Hi
I am confused Can i use a powered mixer with powered (active)speakers ?
Or better I use powered (active) speaker with unpowered analogue mixer ?
Please help
Re: powered mixer with powered (active)speakers ?
- resistorman
Frequent Poster - Posts: 2699 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
This has been covered in the OPs previous thread
here: https://www.soundonsound.com/forum/view ... hp?t=85874
- Bob Bickerton
Longtime Poster -
Posts: 5095 Joined: Fri Dec 20, 2002 12:00 am
I'll lock this topic - if you want to continue the discussion please follow the link to the previous thread which covers the same ground.
Posts: 14392 Joined: Mon Sep 10, 2001 12:00 am
This has been explained already in your previous thread.
Active speakers have integrated power amplifiers. They only require a line level input from a standard mixer (analogue or digital). The Dynacord CMS 1000 Mark 3 you decided on previously will be fine.
A powered mixer has an integrated power amp designed to drive passive speakers... but you have active speakers so a powered mixer would be inappropriate.
Yes!
EDIT: Slipped in under James' lockdown!
Posts: 39099 Joined: Fri Jul 25, 2003 12:00 am
