Alternatives to RME?
Re: Alternatives to RME?
At one point I couldn't see the point of Total Mix, it seemed to be made complicated just for the sake of it. I had come from other interfaces where the setup was far easier and intuitive.
Then I started reading the manual and it all became clear to me, and in fact, logically, it makes perfect sense, simplicity itself. Thing is, there is a lot of simplicity, it aspires to accommodate any setup.
Now, if and when I update my interface, I would be reluctant to move away from RME because I like the Total Mix so much.
You don’t have to leave the RME stable or lose TotalMix to update your interface. A Digiface USB lets you to use an interface of your choosing (assuming ADAT inputs/outputs). The Digiface might seem expensive for a box that doesn’t really do anything (no preamps or converters), but I’ve recently gone down this route and it’s a revelation. I can pick and choose a collection of preamps and converters for input and a completely separate set of gear for output. And I’m confident RME will continue to update the driver for years to come making the whole rig as future proof as I could realistically expect.
- Essex Boi
Poster - Posts: 86 Joined: Thu Dec 22, 2022 1:10 pm Location: Not the bit of Essex on the telly
Reality is merely an illusion, albeit a very persistent one.
This is in no way a stab at the German people, every nation, and its people, have their characteristics.
German software, TotalMix, Samplitude, Reaktor, Reason, all have this initial intimidation, they seem overly complicated, it’s like, the designer is working in a bubble, and isn’t thinking about the large variety of end users, and how they might cope with it.
I have Reaktor, and Reason, I can "use them" but do I have the "big picture" in my head? no, I muddle through not really knowing what I’m doing.
British software is sort of like this, but not quite, I do find American equipment, and software instantly easy to understand and user friendly.
Arpangel wrote: ↑Tue Mar 21, 2023 8:07 am
And this is in no way a stab at Arpangel, who definitely has his own characteristics.
You do talk some bobbins sometimes!
I've used recording/DAW software in one form or another since the 1980s and I've never noticed a geographical pattern in how it does whatever it does.
All software has a learning curve and different people process that curve differently due to their varying experiences, needs, likes and dislikes. It's just a matter of progressing through each learning curve and finding things that suit one's approach.
All but the most basic software seems intimidating and overly complicated until one is used to it. Whether one takes the time to get used to it depends on whether the rewards justify the effort and whether they can be achieved in a way which suits the user better than another bit of software.
- forumuser840717
Regular - Posts: 481 Joined: Thu Jun 16, 2016 5:20 pm
forumuser840717 wrote: ↑Tue Mar 21, 2023 9:47 am
Arturia great, Valhalla same, Reaper took me about 10mins to learn all I need, coming from Samplitude it was a revelation.
Samplitude was impenetrable, Reaktor same, Kontakt same, Reason you go in you can't find your way out, it’s a maze.
All of the above are great programs but some seem to make it as difficult as they can for to do what you want to do, easily.
Not all of us are computer experts, and don’t what to be, sometimes it’s like these things are designed by engineers for engineers, not musicians.
Regarding certain equipment, software, we have our opinions, and mine aren’t going to change, it’s good there’s enough out there to please most people.
Germany believes in technical education. It shows in their approach to many things, including product design. Personally, I like that!
If you invest some effort into reading the manual and understanding the underlying mindset these products are phenomenally powerful and remarkably straightforward to use. If you don't, they aren't and appear complex and impenetrable.
In which case, go find something simpler that better suits your level of involvement.
Posts: 42172 Joined: Fri Jul 25, 2003 12:00 am
Hugh Robjohns wrote: ↑Tue Mar 21, 2023 10:28 am
Germany believes in technical education. It shows in their approach to many things, including product design. I like that!
Basically, some of us, like me, are idiots regarding certain technical things, we aren’t all created equal, unfortunately some designers don't take this into account, that’s why I like American stuff, they know how to "idiot proof" things. What they remember is that idiots, are also "customers" too.
My particular affliction is a block regarding numbers, maths, a complicated page of software does the same, puts my brain into melt down, a mental panic that I find paralysing.
I've recently moved over to RME, and I've found TotalMix to be pretty logical. Anything that comprehensive will always have a bit of a learning curve, but it could certainly be a lot worse. I've not spent too much time with it, but I've simply hidden the various bits I don't want or need and labelled everything to match my I/O, that's made a big difference.
Why should they? Making something genuinely idiot proof inherently also simplifies it, reducing it's versatility and capability. I get why some designers and manufacturers aren't prepared to do that.
They're aiming products at people who appreciate the design capabilities.
If you don't, find something simpler and be happy with that — but don't criticise a product you simply don't understand or can't be bothered to invest effort in understanding.
It's probably a bigger market!
Seriously, though, idiots and braniacs can both be served by the asme product. I must admit, I preferred the older version of Totalmix, before the DSP FX came along and necessarily made the interface busier. But the whole point about it is that a 'friendly' view is possible, and so too is lots of logically laid out info in one screen...
- Matt Houghton
Frequent Poster - Posts: 1486 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
German software impenetrable???
I have one word to say - Cubase
There must be a reason Cubase became to go to DAW for many people
If anyone needs a coder to produce instantly accessible software, I'd suggest go see the coders at TikTok, it's almost become addictive, no wonder the USA wants the forced sale of TikTok, so FaceBook can buy it and get at those algorithms they can't figure out - You heard it here first
Rubycon-Stratosphere wrote: ↑Sun Mar 19, 2023 9:45 pm
If you take the Fireface UFX+…to be honest, who needs that much I/O‘s?
I do, i've expanded it with a 32 channel Ferrofish as well - lots of hardware fx and instruments over here...
AND I use a patchbay....
Same here - once the input and output names reflect your real-world hardware, TotalMix becomes a lot clearer.
Posts: 21642 Joined: Wed Jan 13, 2010 8:44 am
Hugh Robjohns wrote: ↑Tue Mar 21, 2023 10:48 am If you don't, find something simpler and be happy with that — but don't criticise a product you simply don't understand or can't be bothered to invest effort in understanding.
Maybe I should stop beating about the bush and just say I don’t like the sound of it.
Can we stop now, please?
Everything that could possibly be said has been said - some of it several times.
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote: ↑Wed Mar 22, 2023 10:12 am Can we stop now, please?
I’ve said what I’ve said, yes, let’s stop.
To their credit my old fireface 400 worked straightaway on being re-connected, what a relief that was!
- rggillespie
Regular - Posts: 242 Joined: Wed Aug 29, 2018 8:24 am
Sorry to hear of your woes.
I've just reviewed the new RME Digiface AES. It came with a thick user booklet in English and German, as have all the other RME interfaces cos I've reviewed or bought over the years. So I'm surprised the UCX II didn't have one.
I downloaded and installed the DF-AES drivers, rebooted the computer, and it all worked as expected. TotalMix FX looked and worked as I expected. Audio went in and out of the DAW with no problems once I'd selected the appropriate I/O channels, and configured the clocking. The unit's display screen presents a lot of info, but it's fine once you know what's where.
The UCX II is getting quite long in the tooth now and I imagine an updated model will be along soon...
I have zero interest in this kit and will never be buying one.
Out of interest, I just put the product name into a well-known search engine, and the first thing that came up was RME's own page header about the product. On that page, I clicked 'Downloads' and found what appears to be a detailed User Manual for both Windows and Mac installs...
- Mike Stranks
Yes, all of RME's manuals are available and easy to find online, but I think rggilespie was upset that a hard copy wasn't in the box — something that I find very odd as every RME product I've seen has included comprehensive paper manuals.
I'm at the point where I don't care what interface anyone buys and will not be offering any recommendations
Unless maybe it's for some special use case where I have direct experience that will help solve a specific problem
- resistorman
Frequent Poster - Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Obviously a Pick'N'Mix selection, so you point out the number and type of inputs and outputs you want to the assistant. They then scoop them up into a paper bag for you, weigh it, and ring the price up on the till.
