Cheap CD player to hook up to Yamaha MG16X 16-Channel Mixer and how?
Re: Cheap CD player to hook up to Yamaha MG16X 16-Channel Mixer and how?
Post by OneWorld »
I use the Alesis Masterlink 9600
They have phone and SPDIF i/o and you can also copy the contents of a CD to the internal hard disk.
You can have a maximum of 16 playlists on the HDD and each playlist can have a number of songs in it, I can't remember how many now but it is a significant number.
Alesis stopped making these eons ago, but they still turn up on the usual 'pre-loved' sites and at reasonable prices. Erm - I just checked on eeebHay, WOW the prices have shot up :thumbdown: Might be worth keep checking though
I have found mine to be very reliable (fingers crossed :roll: )
OneWorld
Posts: 5286 Joined: Tue Apr 07, 2009 12:00 am
Post by Rene Asologuitar »
punkyfish wrote: Thu Feb 02, 2023 8:20 pm Hi,
I want to hook up a CD player to our mixer but need help with:
1. A relatively cheap CD player that will do the job playing backing tracks
2. What cables I need to be able to do it
Am based in UK, thank you for any help
I have a Yamaha MG8x, and I use an RCA cable to hook the player to, and it works great!!!
Rene Asologuitar
Posts: 76 Joined: Sun Mar 06, 2022 5:06 am
Post by punkyfish »
If a CD player has a headphones input Jack, will that work with a cable to my mixer? Struggling to find a CD player
punkyfish
Posts: 61 Joined: Sat Mar 16, 2019 11:59 am
A headphone socket is an output rather than an input, but yes, it should. As Wonks said above, you'll need a lead with a 3.5mm jack at one end and two RCAs at the other.
Posts: 28013 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by punkyfish »
Thank you very much
punkyfish
Post by sonics »
If you have a CD player, use the line outputs, NOT the headphone socket, please!
sonics
Post by punkyfish »
I'd replay tracks stored* on a phone or mp3 player. You'd need a 3.5mm mini jack to dual RCA-phono plug lead to run from the player's headphone output to mixer input.
If the mo3 player has a usb-c input, will a usb-c to rca work as well? Thanks
punkyfish
USB is a digital connection and the headphone socket analogue. A USB C to dual phono lead must have a D/A converter built in. You are more likely to find a USB C to 3.5mm TRSF socket though.
* Unless, I suppose, it is SP/DIF I/O or a video format but I've never seen one of those.
Posts: 21880 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by OneWorld »
punkyfish wrote: Fri Feb 03, 2023 7:39 pm Struggling to find a CD player
There are lots on eBay, from £20.00
CD Recorders too.
Might be worth checking out charity shops, the one local to myself has them in each week, though the majority tend to be those mini-bookshelf 'music centres' you could still detach the tuner and whatever and just use the cd player
OneWorld
Post by Mike Stranks »
OneWorld wrote: Mon Feb 06, 2023 12:48 am
CD Recorders too.
Yup!
This time last year I helped dispose of the gear of a late friend (Covid victim).
There were 4 or 5 CD-players/recorders... and good ones too!
I had no trouble disposing of them via eBay, even though I'm reasonably rural and it was 'Buyer Collects'.
(A word of caution on the mini-systems. Some of the ones I've seen that appear to be 'separates' use proprietary 'all in one' - mains and signal- interconnects between the units, so not easily used in standalone mode.)
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
As has been said, CD players are prone to vibration issues. You can live with the occasional glitch if just for interval music, but not during performance if it’s a backing track.
Which is why if you must go CD, I’d suggest a portable ‘Discman’ style one (normally round). These at least would be designed to cope with a certain level of vibration on the move and have a much larger internal read-ahead data buffer than a domestic hi-fi CD player so that they can play back from the buffer whilst the device tries to re-read any disc data lost due to the player being shaken.
But as has been said, a phone or tablet is a much better playback device for playing backing tracks and that’s what I’d use.
Posts: 18250 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by BigRedX »
These days I would even think about considering a device with moveable parts for audio playback in a live situation.
BigRedX
Posts: 2800 Joined: Fri Sep 03, 2004 12:00 am
Post by OneWorld »
Wonks wrote: Mon Feb 06, 2023 8:24 am As has been said, CD players are prone to vibration issues. You can live with the occasional glitch if just for interval music, but not during performance if it’s a backing track.
Yep I have one of those. And it plays faithfully everytime I use it, and it's at least 20 years old
OneWorld
Post by punkyfish »
Thank you for all replies.
I think I am going to look at an mp3/lossless audio player something like this, however they only seem to have a usb c socket. Can someone suggest something that might work with something like this:
https://www.amazon.co.uk/gp/product/B09 ... R097K&th=1
Thank you
punkyfish
That has a headphone socket (as I'm sure nearly all do even in our wireless world) which, while it's not the perfect solution, will work fine as an output to the PA desk. You could buy one of these https://www.amazon.co.uk/VENTION-Auxili ... B085DYRDXZ but I doubt you'll see any quality improvement over using the headphone output.
BTW do you have an old iPhone/'droid? With a suitable playout app that would be better than a cheap .mp3 player.
You’d use the 3.5mm headphone output to connect to the mixer.
Either a 3.5mm TRS to 2xRCA cable if you use the RCA inputs on the mixer, or 3.5mm TRS to two 1/4” TS jack plug cable if you want to use a stereo channel.
I’ve used both in the past, though I normally prefer the stereo channel approach as you normally have tone controls available and with the RCA inputs you tend not to.
Being a headphone output, it is possible to overload and distort the mixer inputs at full output volume on some players, so play with the output level (and any input gain control you may have) for best results.
Post by sonics »
One of best little media players would be an older LG phone in the "V" series. The V20/30/40 etc. They have a great-sounding DAC. I'd suggest using UAPP or PowerAmp for playback.
An iPhone with the official Apple DAC (headphone) cable is another great option.
sonics
An older iPhone with a headphone socket (iPhone 6S or earlier) would also work well, still capable of running the latest iOS and apps and pretty user friendly.
Sam Spoons wrote: Mon Feb 06, 2023 5:41 pm An older iPhone with a headphone socket (iPhone 6S or earlier) would also work well, still capable of running the latest iOS and apps and pretty user friendly.
You’ll need something like an iPhone 8 or newer to run the latest iOS 16 (v16.3 at time of writing), though a 6 or 7 will run iOS 15.
But a phone of that age will probably need a replacement battery, and the controls get increasingly dodgy. Before it died completely, my 6S battery lasted only a few hours at most if being used, and then the side on/off/lock button stopped working.
Post by OneWorld »
Wonks wrote: Mon Feb 06, 2023 5:52 pm
I've had that experience too. It is difficult to know exactly what the OP wants to spend. There are lots of options, depending on budget. In fact old CD players are so cheap that 2 of them could be purchased, with one as a spare, or even buy an old laptop, they have CD/DVD players.
What I do know is that I got a relatively decent phone to play back files but for some reason it started playing silly bug*ers (no that's not a tune, AFAIK) and as far as I could tell it was cheaper to buy a replacement phone than get the existing one replaced. And with today's tendency to use parts, even the battery, that can't be replaced so easily, well suffice it to say, that despite one poster's advice that anything with mechanical moving parts should be avoided, well The Flying Scotsman is still going, but there again the parts have been changed/replaced - you can't do that with an iPhone and ironically enough, my old CD player has outlived 2 smartphones!
OneWorld
Post by sonics »
The LG V20 phone is one of my favourites. It has a removable battery, and will also connect to my external DAC for lossless playback of files and Tidal. It sounds noticeably better than my iPhone 6 using the headphone socket. They cost from about £50 used. Still available new, as well.
You could also use a tablet if you wanted a bigger control surface, of course, although I see that phones are getting huge again! That latest iPhone is ridiculously chunky IMO. :)
sonics
Have not followed the whole thread but if CD players are now rare/expensive look for a DVD player. They will play CDs but you can also store a shedload of MP3 on one.
No idea how bump-proof they are but if it were I, I would in any case use a Minidisc recorder. Mainly because I have two and lots of discs.
Posts: 18095 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
ef37a wrote: Mon Feb 06, 2023 9:37 pm Have not followed the whole thread but if CD players are now rare/expensive look for a DVD player. They will play CDs but you can also store a shedload of MP3 on one.
Just be careful to check the outputs as some only have an HDMI out.
Post by punkyfish »
Wonks wrote: Mon Feb 06, 2023 1:57 pm You’d use the 3.5mm headphone output to connect to the mixer.
Hi thank you for your reply, where do I plug the 1/4” TS Jack plug cable in on the mixer?
punkyfish
