Lead-in time for tracks
Re: Lead-in time for tracks
I usually have a lead in time of about 0.25 seconds.
...thanks, when I looked this up the other day I was finding 2 seconds which seemed excessive. Checking it again it sounds like this was recommended for CD, but unless you're releasing on CD I guess it can be shorter...?
2 seconds was kind of a default time between CD tracks. A 1/4 second or so is fine.
- resistorman
Frequent Poster - Posts: 2708 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Yes, for streaming, shorter is better. Listeners expect the track to start just about straight away.
A 2 second or longer lead-in is compulsory for the first track on a CD although the CD player skips that lead-in and goes straight to the index 1 on the first track.
I'd normally leave at least 0.1 seconds before the audio starts to give any player time to unmute before the start of the wanted audio.
Posts: 14431 Joined: Mon Sep 10, 2001 12:00 am
I've experienced quite a number of digital audio playback systems that fail to play the first 100-300mS of audio, from CD and DVD players decades ago to modern apps. Sometimes it's faulty programming and is fixed in an update; sometimes it's a hardware issue that will never change.
Whether you'd want to include a gap to take that into account would be up to you. I think no gap (very common) is foolish.
Unless it's for a CD, I normally leave 1 second of silence as a lead-in. I find if I'm using something like Soundcloud, that allows me to drag back to the start of the track and play almost instantaneously, whilst if I leave anything much shorter and drag back, the track always starts just after the beginning. Which sort of ties-in with Sonic's experience.
Wonks wrote: ↑Tue Dec 06, 2022 10:20 pm Unless it's for a CD, I normally leave 1 second of silence as a lead-in. I find if I'm using something like Soundcloud, that allows me to drag back to the start of the track and play almost instantaneously, whilst if I leave anything much shorter and drag back, the track always starts just after the beginning. Which sort of ties-in with Sonic's experience.
Soundcloud definitely needs a lead-in, it’s quite a bad offender.
I too standardise on a 1-second lead-in, by cropping the track start visually to the very start of its waveform, and then physically adding 1 second of silence (as others have mentioned, shorter lead-ins can occasionally result in the first note getting cut off in some applications).
I never use anything longer than 1 second, and it really annoys me when others do so, as after a few seconds have passed and you still can't hear anything, you're bound to suspect faulty playback.
I then adjust the spacing between tracks using the end of each track as required, adding extra silence if necessary.
Posts: 20682 Joined: Wed Jan 13, 2010 8:44 am
Interesting. I'll have to take that into consideration.
- resistorman
RichardT wrote: ↑Tue Dec 06, 2022 10:57 pmWonks wrote: ↑Tue Dec 06, 2022 10:20 pm Unless it's for a CD, I normally leave 1 second of silence as a lead-in. I find if I'm using something like Soundcloud, that allows me to drag back to the start of the track and play almost instantaneously, whilst if I leave anything much shorter and drag back, the track always starts just after the beginning. Which sort of ties-in with Sonic's experience.
Soundcloud also tends to need a bit of a lead-out as well.
Personally I find half-a-second tends to do the job but obviously this is not a consistent experience.
Forum Aficionado -
Posts: 24807 Joined: Sun Jul 05, 2015 12:00 am
