Mogami 3173 XLR Wiring
Post by Mustang Martigan »
Hey, when wiring the 3173 to XLR, do you need to wrap the copper shielding wires with the uninsulated drain wire? Or can you snip the shielding, cuz it's already touching the drain throughout the cable?
Also, what's the point of the two pieces of clear insulation that don't have any wire?
Thanks.
Mustang Martigan
Posts: 12 Joined: Sun Dec 17, 2017 11:57 am
Re: Mogami 3173 XLR Wiring
Mustang Martigan wrote: Sun May 28, 2023 10:17 pm Hey, when wiring the 3173 to XLR, do you need to wrap the copper shielding wires with the uninsulated drain wire?
I would, yes.
They are 'packers', twisted in with the two signal wires to make that group more round or cylindrical, given a more consistent structure for the screen and outer protective sleeving to encircle. You can trim them back.
Posts: 42194 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Mon May 29, 2023 12:02 am
I would, yes.
I trimmed the shielding on the first one I made the other day; it works fine. What would the benefit be of combining the two?
Mustang Martigan
Better RFI immunity.
