TC Electronic G Major 2 - tap tempo newb question
For all tech discussions relating to Guitars, Basses, Amps, Pedals & Accessories.
Post by SecretSam »
If any of you know the G Major 2 ....
The manual talks about tap tempo. But I can't figure out where to, you know, tap.
Via a momentary footswitch would be good. Also, by poking a button on the front panel would be handy sometimes.
Can anyone tell me?
SecretSam
Posts: 2935 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
Re: TC Electronic G Major 2 - tap tempo newb question
The manual is remarkably unclear on that subject isn't it? Have you tried tapping the delay button when in the tap section of the global menu?
Posts: 28116 Joined: Sun Jul 05, 2015 12:00 am Location: York
Apparently you can plug in a momentary switch into the expression pedal input and set the Tap Tempo (in Mod) to pedal
And it can be done via a MIDI foot pedal as well. Somehow.
Posts: 18329 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by SecretSam »
Thanks, Wonks and Drew. I'll try that momentary foot switch thing. The other thing the manual doesn't tell you is where/how the tap tempo is displayed.
On the line 6 m9 there is a very useful flashing light that confirms at what tempo the unit is running.
I like the sound of the G major, but its ergonomics could be better.
SecretSam
It’s 22 or so years old now. No web interfaces or phone apps to make things easier.
