Looking at the 'big composition' for 2023
Post by Ben Asaro »
With Jamuary in the rear-view mirror and a scheduled week off to ruminate on all of the sounds and such from the month, I've been trying to come up with a single 'mission statement' for this composition, similar to my other big pieces. I've done a piece based on bell changes, with subtle changes and ever-shifting relationships between the notes ... I've done one with a chord progression that takes a full hour to resolve ... and I've challenged myself by recording a live performance using two of the most notoriously unwieldy synths (the Subharmonicon and Lyra-8) at the same time. I enjoy the fact that my big compositions tend to merge technological, philosophical, and music-theoretical related areas into a single piece.
Jamuary really got me interested in looping phrases ... and loops within loops. And combined with my late-2022 experiments with the 'timbral garden' and modulating modulators, and granular synthesis, and really looking at ways to sequence sound so that it's NOT just imitating a band from the '70s; particularly viewed through the lens of Minimalism.
So the mission statement I came up with is:
Microcompositions using waveforms that can be pushed into shapes and materials and then sequenced.
As for how it would look, I imagine it like being interconnected gears. In the center is the largest gear, representing my key center; this also serves as the function generator for the entire piece. This is made up of microcompositions composed of individual loops. Each loop can be an exploration of a motive, timbre, or rhythm/meter.
My plan is to start SMALL and get a proof of concept going first.
Ben Asaro
Posts: 2930 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: Looking at the 'big composition' for 2023
Where do we send the food parcels? :lol:
Posts: 19918 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by OneWorld »
Ben Asaro wrote: Thu Feb 02, 2023 3:37 pm With Jamuary in the rear-view mirror and a scheduled week off to ruminate on all of the sounds and such from the month, I've been trying to come up with a single 'mission statement' for this composition, similar to my other big pieces. I've done a piece based on bell changes, with subtle changes and ever-shifting relationships between the notes ... I've done one with a chord progression that takes a full hour to resolve ... and I've challenged myself by recording a live performance using two of the most notoriously unwieldy synths (the Subharmonicon and Lyra-8) at the same time. I enjoy the fact that my big compositions tend to merge technological, philosophical, and music-theoretical related areas into a single piece.
Give Steve Reich a call, he’s been down this road
OneWorld
Posts: 5307 Joined: Tue Apr 07, 2009 12:00 am
You're a brave and inspiring man Ben! :clap:
Posts: 21676 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by resistorman »
Martin Walker wrote: Thu Feb 02, 2023 10:13 pm You're a brave and inspiring man Ben! :clap:
Amen!
resistorman
Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by BJG145 »
Sounds intriguing - look forward to seeing how this develops. :thumbup:
Posts: 7736 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Ben, are the individual loops, elements synchronised, or free running, or do you have the option to do both?
Posts: 19916 Joined: Sat Jul 12, 2003 12:00 am
Post by Ben Asaro »
Arpangel wrote: Fri Feb 03, 2023 10:09 am Ben, are the individual loops, elements synchronised, or free running, or do you have the option to do both?
If by syncronised you mean fed from a single clock source, then the answer is probably not.
If by syncronised you mean played in time, I am sure there will be elements that will be played that way because syncopation is fun.
Ben Asaro
Ben Asaro wrote: Fri Feb 03, 2023 1:32 pm
Sounds interesting, look forward to hearing it.
Post by Ben Asaro »
Thanks! I just hope it doesn't end in a train wreck! :D
Ben Asaro
Ben Asaro wrote: Fri Feb 03, 2023 1:49 pm Thanks! I just hope it doesn't end in a train wreck! :D
Even if it does, I suspect it will still be an enjoyable listen ;)
Post by adamburgess »
What a great way to start a piece. Really interesting mindset!
Looking forward to see what transpires :clap:
adamburgess
Posts: 186 Joined: Sat Nov 03, 2018 12:18 pm
Re: Looking at the 'big composition' for 2023?
Post by RichardT »
It’s a very interesting idea - my only comment is that almost all the key centres are very closely related to the main key centre. Is there a way some of them could be a bit more distant? It might create some intriguing effects.
RichardT
Posts: 4992 Joined: Fri Aug 13, 2004 12:00 am Location: UK
Post by Ben Asaro »
RichardT wrote: Fri Feb 03, 2023 6:35 pm It’s a very interesting idea - my only comment is that almost all the key centres are very closely related to the main key centre. Is there a way some of them could be a bit more distant? It might create some intriguing effects.
Good observeration -- This is just an example of the overarching concept, not the actual score. I also find it helpful to start with very simple lines when first trying out something this big.
The main key center is also the function generator for the overall composition and there's no rule that says that it can't change. For now, though, I'm avoiding modal interchange until I know the core concept works!
Ben Asaro
Post by Ben Asaro »
As a side point: everyone is free to take this idea and run with it. None of these ideas are proprietary by any stretch!
Ben Asaro
Post by tea for two »
Just before like literally a day before Ben returned to the forum Dec15
I had a subconscious wish that Ben was back on the forum :beamup:
Universe made it real.
Ben was going to return anyways.
Just occured next day after I subconsciously wished it :crazy:
We can all do this with our wish.
Our wish has to be
1.Subconscious. We cant force think it force wish it.
2. Local and small. Then it maintains balance of the universe. Anything larger or global doesn't occur as it upsets the balance of the universe
3. Selfless and decent. Then this is most likely to occur. Although subconsciously wishing for ourself also works if it doesn't do anything adversely to anybody and won't harm us down the line.
There's that saying be careful what you wish for well it's subconsciously wishing for ourself things that unknown to us would harm us down the line.
So to be safe not sorry our subconscious wish should be selfless decent.
Right as you were.
Ta. :lol:
tea for two
Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
Post by Ben Asaro »
Ben Asaro
Ben Asaro wrote: Fri Feb 03, 2023 7:22 pm As a side point: everyone is free to take this idea and run with it.
We may be free to do it but it doesn't mean we're all capable of doing so! :D
But thank you anyway. :)
Posts: 28092 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Ben Asaro »
Hot on the heels of Jamuary, I was working out of town all last week. I am back home today and looking forward to starting work on the proof of concept for the new composition!
I have a kind of floaty idea in mind that I wanted to try in Jamuary but never got round to it. Let’s see if I have better luck this time! :D
Ben Asaro
Post by Ben Asaro »
Another looper arrived in the post yesterday, a BOSS RC-1. This gives me a mono looper for guitar and a stereo looper for everything else at the ready.
Part of the proof of concept is for me to come up with the instruments I would like to play -- because in an ideal world I will be collaborating with others on this -- and for the modular I'm going to try to use Euclidean Circles to generate complex melodies. Here's v1 in block diagram form:
The idea is that the VCOs are generating set pitches with the NerdSeq acting as a shift register, and keeping the note choice very simple: I am going to start with 4 pitches.
Euclidean Circles will be used to create interlocking melodies by opening each VCA based on their patterns. I guess the biggest question is WHY am I doing it this way? The short answer is: to avoid falling into the trap of repeating myself. By stepping away from the idea of 'step sequencing' and preconceived melodic ideas. By forcing myself to slow down and really commit to a note choice.
Will it work? Dunno! :D
I'll be testing it over the weekend, tho!
Ben Asaro
Post by MarkOne »
Ben Asaro wrote: Fri Feb 03, 2023 7:22 pm As a side point: everyone is free to take this idea and run with it. None of these ideas are proprietary by any stretch!
Are we though? Given the most current understanding of quantum physics this is a deterministic universe, so given a set of conditions everything is ultimately predictable, so are we really free to do anything? Just sayin’
MarkOne
Posts: 2989 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
Post by Ben Asaro »
Ben Asaro
Post by OneWorld »
Ben Asaro wrote: Sat Feb 18, 2023 11:38 pm First "Euclidean Melody" test, https://soundcloud.com/user-329043613-5 ... al_sharing
Reminds me of this, sort of, same sort of template, isn't it?
https://www.youtube.com/watch?v=_ZlFOZMPbdY
OneWorld
Post by Ben Asaro »
Same idea but in stereo using a second filter, another channel on Euclidean Circles, and a 5th envelope.
Ben Asaro
