DI box for guitars to mixer
Re: DI box for guitars to mixer
I don't think running an electric guitar straight in sounds "dreadful" at all! I like to do it with mine, and several clients of mine have done the same on our projects. In fact, for many of my songs, I much prefer it over an amp or emulator. I will use an amp or sim for a lot of things, but not all.
- resistorman
Frequent Poster - Posts: 2693 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Punkyfish, what are you actually trying to do?
You’ve posted in the live sound section so is this -
1) About how to get instruments into your mixer for the purposes of putting them through a PA for a gig?
2) About how to record a band at a live gig?
3) About how to record a band in a studio?
4) Some specific variation of the above?
Until we know, all we can do is speculate, which means that a lot of the answers given above are probably unhelpful and confusing to you.
We can provide solutions to specific problems, but until we know what that problem is, you are going to get a lot of replies that fly off at tangents that don’t help at all and confuse matters.
So we first need to know just what you are trying to do. More questions will follow, but knowing what you are trying to do will allow us to ask meaningful questions.
resistorman wrote: ↑Sun Feb 05, 2023 12:46 am I don't think running an electric guitar straight in sounds "dreadful" at all! I like to do it with mine, and several clients of mine have done the same on our projects. In fact, for many of my songs, I much prefer it over an amp or emulator. I will use an amp or sim for a lot of things, but not all.
I think it depends on genre and whether the guitar is clean or heavily distorted?
I was first introduced to speaker emulation at Blackstar and its main purpose was to make an over driven guitar signal sound acceptable through a pair of hi-fi speakers. But there is also the safety of the tweeter to consider. Highly rated and protected active monitors and PA tweeters might be in little danger (but not none!) but domestic hi-fi will be.
I have dug out some numbers for a pedal and the EM response is -4.4dB ref 1kHz at 5kHz and -19.5dB at 10kHz. The natural pedal response does not extend much beyond 15kHz anyway.
But yes, we need the OP's precise MO.
Also - what's the acoustic guitar?
- shufflebeat
Longtime Poster - Posts: 9105 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
As promised, I plugged my plywood 'P' bass into line input 3 of my Behringer mixer. With channel pot at vertical ('0' dB) and the Main Mix fader at '0' as well I could easily get enough gain to hit +6dB on the LEDS. I could have pushed it harder but feared for my Tannoy 5As. Many a dad's Kef Chorals have been borked by a bass guitar!
It sounded just as I would expect a bass to sound and so, as I suspected, there is no real need for a 1meg input for bass G.
Chet Leeway wrote: ↑Sat Feb 04, 2023 10:26 pm My response was built on the assumption that you wanted to use the mixer for practice, rehearsals, jams or small gigs.
Hi, yes bang on. I think I thought I could do the same using the mixer and it would work, because I can do that with the focusrite. Sorry if I wasn’t clear.
Apologies, I would like to put a bass guitar, electric lead guitar, keyboard/synth, electro acoustic guitar through the mixer which then goes to Yamaha powered speakers.
I’m a singer so fine with mikes however no experience of anything else. I have been given this equipment so trying to fathom out how everything works. I don’t have guitar or keyboard amps and the focusrite addition was purely to explain that I can plug the instruments straight in, which I thought I could do with the mixer.
Any help with that would be amazing thank you.
I also want to ask about electric drums and do they plug in, never used before and don’t have yet, but maybe that would be better as a separate post?
All help gratefully appreciated!
Probably this is or a fender strat, purely for finger picking accompaniment for a ballad.
https://www.gear4music.com/Guitar-and-B ... -Burst/5K2
Thankyou
Short answer: yes you can plug instruments into the line inputs of your mixer.
Longer, and more nuanced answer: Electronic sources — keyboards, synths, electronic drum kits etc — can be plugged straight into the line inputs of your mixer without problems.
You can also plug electric guitars and basses straight into the line inputs and you will get sound out. It may be low level, though, and the tonality will be different to the sound from a proper amp.
Part of that is related to the lower input impedance (a mixer line input is typically 10-50k Ohms, while an amp or dedicated DI input is typically 250-1000k Ohms). There's also a difference in frequency response since a mixer line input will be flat beyond 20kHz, while a guitar amp will roll off quite quickly above 5kHz. This is why 'cab emulation' is so popular.
Acoustic guitars are often equipped with piezo pickups which work best into an even higher impedance of 10M Ohms, but many have an onboard preamp which is usually happy feeding a mixer line output directly.
The usual solution to addressing the impedance mis-match and low-level compatibility problems with electric guitars and basses is to use DI boxes.
The guitar/bass plugs into the DI box which presents much the same high impedance as a normal amplifier. An isolated balanced output at mic level is connected to a mixer's mic input. The DI box's electronics are normally powered by phantom power from the mixer.
There are hundreds of different DI boxes on the market. Some are passive, but active designs are generally thought to be better. Some include filtering options to emulate the real-world speaker/cab roll-off.
Generally, you get what you pay for, with more expensive models being more robust, better sounding, and more feature-laden... but there are some real bargains to be found. For your kind of application I'm a big fan of the Orchid Micro DI.
https://www.soundonsound.com/reviews/or ... s-di-boxes
Posts: 39033 Joined: Fri Jul 25, 2003 12:00 am
Small point Hugh? Guitar amplifiers generally don't have a rapid roll off around 5kHz, most sustain HF to around 10-15kHz and then roll off gently.
Were this not the case there would be no need for emulation in load boxes or indeed the emulated outs fitted to some amps (cough!) in addition to the 'flat' FX send.
It is the guitar speaker that starts to give up at about 5-8k and is is pretty done by 12kHz. This filters out the 'fizz' of distorted guitar.
Yes, OP can plug pretty much anything 'line' level into his mixer. Might not sound too good but as I said, have a do with the EQ.
I was using the term 'guitar amp' to refer to a typical complete combo setup delivering an audible output with which the OP would presumably be familiar and naturally compare to the direct (DI) sound through the mixer.
But I agree with your point about the frequency response of the electronics in isolation.
Hugh Robjohns wrote: ↑Sun Feb 05, 2023 4:01 pm
We have grokked.
Hugh Robjohns wrote: ↑Sun Feb 05, 2023 12:13 pm Short answer: yes you can plug instruments into the line inputs of your mixer.
Got it! Thank you so much for your help and patience!
Are you planning do away with all the amplification apart from the mixer/PA speakers?
If so be aware that for some instruments (especially electric guitar) the amplifier is an important part of the overall sound of the instrument, so you will need some way of replicating that sound without having an amplifier and speakers.
RockinRollin' VampireMan
BigRedX wrote: ↑Mon Feb 06, 2023 5:24 pm Are you planning do away with all the amplification apart from the mixer/PA speakers?
With all respect, that is your opinion for a specific set of sounds and not a requirement for all players and situations. As I mentioned earlier, I often like my electrics plugged in directly, the raw sound can be beautiful, especially fingerpicked. Plucked?
- resistorman
However, for the OP’s benefit I’ll state that plugging an electric guitar straight into a mixer and PA may be acceptable and even desirable for a small number of players, but for the vast majority it’s not, especially if playing anything other than clean sounds.
And even if you like the sound of full-range distortion on an electric, unfiltered by a guitar speaker or a speaker emulator, it’s likely the audience won’t appreciate it much, especially younger people with better high-frequency hearing.
Maybe if the OP could give some examples of tracks the band sound similar to, especially if they heavily feature electric guitar, it would help our understanding.
But without that, as the OP is very new indeed to all of this, it would still be better to play safe and use a pedal that has amp and cab/speaker emulation.
I agree Wonks and since OP needs a high Z input anyway he could look at a multi-effects pedal? They start at 40 quid for a Behringer, 70 odd for a Zoom and then the sky's the limit. Some might even have speaker emulation.
I have a similar mixer, and I use acoustic/electric guitar, and I plug in directly, and I have no issues!!!
- Rene Asologuitar
Poster - Posts: 76 Joined: Sun Mar 06, 2022 5:06 am
Rene Asologuitar wrote: ↑Mon Feb 20, 2023 1:14 am I have a similar mixer, and I use acoustic/electric guitar, and I plug in directly, and I have no issues!!!
Fine, but as I and others have said, other peeps MMV. I have touched on the risk to tweeters but another fact is that guitarists that play through FOH PA are BEHIND the speakers! What might be a nicely balanced sound to them can be ice pick, bat bothering HF torture to those out front! Add to that the problem that many guitarists play far too loudly anyway!
