Do you always look at scales when composing?
Hi there. So I have been writing and producing music in many genres on and off for many years professionally and as a hobby. I generally never looked at scales when writing a song, unless a client requested something specific or I wanted to use an authentic Egyptian scale or something like that, but most of the time I just mess around with the notes and see what sounds "right" and of course it will end up in some sort of scale which is in tune, but I never think at the start OK I am going to use this specific key and scale. I just play notes and see what feels good. It seems to work. I wonder if other people are the same as me or not? Or do you like to choose a scale at the very start of your songs?
- firesoundwave
- Posts: 3 Joined: Tue Dec 06, 2022 12:05 am
Re: Do you always look at scales when composing?
Never. The only consideration I give is where I’m linking two compositions and I deliberately want a particular feel between. Even then I would first look at chord voicing on the preceding piece first if I can’t get where I need it I’ll consider a particular key.
Mind you I’ve lately being playing more guitar (being a pianist by training) and struggled with some of my compositions.
If you are working with other musicians then scale can be critically important. Vocalists will need a chosen scale that suits their vocal range, and some instruments are restricted to (or are difficult to play in) certain scales.
But if you're working on your own, then you just choose what works for you.
I should have added that to my post. I do work on my own.
I can only play in a limited number of scales, so my choice is almost always made for me, at other times, I put together in real time, chords based on the diatonic scale, I haven't a clue what I'm doing, but it sounds good to me.
I tend to feel my way around, and at least I know what notes, and combinations of notes, sound like before I play them.
No, virtually never.
Usually I just start noodling around on the keyboard and have no idea about key/scale at all. I only need to know what key it's in when I start to add accompanying tracks!
- Folderol
Jedi Poster -
Posts: 19871 Joined: Sat Nov 15, 2008 12:00 am
Not having any musical theory I wouldn't know what scale I was working in even when I'd finished.
But then I'd generally call myself a song-writer rather than a musician and definitely not a composer.
Posts: 28031 Joined: Sun Jul 05, 2015 12:00 am
No. I work on the principle that if it sounds good, then it is good.
Having said that I have changed the tuning of B string on my Bass VI to C which works better for two note chords and drone parts on the songs that are in Am
IAA wrote: ↑Thu Dec 08, 2022 9:09 amOr do you like to choose a scale at the very start of your songs?
Same here. I'll either spend some time at the keyboard working on voicings, or changing the keys to get a nice transition, or try all 12 keys by transposing in the DAW and hear what they sound like. Then some further massaging by living with the resulting topline for a while. Maybe some regret at ever trying to shove two different ideas together and be like Don Music for a while... So it's about voicing, scale, key, or mode... or all of them!
For a vocalist it's purely the key that pertains to vocal range. I assume most good vocalists won't have a difficulty with any scale (unless they're untrained and are bad at certain intervals, which is unusual IME) unlike as you say, certain scales are physically difficult on different instruments. My wife was practicing B minor on the violin today, or "Bitch minor" as she calls it
- Tomás Mulcahy
Posts: 2810 Joined: Wed Apr 25, 2001 12:00 am
Ditto, never. Knowledge is power and all that, but I want to write what's in my head, unconstrained by any consideration of scales or theory.
** wanders off to write another three-chord song in Am **
I'm a noodle and see what happens kind of guy too.
I actually more often than not start with a chord progression and work a melody into that later.
But I always strive for 'singability' for want of a better word, even if I'm working on an instrumental, I want to be able to hum it.
But thinking about a scale or mode first? No, I'm not that good a musician to even know.
Well music is an art not a science so it allows flexibility, that said it is the most scientific of the arts, for good reason, it can be a solitary or collective endeavour, so there has to be a universally agreed set of rules which everyone is bound by, otherwise it isn't music, it is noise.
What is beguiling about scales and keys is how the nature of a piece of music can change quite radically if played in another key, and by that I don't mean changing from major to minor, but one major key to another.
Additionally, what I do is I always avoid the 'always' paradox, one day you do this, and another day you do that - do you always not do something always? Seems a bit too restrictive to me, yes music is prescriptive by nature, but the rules are merely the compass we use when on our journey to the finished. Sometimes we might know our destination and sometimes, like Christopher Colombus, just set off and see where we end up
I think this is because of Equal Temperament. That causes the intervals to change, not the key as such. If we were Just Intoned the intervals would not change, But then we could not do key changes so easily. In other cultures, key is not such an issue. The singer decides, in Indian Classical music (North and South). I once tried printing the Moonlight Sonata in an easier to read key, and it sounded trite. When working with a singer and changing the range it's best when you have just a melody and chords. When it's a pre-produced arrangement it gets very messy.
- Tomás Mulcahy
The way I would look at it is : take a major third. It sounds different high up the keyboard from in the bass. In fact it sounds pretty terrible in the bass, and you could find your own lower limit for how low a major third can be used harmonically.
I think that would be similar in just intonation, although not quite as bad in the bass. Small intervals are going to sound bad in the bass.
I agree about transposing an arrangement, as some intervals could go below their lower limit.
Tomás Mulcahy wrote: ↑Thu Dec 08, 2022 5:53 pm
Yes but the melody and chords have to be in cahoots with one another.
As for the experiment, changing Moonlight Sonata to an easier key, I would have thought that to be futile, there is that unknown/undefined dimension in music that means the juxtaposition of notes is a critical component of it, that this note(s) played with other note(s) just sounds 'right'
A pal of mine who is a highly regarded performer round these parts and we have had this very discussion many a time over a pint, and he speaks of his frustration with other band members, the 2 guitarists in this case, and who are quite accomplished players, but sometimes leave out notes when playing a tune, because they are 'awkward' they play the painting by numbers version of a tune and it just don't land on the ears as convincingly. As you say, sounds trite.
I remember a documentary on TV some years and the subject matter was this - could a rap artist and a classical choir/ensemble 'gel'? could there be cross-over?
Goldie, the rap artist, played to the camera, trotted out all the cliches "I play from the heart and soul, not a piece of f*cking paper with scribbles on it.......etc etc etc"
The choir and ensemble weren't that fazed by his tantrums, in fact they were a tad amused by it, but they sort of said "We turn up at work, we know our job, we do our job, then go home, we don't make a big deal about it, but ever let anyone say we don't enjoy our music" And they were quite happy to suffer Goldie's tantrums - who at one point walked off set in a rage so to speak - though I expect this was playing to the camera, he had to come across as the rebel. Basically he was saying he didn't want his music constrained by the conventions of established musical norms. Hard to avoid convention when there was only 2 chords in it!
So the choir/ensemble said "Oh dear what a shame never mind, there's nowt as queer as folk, but, we've started so we'll finish"
And they went on to work on the music (of Goldie) doing new arrangements, stretching the music so to speak, seeking melodic and harmonic opportunities. And unsurprisingly, they excelled. Goldie was encouraged to play his part, listen to the finished object, and involve himself. On hearing the new arrangements, to his credit, Goldie paid homage to the classical player and singers, he was "blown away" and basically said "I get it now, all this chords and scales and inversions and such, I'm a convert and these guys(and gals) have got 'soul'
There was also another program on Channel 4 - Faking It. In one episode 3 people played the part of a DJ and the panel of 3 top professionals, DJs, Producers et al had to guess which of the 3 contestants was a pro Ibiza DJ. The contestants were a Pro DJ, and amateur and a young woman from the RNCM who was studying cello. She had never been near any decks in her life.
The contestants had a few days to put a set together. The young woman excelled, the panel of judges said it's clear who's the pro, by a country mile, it's the young lass, she's a natural - the judges were dumbstruck when they found out in fact the young woman was a classical cello player, asking how she managed it and she simply said, "Well I know my scales, I know my keys, I have a sense of rhythm, so can easily drop in on the right beat - it's no big deal, I am a musician"
In fact she was offered a job, though despite her really enjoying the challenge, she said thanks but no thanks, I'll stick with the cello
...right...I don't think I'd really made that connection. Huge difference then.
But it's not unknown. ET is a compromise. It's designed to minimise changes when you change key. It doesn't eliminate them, but it's better than what happens if you stayed with JT.
- Tomás Mulcahy
I just remembered something called Hermode tuning...have you come across that Tomás...?
http://www.hermode.com/index_en.html
OneWorld wrote: ↑Thu Dec 08, 2022 5:47 pm Well music is an art not a science so it allows flexibility, that said it is the most scientific of the arts, for good reason, it can be a solitary or collective endeavour, so there has to be a universally agreed set of rules which everyone is bound by, otherwise it isn't music, it is noise.
Even transposing a piece one semitone can make a huge difference.
I tend to start composing with a melody that I’ll sing into a recorder or DAW while the ideas are still there.
I don’t worry about what key it’s in, I just work out what chords work best for the supporting instruments and backing voices and don’t even think about if they’re using the scale notes of that key (assuming I did check what key it’s in).
