Harmonic Bloom - Extra presets and 25% off!
Post by SonoraC »
Awarded a 5 star review by Paul White in the latest issue of Sound on Sound, Harmonic Bloom exploits the concept of the harmonic series to turn noise into unique and distinctive musical material that can be used in your compositions.
From calm and reflective organic soundscapes to dark and imposing mechanical pads and textures, Harmonic Bloom offers an awe-inspiring array of sound design possibilities – and that’s just with the built-in noises and sound sources! Import your own samples into the easy to use interface to craft rich, complex and captivating instruments like no other!
As Paul said in his review... "...the combination of the Main samples and the harmonics coaxed from the Noise section can make for some hauntingly beautiful sounds, from ethereal pianos and plucks to warm and washy pads. I wasn’t sure what to expect when I first encountered Harmonic Bloom but I’ve quickly grown to like it very much and I suspect that musicians into ambient styles of composition will find it especially attractive."
Until 20th April, there's 25% off Harmonic Bloom and we also recently released a new update adding 60 more presets!
Find out more here > https://sonora-cinematic.myshopify.com/ ... -cinematic
SonoraC
Posts: 41 Joined: Tue Apr 26, 2022 11:10 pm
