Hello everyone,
I have a Roland HD1 e-drum kit. Worked fine with Toontrack. But looking for something more touch sensitive. Still, I need the small size the HD1 has as my room is small.
I could upgrade the snare by a more expensive one? Or is there a full drumkit (just as small) but with better trigger quality? I don't care about the sounds as I'll be using Toontrack anyway.
upgrade to Roland HD1
- Guitarking
Regular - Posts: 282 Joined: Sat Jan 09, 2010 12:00 am
Re: upgrade to Roland HD1
I don't know much about digital drums, but I'm wondering about the touch sensitivity. Since midi velocity has a set range, is the problem that the velocity is "bunched up" in parts of the range? Are there different curves you can apply, either on the instrument or in Toontrack?
- resistorman
Frequent Poster - Posts: 2887 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
The HD-1 has five different sensitivity settings, what's currently set to?
I'm a very light touch drummer (because I'm not a drummer) and I have no issues with the sensitivity of mine.
I don't think I've seen anything of a notably better quality that'll give you the same small footprint - might be worth looking at upgrading the snare but I'm not sure what the compatibility is like.
Posts: 28092 Joined: Sun Jul 05, 2015 12:00 am
