impressive nonetheless.
- siderealxxx
- siderealxxx
siderealxxx wrote: ↑Tue Dec 06, 2022 2:38 pm Had you said 'the large flat red screwdriver in the bottom kitchen drawer' then then this thread wouldn't have run to, ahem, four pages! Impressive nonetheless.
Ah, I see where I went wrong. Well, I'll know for next time.
I like the sound of this, "Microphone Farm", very wise.
Also, "...some mics are more equalised than others".
- shufflebeat
A classic from George Aural.
Not many forums where you can get 4 pages out of removing a stuck screw! Well done
- resistorman
Frequent Poster - Posts: 2886 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Now I need to know if it was PlusGas Formula A, B, C, D or E?
I may be mad, but I'd find a book on the history of lubricants and penetrants rather interesting!
Fascinating range of products (here; Canadians love this stuff) from WD-40, 3-in-One, JIG-A-LOO, Liquid Wrench, Permatex, Honey Goo etc.
Or perhaps I don't want to know what's in the cans, and should stick to this formula?
Code: Select all
Start
Spray
Work?
If yes goto Stop
NewCan
Goto Spray
Stop
HaveBeer
End
You mean to say that "Goo Gone" doesn't do what it says on the label?
